** EK GTX 680 Waterblocks DUE NEXT WEEK **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
We have placed our order for GTX 680 waterblocks today, stock should be here next week.
Please ensure that you place a pre order to avoid disappointment. at the rate the 680s are selling and considering the emails that I have had about them today, I would suggest getting in quick before our allocation is depleted.
Pictures will be updated as soon as EK release some proper ones :)
EK-FC680 GTX Full Cover Waterblock - Nickel Plexi **EN Nickel Plating** @ £79.99 inc VAT
EK-FC680 GTX is a high performance full-cover water block for nVidia reference design GeForce GTX 680 & -670 series graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC680 GTX water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps.
Base is made of electroless nickel (EN) plated electrolytic copper while the top is made of quality cast acrylic material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
EKWB recommends the purchase of aesthetic retention backplate (EK-FC680 GTX Backplate - Black) which improves the looks of your graphics cards and also provide some passive cooling to the VRM section.
G1/4" threaded fittings can be used on both side of the water block (on copper and plastic) and 2 plugs (EK-Plug G1/4) are enclosed!
Up to four EK-FC680 GTX series water block can be interconnected with EK-FC Bridge & Link system. The correct connection link for this water block is EK-FC Link GeForce.
Enclosed:
- EK-FC680 GTX series water block
- mounting mechanism with screw-in brass standoffs
- thermal pads
Please note: Thermal paste is not included and needs to be purchased separately. EKWB recommends Gelid GC-Extreme for best performance.
Made in Slovenia - Europe!
Only £79.99 inc VAT.
ORDER NOW
EK-FC680 GTX Full Cover Waterblock - Nickel Acetal **EN Nickel Plating** @ £79.99 inc VAT
Base is made of electroless nickel (EN) plated electrolytic copper while the top is made of quality POM Acetal material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
Enclosed:
- thermal pads
ORDER NOW
Will there be tech lab pre-fitted cards? As I see the POV cards blocks on, but at £600 thats a bit steep.
I've discovered my hands are far too big and shaky for fitting waterblocks.
Seriously giving consideration to an IB + PCIe 3.0 upgrade this year.
well the 7970 has switched to an MSI Oc Model card
it depends what watercooling friendly board partners gibbo buys really and of course, pricing and availability.
in honesty though, the feedback I get from customers is that they prefer to overclock themselves, especially on a card with WC.
