Which block for a HIS 6970?
17 Dec 2004
Crawley, WEST SUSSEX
Hi,
Just bought a HIS 6970 off the MM and need to get a block for it and just wanted to know what I should get? I usually go for EK as never had a problem with them but have hear something about flaking on the 6970s? I see there is a XSPC one on OCUK but not sure if its any good?
All advice welcome, thanks.
The flaking is more pronounced with the non-EN blocks, but as always with any Nickel plated blocks flaking is an issue. The EN blocks are a lot better, significantly lowering flaking.
Depends about preference on looks really, they all perform within 5 degrees of each other which is fairly insignificant, I think the Koolance blocks look cool, but are a tad expensive.
Tbh, you'll be happy with any block :)
