- 31 Oct 2011
Okay, so, I've built a new PC, had it for about 4 months now. Recently, within the last month or so, Windows 7 has been taking an absolute age to install anything whatsoever.
As an example, it took 30 mins or so to install the latest Java (32bit). Now I know Java isn't a particularly large program, and it shouldn't take that long. Comparing the install to an OptiPlex 755 with Win 7 x64 leaves no competition. The 755 completes the install after a few minutes.
I recently tried to install Blacklight Retribution, and it did install, but took near to an hour. Friends commented saying it took maybe 15-20 mins for the entire install for them.
I have tried disk defrag, registry cleaner and/or defrag, even changing the HDD operation.
It doesn't seem to make a difference and I know the easiest thing to do is wipe / clean install but.. really?! The effort.
So, I ended up here.. do any of you have any other ideas?!
I'd really appreciate the help. Thanks.
P.S. I have also tried disabling background processes, tasks etc, and there's nothing else running apart from the obvious (AV etc.) when I attempt, with no difference.
