News : Mayhems Biocide Extreme
We've been talking with you guys and other people over the net and as most of you will know there does seem to be a link between biocides and problems with plating. So i have been working on some thing that is a solution to help towards reducing the risk of plating issues and biocide usage.
Under testing i have noted that plating issue arise more when the PH of liquid turn to acid and this helps exasperate the problem further yet pre-mix fluids which have a PH of between 6.5 to 8.5 doesn't seem to cause this issue. All so another thing to note is dye all so work better in this range and will not lose there colour.
Now even though on Mayhems Biocide Extreme we have it on the bottle only use between 1 to 2 drops per 1 Ltr of fluid people still think more is better which is not the case and this causes dammage to a water cooling system.
So with in effect next week we will be rolling out a "test" kit with all our Mayhems Biocide Extreme. This test kit is a very simple one and will comprise of a Card with instructions and a chart and 10 PH test strips (you can cut them in 1/2 and make 20 if you like).
Using the PH test strips and the instruction card which has the colour chart of you can see the effect mayhems biocide extreme has on you liquid in your water cooling system and it will help keep you system in top shape.
Even though we personally do "not" produce blocks plated or none plated we think that by doing this it will teach and help prevent further issues in the future if the user does it correctly. All so the it will save the user purchasing a more expensive PH tester.
One of the advantages of using test strips is that when testing our Ultra Pure H20 because of the lack of dissolved-oxygen in the water normal cheap end PH electronic testers cannot read the liquid correctly but test strips can.
We think by doing this little token gesture to you our users it will show that we do indeed care about our product lines and all so care about our users.
Mick
Mick
