Why MSI afterburner ?
30 Sep 2008
surrey
I see that most people use msi afterburner for overclocking there ATI cards,even if the card is from a different manufacturers. I have a gigabyte 7950 which comes with easy boost . What will afterburner do that easy boost wont ???
No one knows the answer because they wouldnt use anything other than MSI afterburner :p
MSI Afterburner is so easy to use for voltages and overclocking, easy to set up profiles, so much graphics card monitoring available and manual fan control / profiles, plus video recording and screen capture that actually work, and its free.
I dont think theres any other overclocking software that even does 10% as much.
It just offers better control for me than others.
Tried Asus GPU tweak and Sapphire Trixx, and while they can get the job done to a degree, they just don't offer the flexibility of AB
Plus it has all the on-screen monitoring as well.
It's just the best
Agree with eyetrip.
I never really used afterburner until I got to my Gigabyte 7950 OC cards. It helped me squeeze a bit extra from them, as well as monitor the temps, clock speeds, fan speed etc. I had tried a few others, like Easyboost, Trixx, etc but they weren't as user friendly or offering the same kind of features for monitoring.
THanks .
Downloaded and had a play,but for some reason it wont let me access voltage and shader control even though i have enabled it and restarted afterburner. I am using V2.10 ??? strange:(
THanks .
Get the 2.20 Beta 15 from for example here
2.1 is a year old, not sure why they keep this in Beta still.
I use it, as it works perfectly with my G19 keyboard and get all the info in game on that.
