RAM for 'old' Titan Spirit GT
19 Nov 2008
Hi all
I want to put in another 2Gb of RAM to this 'old' PC - or maybe put in 4Gb of new RAM. Does OcUK currently stock anything suitable for this sort of PC?
Here's what I do know is inside: 2.4 GHz Intel Core Duo E4600, with 2Gb of dual channel Corsair 800MHz RAM (CM2x1024-6400C5DHX, 5-5-5-18). The mobo is a Abit IP35 Pro XE. It has a 650W Corsair PSU. Hope that helps!
Thanks for that! Will I need to tweak anything (BIOS perhaps) when I add another 2GB?
I'm not sure. Best thing is to set the timings/voltage as is stated on the RAM. However it should work straight away, just not necessarily at its rated speed.
Also, someone will help me on this I hope, but it's best to have a matching pair [say 2x2GB] rather than a mix-match of RAM
Ok. I currently have 2x1Gb sticks and have another 2x1Gb sticks on order. As far as I can tell, what I've ordered is exactly the same as what I've already got in my PC.
