we all know that water is more effeicient at removing heat than air, but ultimatley all water is doing is delaying the process of your pc heating up longer than an air cooled system. as when you water reaches the same temp as the temp in your room it will then gradually increase warming the ambient at the same amount untill everything is the same temp,
obviously the bigger the room the longer this will take but we cant increase the size of out rooms easily. yes you can open doors and windows in the winter but opening a window in the winter will have the same effect as having aircon on all the time. and in an attempt to kool your pc you may have to suffer cooler than comfortable room temps.
so water chiling is the only real answer to nice comfortable room temp and a cold pc.
what a long winded way of asking are there many options other than Hailea water chillers? as sometimes i dont really want to put the aircon on just to keep ambient temps down as the room warms up a hell of a lot
and if i can chill my water and keep pc kool but still in a comfortable room not to hot and not with ac on all day would be nicer
hailea or anyother ideas ?
