40hp outboard sooooo noisey
28 Nov 2011
Cumbria
Hi i ran outboard up yesterday (first time this year) have changed plugs and oil and now it sounds sooo noisey. It runs sweet plenty of water circulating, had it running for about 15 min and it didnt get louder or quieter. Any ideas please
Outboards are generally very noisy!
It may just be because the prop is out of the water (if you're running it using a hosepipe or something)?
Have you flushed and changed this engine in a confined space before (assuming you are in a confined spae?)... could it just be that you are getting plenty of echoes/reflections?
Hi
its a honda 40hp 4 stroke year about 2000-2002 no idea of running hours, what ever was not working correct is ok now. It was very loud for about 30 seconds today then went quiet again, maybe with being lay down in boot of car.
Thanks
Sure you know this already, but be careful laying 4 strokes down on their side, should be a label indicating the correct side.
Laying the wrong way can result in oil leaking from the sump and ending up on filters etc and worst case into the cylinders.
helpfully someone at my boat club turned mine from the correct side to the wrong side last year
Yes had it out on water both times once nice and quiet second time rattled it head off,
Thanks i took it to our local boat place he is going to strip it down and have a look, he thinks it could be @@@@ in the oil pump or in a oilway.
cheers
