Best product for cleaning engine bay?
18 Nov 2011
Kent
Hi
The engine bay on my old civic is looking pretty terrible and I would like to give it a spring clean!
What is the best product to cut through the grime and get it looking good again?
Thanks
Jizer is pretty good if you want to cut through a lot of grime. Make sure you cover the electricals before cleaning the engine bay out.
I use muc off too, or just soapy water and a rag if you want to give it a light cleaning.
I use Auto Glym Engine & Machine Cleaner, although any similar product will work just as well if you agitate it a bit :)
I use Gunk foam spray. When cleaning the engine block get the engine warm but not hot before spraying. Helps with cutting into the muck.
