Xbox capture card
Technically it could, but the quality will be shocking. The manufacturers website lists the resolution as just 720*576
poop :(
could you point me towards a cheapish way of doing it, as my son wants to upload his matches to youtube etc and via the xbox you can only upload less than a minute
seeing as you have the card i would suggest try it and see, if the results are not to your liking then look into a better capture card.
