ITX system, will it work
There's a review of the case here:
Thermaltake Element Q Mini-ITX Case
It looks like it's designed for the HDD to fit at the side of the case in an area designed for a 3.5" disk.
If you're going to use a 2.5" disk you'll need a 3.5" to 2.5" mounting kit so you can fit it in the same place.
i will just mlunt the hdd with sticky tabs like i have on my pc when i put the ssd on the back of the motherboard tray
