Claiming tax on mileage
13 Nov 2002
Scotland
Guys
Just want to check something.
I get a lump sum split over 12 months to run my car as well as a mileage rate of 27p/mile.
Can I claim the difference? 45p I assume at the moment?
The thing I dont know is if the lump is taken into account in any way or not
Is a MAP the same as a car allowance then?
No, a car allowance is taxable as if it were any other part of your income, MAPs are only taxed on one's P11D if they go over the value of the HMRC-approved payment for the miles you did.
By the way OP, you can only claim the tax on the difference, not the actual difference.
So if you did 12,000 business miles per year and receive £100 per month MAP from your employer, you'd get (10000 * £0.27) + (2000 * £0.25) + (12 * £100)= £4,400. Approved HMRC payment would be (10000 * £0.45) + (2000 * £0.25) = £5,000, so you'd be able to claim 20% of (5000-4400) = £120, assuming you are a basic rate tax payer.
I think.
I get £5600 a year taxed and split over the 12 months...
Does that mean I can claim tax on the difference on the mileage?
MAPs shouldn't be taxed (unless over the HMRC mileage threshhold)?
If you get £5,600 of MAP payments p.a. then you have to do at least 14,400 business miles to avoid paying tax.
Worked it out today, its about £1800 of a difference over the 13000 miles or so I done this year
Also done one for 10/11 too
My employer used to do it all, but they missed last year and I dont have hope theyll do it for 11/12 either
To confirm the calc:
12415 miles at 27p mile completed in 11/12 = £3352.05
10000 x 45p = 4500
2415 x 25p = 603.75
Total tax free amount = £5103.75
Therefore the releif = £1751.70 for 11/12
That's not the relief, that's the amount on which you are entitled to relief, so take 20% of that (assuming you are a basic rate tax payer). Also, I believe you should have received (10000 * 0.27) + (2415 * 0.25) = £3303.75, not £3352.05. Everything over 10k miles is allowable at a maximum of 25p no matter what your employer paid you for the first 10k, I believe.
This means you'd get 20% x £1800 = £360.
Robbie G is correct. ALso, don;t foget you can get an extra 5p per mile if any of those journeys had an employee in the car with you.
Aye, thanks guys, i know its the tax rate on that
Forms are ready to go, should be worth a fair bit over the two years
Thanks for the help
Worth looking at what you carry also, there's a clause about getting passenger mileage if you carry boxes etc for work too I think. At least I know we can claim for a passenger if we carry a box over a certain weight (or we could a few years ago).
