- 4 Jul 2009
- Perth, WA, Australia
As the guy above said, you just need a molex power to SATA power cable and an eSata cable.
Pretty sure he meant a regular SATA cable. You'd only need to mess with eSATA if you wanted to connect six drives. I'm assuming that the guy who originally posed the question is installing an OS on one of the five 2 TB drives (or running something like FreeNAS from a USB stick). (I wouldn't install an OS on a storage drive: I prefer to keep my data separate from my OS. But that's personal preference.
)So, the (regular) SATA cable needs to be routed from the motherboard up to the top bay.
As for the BIOS, read back a few posts; I posted a link yesterday to the hacked BIOS that'll enable AHCI mode on the 5th & 6th SATA ports.
EDIT: The SATA cable needs to be right-angled at one end. (I think it's a "right" right-angle, to avoid hitting the battery? Better check that; I forget which way is right and which left!
) Also, 50 cm is the perfect length. (Shorter won't reach.)
