best overclockers ?
Everything considered i went for a gigabyte 7950 windforce , picked up for £70 less than overclockers cheapest 7970. As i game at 1920x1200 anything more is just overkill with thease inflated prices at the moment.
Should be here tomorow :D
I'm guessing you will enjoy your new card :D
Post if you OC it as I'm interested in other 7950 clocks/voltages :)
Ok thanks, great card by the way, good luck with the clocking. Alternatively you could have got a asus directcu 7950 for £313 which is also a good choice :-)
Yeh i saw that one ,but the asus just didnt tick as many boxes even though it was £40 cheaper.
There have been reported problems with the heatsink, allought that might just have been a dodgy revue card . Also its a 3 deep card so will be a tight fit if i deside to crossfire at a latter date . And allso you have gigabytes 3 year warrenty and uk based returnes should i need it ..
