Windows serial numbers
10 Jan 2009
Hi all, I'm looking to buy a laptop from a friend, but he has lost the windows 7 installation disks. It has the code printed on a label at the bottom.
Can I install a version of 7 and use the serial on the laptop? If so where could I get a copy of win 7 with no code?
Thanks
Are you sure it even came with discs? Usually the recovery data is on a separate partition on the hard disk nowadays.
