Odd result with 680...
8 Sep 2010
Kent
I have just run the High 1080p benchmark for Shogun 2 with my brand new 680GTX and it has given me a worse result than with my CF6870s? I have looked at anandtech's review and it should be getting double the result I am getting (which is 56.575)...
Any ideas? It certainly seems to have no trouble with BF3 on Ultra though :D
Hmm. I would have thought that CF 6870 were actually faster at raw speed when scaling than a 680.
I'm probably wrong, mind, but I could swear that 6870CF was very fast indeed, lacking only in vram :S
The 680 is probably bottlenecked in an AMD system in a cpu intensive title whereas AMD gpus work better in a complete AMD setup.
Probably due to AMD putting more effort in to ensure their own tech works better with each other.
Shogun 2 is very reliant on CPU power.
I got the same result on a GTX275 as i did on a 480gtx until i made the jump from Core2Quad to i5 2500k.
Going from a 3.6GHZ Q9650 to an i5 2500k @4.6GHZ doubled my framerate.
Uhm why wasn't the processor bottlenecked before seeing as CF is even more CPU intensive?
Who's to say it wasn't?
Majority of people don't even realize they're bottlenecked because you get the same old people saying "CPU's aren't that important in gaming"
Well I used to get 75fps with my CF6870s on the same benchmark. So if I am CPU limited then surely I would get the same FPS with either the 680 or CF6870?
Guess not.
I suppose Shogun 2 is quite CPU intensive, so it's just going to be a one off really as most of the games I play a more on the GPU side of things.
Thanks.
I've gone from a 6870CF to a 680, and damn it's a big improvement.
6870CF is about equal to the power of a 580, not counting compatibility/drive issues in some games.
The 680 is leagues ahead, well worth the upgrade for me :)
But as above, your limitation is your cpu.
I'm running an i5 2500k at 4ghz and it flys.
I agree. It was just Shogun 2 running slower in the bench than my 6870CF was a bit of a suprise.
But I suppose it's AMD Optimized. But, why would it run slower than my CF setup on the same CPU if I was CPU limited?
