Display port for radeon 7970
18 Dec 2009
Hi all ,
Just got a new system with two 7970 and a dell ultrasharp 27" monitor which comes with a display port cable , did not realise the gpu was mini display port , so my question is ... Is there any different between the mini display port to dvi and hdmi ?? Which is the best option?
Dog
If you don't have a DVI cable, grab a mini Displayport to Displayport adapter. There's no difference between DP/DVI/HDMI, but DP can carry more bandwidth.
Use two cables?? For one display, I got VGA cables and display port cable ( not mini ) with the monitor and dvi to hdmi adapter with my 7970
Sorry getting confused between threads. Ignore that just one cable!
Hi all ,
Dog
Did you not get a dual link DVI cable supplied with the monitor?
If it was new you should have.
