Manually set up 5.1?
2 Mar 2006
Derby
Hi guys,
Just in need of some help. How would I go about setting up the speakers manually on my onkyo avr? I have used the setup microphone but something doesn't sound right, the volume is low on the centre speaker meaning that the effects are loud but voices are quiet.
Are there any guides to follow?
I know how to access and change the settings, I was hoping to read up on how it should sound if that makes sense, it seems quite complicated :(
Bear in mind that a lot of movie soundtracks emphasise the effects anyway,many people complain of quiet dialogue when listening at lower volume levels,due to the sound engineers mixing the soundtrack at reference level,which is very loud.
Im sure your amplifier will have a dynamic range control of some kind to compensate for this,my Marantz reciever has Audyssey Dynamic Volume,which really brings the dialogue forward.
Or you can bump the centre up by 3-6db, as you see fit.
When I set mine up manually, I first set up the distances for each speaker which is straight forward enough with a tape measure to the seating position (off course some compromise if seating is for 2) then using the test tone adjusted the levels for each speaker so they sounded relatively the same level, but as said above then increased the centre by a bit more.
i tried out the audyssey microphone thing with my onkyo as well, but found it also came out with weird levels, so set them myself. didn't take too long. You can find various demo or test video files on the web that help.
I did as Mr Men did, sat and listened to the noise and got the same volume from all the speakers, I kind of guessed that was how it should be.
I'll watch a blu ray and see what the sound is like now.
Thanks for your help.
P.s. which videos for set up would you recommend?
