- 3 Mar 2010
- Highlands, Scotland
All set up, but yet to give it a proper test run
Game of Thrones on Blue ray should do nicely!
I was up until 1am lifting carpets and running speaker cable, neatly re routing cables behind the TV, labeling cables etc Prob went a bit far but I'm really fussy about things like that.
It's got it's own shelf in my TV unit and while not snug, there is only about 10cm clearance above the receiver with around 10cm either side (open front)
Pioneer state 30cm above it! Although this is not a high powered unit I will keep an eye on the heat output and maybe invest in a small fan if needed
Game of Thrones on Blue ray should do nicely!I was up until 1am lifting carpets and running speaker cable, neatly re routing cables behind the TV, labeling cables etc Prob went a bit far but I'm really fussy about things like that.
You won't be able to go back to standard tv speakers now.
unless you have a £10k system you probably wont hear any benefit.
