Massive setup! =) Where did you get those adapters between the gpu blocks? Cant find them on overclockers.
we dont have them listed...
yet
Thanks Guys, Sure OCUK will have the blocks soon. They really are excellent.![]()
Hey Stu just wondering how your running your monitors, are you using the miniDP adapter that was shipped with your card?
very nice stu well done mate![]()
Epic build. If you don't mind me asking how easy were the EK gpu blocks / back plates to fit? I have got 2 on their way for my 7950's...
By the way - your rig makes me jealous![]()
when doing my second one ... almost snapped my card until I realized.
I'd like to thank you for the pics showing how your tubing is laid out, its nice and tidy and has given me some inspiration for my project. If there was anything you would change with your tubing layout what would it be? if anything at all that is![]()
I think, generally speakng, its just addds HEAT as the rad must sit at case internals temp. However, its there as a secondary and teh fans programmed to only kick in if the delta between main rad in/out exceeds my parameters so I will await the height of summer and see if the fans ever kick in on it. to date, they have never been on. If not, I may well take it out and use it on another build.Also do you think the 360 rad adds anything to your loop? Would you see any difference with it removed?
Beatuful build mate. drooled ony my keyboard a bit tbh
Good Luck![]()
Really easy mate, just take your time and refuse to rush, you will be fine. The above chaps tips are all excellent, I need say no more.
P.S: I bet your not jealous of the 89 hours I have worked this week though.![]()
I should have it all built and running by the middle of next week
Well, I guess for now its finished.
Cpu is now running 4.9ghz stable with the cards at 1200 GPU & 1575 Ram.
While I remember to ask, how did you route the fan cables to the aquero?
Plan to link my 4 180mm G-Silents to a fan controller to keep them low or off when required.
The Aquero a worthy investment? I know zero about them, but see an Aquero 4 on the MM that could lure me away from my FC5.
