You can buy nVidia 3DTV
http://www.nvidia.com/object/3dtv-play-overview.html
Its free if you have the 3D vision usb dongle for the IR emitter.
I wondered if I would/could simply use the 3d active glasses that came with the TV combined with the goodness of the gtx680?
Thats what 3DTV Play is for. 3D Vision is the IR dongle and glasses for 120hz compatible monitors.
3DTV Play just unlocks the nVidia 3D driver for use with ur TV.
you can download a 3dtv play 30 day free trial off the nvidia site and try for yourself =). I couldnt get 120hz 1080p outa my sammy 40" though, due to the fact a single hdmi cable wont carry it as i understand it.
1080p@24hz 3d sucked, but 720p@120hz was nice atleast, but just made me want a proper 3d vision monitor =)
the one i have is the ue40d6530, hope you get better results than i did =)
Hopefully I will be ok then?One rung down from the high-end D8000 series, the Samsung D7000 range of LED TVs is blessed with all the features found on the D8000 (including 200Hz/ 240Hz motion
Checkerboard it is then.You can play 3D games with 3DTV Play, but why would you want to? By design, 3DTV Play forces you to play 3D games in inferior 720P framepacking which results in poor image quality. Native resolution 3D Vision/checkerboard mode is prefered, but it won't work because your TV does not support checkerboard mode.
For non-checkerboard TVs, there are three options:
Tridef 3D
iZ3D
3DTV Play
TriDef 3D and iZ3D support side by side mode which gives you native resolution 1920x1080 at full frame rate. With 3DTV Play you are doomed to scaled 1280x720 gaming on a 1920x1080 screen. If you want to use nvidia 3D software, trade your TV for a D7000/D8000 LED samsung, any 2010 samsung, or an LG TV. This will enable you to 3D game in native resolution with 3D Vision.
