**EASTER BANK HOLIDAY DEALS - ROUND 1 - THE PHANTOMS!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
To celebrate this long bank holiday weekend, today and tomorrow we shall be launching several rounds of deals, these deals shall end Tuesday midday, lets get the ball rolling the superb range of Gainward Phantom graphics card. Power & Silence all rolled up into the same package:-
Gainward GeForce GTX 580 "Phantom" 3072MB GDDR5 PCI-Express Graphics Card @ £349.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Instead of fans on its obverse side blowing air onto the PCB, there are three fans on its reverse side, drawing air from the aluminum fin array, and onto the PCB. The PCB also seems to be a non-reference design.
Features:-
- Core Clock: 783MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 3072MB GDDR5
- Memory Clock: 4020MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1566MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 2 Years
Was [£399.99] Inc. VAT
Only £349.99 inc VAT. - ONE OF THE BEST 3GB Cards available & now the cheapest!!
ORDER NOW
Gainward GeForce GTX 570 Phantom 1280MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
Features:-
- Core Clock: 750MHz
- Memory: 1280MB GDDR5
- Memory Clock: 3900MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1500MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 years
Was [£269.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 560Ti "Phantom" 2048MB GDDR5 PCI-Express Graphics Card @ £219.95 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560Ti - arm yourself for battle.
Features:-
- Core Clock: 822MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 384
- Shader Clock: 1644MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was [£239.99] Inc. VAT
Only £219.95 inc VAT.
ORDER NOW
Gainward GeForce GTX 560Ti "Phantom" 1024MB GDDR5 PCI-Express Graphics Card @ £169.99 inc VAT
Features:-
- Core Clock: 835MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4050MHz (Effective)
- Shader Clock: 1670MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was [£189.99] Inc. VAT
Only £169.99 inc VAT.
ORDER NOW
Finally, don't forget to Pre-Order a GTX 680 Phantom if you want one of the best:-
Gainward GeForce GTX 680 Phantom 2048MB GDDR5 PCI-Express Graphics Card @ £529.99 inc VAT
The GeForce® GTX 680 delivers more than just state-of-the-art features and technology. It gives you truly game-changing performance that taps into the powerful next-generation GeForce architecture to redefine smooth, seamless, lifelike gaming.
Immerse yourself in an ultra-smooth gaming experience with exciting new NVIDIA technology advancements like NVIDIA Adaptive Vertical Sync. It’s a fast, seamless way to adjust VSync to your current frame rates for maximum playability.
Gainward GTX 680 Phantom, continue the elegant design of the first generation. The new Phantom II comes with brand new fins design (patent pending) that introduces 1) better thermal performance 2) lower acoustic level 3) more solid structure than previous generation. With this new outstanding innovated thermal design and optimized product design Gainward GTX 680 Phantom delivers an extreme gaming performance for enthusiast gamers.
Gainward Grand-Prix Heat-Pipes Hybrid Cooler, was designed in 6 mm copper-water heat-pipes on a copper base conducting heats away from GPU at highest efficiency, then dissipating onto aluminum heatsinks, which are forced ventilated with Great 8 cm silent PWM fans (GR8).
Great 8 cm silent PWM Fan (GR8) achieves highest cooling performance at much lower temperatures under power saving mode.
Gainward provides 4 ports in one, fulfills universal connectivity to diverse displays in extreme high-definition resolution. Dual View is supported with ease without bothering connector conversion.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- Core Clock: 1084MHz (GK104)
- Core Boost Clock: 1150MHz
- Innovative thermal design: Vapour Chamber (Quieter & Cooler than previous generation)
- Gainward 6+2-Phase PWM for improved OC headroom and power stability
- Memory Clock: 6300MHz (Effective)
- Memory Bandwidth: 201.6GB/s
- Processing Cores: 1536
- Shader Clock: 2168MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 215 watts at stock speed)
- 1x 8-Pin PCI-E Connectors & 1x 6-Pin PCI-E Connectors required
- Card Dimensions: 270*111.15*38.75 mm
- Warranty: 2 Years
Only £529.99 inc VAT.
ORDER NOW
The Phantoms are great cards, have a good in depth look at the cooling system here:-
http://www.gainward.com/phantom/p2/index.php
What you waiting for? Time to spank the wallet guys. :D :D :D
We shall be posting more rounds of deals up throughout today, so keep your eyes pinned on the deal section. :)
You could have started this yesterday, now everyone (ie me :p) has to wait till Tuesday unless couriers will deliver on bank holidays?
pretty sure couriers will, but you won't get it for free
As for the sales, damnit! coulda started yesterday, or extend it until next wednesday? :p
Argh why is all the kit I want appearing on sale now, right before I have to pay the deposit on a house :-( Need more money. . . . . . oooo found a penny!
"The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580."
You might want to change your synopsis for the 580 cards now the 680 is out :)
