- 20 Jul 2009
- The bleak North East arm pit of Britain
Hello
OcUK have added a few new lines to the Speakers line up. Made by Hercules, these speakers are a perfect balance of value and performance.
Take a look now
Hercules XPS 2.0 80 DJ Monitor Speaker System @ £109.99 inc VAT
Precision and quality design optimized for creating music mixes with computers.
- Silk dome tweeter delivering sharp and pure treble.
- 4-inch woofers with Kevlar diaphragms delivering homogeneous and precise sound.
- Dual port delivering powerful bass restitution.
- Wooden satellite made from 9 mm MDF, compact speaker measurements.
- Audio inputs (for connecting a computer, DJing equipment, mixing gear, MP3 players, game consoles or other audio sources)
- RCA connector (main source)
- TRS connector (6.35 mm) for balanced input
- Line input for connecting MP3 players or other audio sources
- Headphones output (speakers are automatically deactivated when headphones are connected).
- ON/OFF switch
- General volume adjustment
- Bass adjustment
- Treble adjustment
- Power light
- Ergonomic buttons based on Hercules DJ consoles, offering simple grip and use
Technical specifications
- Total power output: 2 x 20 W RMS
- Peak power: 80 W
- Frequency response: 60 Hz - 20,000 Hz
- Satellite measurements: 27.4 cm (H) x 19.2 cm (W) x 18 cm (D)
- Right satellite weight: : 4.22 kg Left satellite weight: 2.88 kg
- External power supply
- Magnetically-shielded satellites for an interference-free environment
- ROHS standard-compliant product
Only £109.99 inc VAT.
ORDER NOW
Hercules XPS 2.0 30 DJ Club Speaker System @ £39.95 inc VAT
A 2.0 speaker system with a compact design inspired by professional PA systems for DJs. A trendy and innovative flair that will make a difference when placed next to your computer.
- Lacquered black finish
- Metal grille to protect the driver
- The port located on the satellites’ front face ensures enhanced bass restitution
- Volume adjustment button on the satellite’s front face
- Tone adjustment button on the satellite’s front face
- ON/OFF switch
- Main line input
- 1 RCA audio output for connecting the left speaker
- 1 auxiliary input (for connecting your MP3 player) and 1 headphones connector located on the satellite’s front face, offering easy access
- Total power output: 2 x 5 W RMS
- Peak power: 20 W
- Frequency response: 80Hz - 20,000 Hz
- Satellite measurements: H: 19.5 cm / D: 11.8 cm / W: 10.4 cm
- Magnetically shielded satellites for an interference-free environment
Only £39.95 inc VAT.
ORDER NOW
Hercules XPS 101 2.1 Speakers System @ £139.99 inc VAT
Multimedia sound refined
XPS 101 … Simply sublime, in terms of both sound quality and design.
- High-end 2.1 multimedia speakers
- High-performance 2.1 audio system.
- Total power: 101 watts RMS (2 x 20.5W + 60W). Peak power: 202 watts.
- Speakers are magnetically shielded, so as not to disturb your surroundings.
- Subwoofer with subwoofer driver on the front and two passive woofers (one on each side of the subwoofer), for perfect rendering of bass frequencies.
A great new design, only from Hercules:
- Satellite bottoms and top of subwoofer crafted of metal alloy and formed via the “Die Cast” pressure injection method.
- Satellite stands made of clear Plexiglas.
- Piano-like finish on the satellites.
- Connectors located underneath the subwoofer, for enhanced aesthetics.
Multifunctional remote control with pulse switch and backlighting:
- Volume control
- Bass control
- Treble control
- Headphone input
- Auxiliary Line In input
- Connection cable to the microphone input on a PC/Mac.
- Product complies with ROHS standards.
- Product complies with the standard of less than 1 watt of electrical consumption in standby mode.
Only £139.99 inc VAT.
ORDER NOW
Hercules XPS 2.1 40 Slim Speaker System @ £39.95 inc VAT
Exclusive, streamlined and very trendy design: ultra-fine satellites blend in seamlessly with your indoor decoration.
- Total power output: 32 W RMS (2x8 W + 16 W RMS). Peak power: 64 W
- Each satellite features an active Neodymium transducer
- Magnetically shielded speakers for an interference-free environment
- Headphones connector and secondary line input located on remote control
- Built-in power supply
- Satellites feature a white lacquer finish, fashionable taupe fabric
- Satellite dimensions (alone): 23.5 cm H x 5.8 cm L x 7.2 cm D
- Wooden subwoofer dimensions: 24 cm H x 16.5 cm W x 20.5 cm D
- 1.8 m cable for connecting audio source
- Total power output: 32 W RMS (2x8 W + 16 W)
- Peak power: 64 W
- Frequency response: 40 Hz - 20 kHz
- Satellite dimensions (one): 23.5 (H) x 5.8 (W) x 7.2 (D) cm
- Subwoofer dimensions: 24 (H) x 16.5 (W) x 20.5 (D) cm
- Satellites are magnetically shielded: won’t disturb your surroundings
- Product compliant with the RoHS standard
ORDER NOW
Hercules XPS 5.1 70 Slim Speaker System @ £59.99 inc VAT
5.1 speaker system, featuring center speaker with flat panel screen mounting system and wooden subwoofer.
Ultra-slim satellite speakers: their sleek, modern design fits in perfectly with any décor. Includes a very thin center speaker with flat panel mounting system - a bonus, compared to current market standards. Lacquer finish on backs of satellites.
- Total power: 70 watts RMS (4 x 7.5 W (satellites) & 1 x 15 W RMS (center), 1 x 25 watts RMS (subwoofer)). Peak power: 140 W.
- Frequency response: 30Hz - 20kHz.
- Greater energy savings than market standards: special power supply uses less than 1 watt of power in standby mode.
- Magnetically shielded speakers won’t disturb your surroundings.
- Multifunction remote control - practical and easy to use:
- Control knob with 3 functions: on/off, volume control and bass control. LED indicators for the different functions.
- Headphone jack and microphone input.
- Auxiliary line input.
- Virtual surround sound button (applied to stereo input).
- Master on/off switch on the back of the subwoofer.
- Satellite dimensions: 23.5cm H x 5.8cm W x 7.2cm D
- Subwoofer dimensions: 27cm H x 17.2cm W x 25cm D
- Product meets RoHS standards.
Only £59.99 inc VAT.
ORDER NOW
Take a look now
- ON/OFF switch
- Bass adjustment
- Treble adjustment
- Power light
- Peak power: 80 W
ORDER NOW
- ON/OFF switch
- Main line input
- Peak power: 20 W
ORDER NOW
- Volume control
- Bass control
- Treble control
- Headphone input
ORDER NOW
- Peak power: 64 W
ORDER NOW
ORDER NOW
