Consigliere
- 12 Jun 2004
- SW17
They would just say it equals 0.00r1
Her first example
.999r = x
9.999r = 10x
Then she does -.999r on both sides, but no matter how far you repeat it, at the end it will be 1, they just round it down to suit their argument.
10 - .999r doesn't equal 9. it'll be an infinitely small number, 9.000r1 Not 9.
To which the obvious answer is "you can't have a 1 in the infinityeth place, you dolt. Infinity does not work that way". The "you dolt" part is the most important part of that.![]()
So how would you define a number that is infinitely small but not 0?
Or you just do
0.33333333r=1/3
0.99999999r=3/3
0.99999999r=1
Or you just do
0.33333333r=1/3
0.99999999r=3/3
0.99999999r=1
0.999r + 0.111r = 1
Nope. It's 1.111r.
Her first example
.999r = x
9.999r = 10x
i said 0.111r
add one to start 1.xxxx all the rest shift to 0?
A more interesting subject, does infinity exist?
