I still use a wooden spoon that i got free from Radio Times 15 years ago.
i would rather do without than have cheap cack everywhere!
Congratulations. However, that doesn't mean that all wooden spoons are the same, which was your contention.
How exactly does one wooden spoon which costs £1 differ from one sold elsewhere for £10? Surely a wooden spoon is a wooden spoon...
He must source his wooden spoon that uses mahogany or something.
I'm no expert on wood, but the type of wood used matters.
Some mugs are better than others. For example, the cheapest ones will be seconds, with imperfections/warping... you get ones made with better materials... etc... which matters, even if they all shatter in the same way if you start throwing them to the ground.
Erm, I in know way selectively quoted, which had the affect of changing the meaning of the words.
But yes, some stuff's worth spending more on, such as wooden spoons, as they're not all the same.
I think you've confused your own argument.
Do you agree that some things are worth spending more on, some do not? No?
If you pay peanuts you get a monkey
For most thing I have the philosophy of buying once, right.
Not only is it usually cheaper in the long run, but you get lots of other advantages along the way. E.g., maybe the item is more efficient or just a better product to use.
