my mum has this car, dont know if thats a good thing or bad thing
i think its a cracking car, pulls great, great on fuel, its very comfy (the seats are lovely)
things i dont like and things to look out for
1) check the bumpers for cracks and correct fitting, quite a few have been bummped and they are very easy to crack also the sides of the bumpers are held in by a kind of pin thats in the car and a little hook moulded into the bumper, these are very easy to break.
2) the wheels corrode really easily, they can be fixed but most people just get them painted rather than the cut finnish they come with new (this ruins them imo)
3) the single tailpipe on the oil burner (the petrol looks so much better with twin exit)
4) they can go through brake pads quickly depending on how its driven
5) check th cd player, the 6 cd stack has a habbit of messing up and so wont load or eject discs
6) check all the bulbs on the instrumend display, if one goes its a PITA to replace
the car shares an engine with the x type jag, so parts are very easy to get and you can flick between the two. (my mum saved £75 by buying a new EGR from jag instead of ford)
i think overall its a very nice car and good examples dont cost the earth,
