Hi there
Not a 7970/7950 I know, but this is a awesome deal:-
OK first of all getting 6970 to sub £200 is a milestone in itself and OcUK is now at least £50 cheaper than competitors on a 6970. Secondly however these are the amazing Twin FrozR III & Lightning cards, so the most overclockable and fastest 6970 available.
Basically these cards offer close to GTX 580 performance which starts at £300 and is quicker than GTX 570 which is £200 from here. Compared to 7850 these cards are noticably quicker and trade blows with the more expensive £260 7870.
As such this deal is very very good, so get involved:-
MSI HD 6970 OC 2048MB Twin Frozr III GDDR5 PCI-Express Graphics Card with FREE Deus Ex PC Game @ £199.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
This special Twin Frozr III Edition utilises the same PCB from the flagship lightning cards and as such has both performance and silent modes. With the amazing Twin Frozr III cooler for near silent operation, cooler running and great overclocking potential. There is no better value 6970 on the market!
Features:-
- Same PCB / Components as Lightning Version
- Huge overclocking potential (1000MHz+ Core possible though not guaranteed)
- Near Silent Operation
- Core Clock: 880MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5500MHz (Effective)
- Memory Bandwidth: 176GB/sec
- Processing Cores: 1536
- Texture Units: 96
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 1x 8pin and 1x 6pin PCI-E power connectors required
- 500W minimum PSU recommended
- Warranty: 3 Years
- Supplied with FREE Deus-Ex PC Game (Subject to availability)
Was [£269.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
MSI HD 6970 OC Lightning 2048MB GDDR5 PCI-Express Graphics Card with FREE Deus Ex PC Game @ £239.99 inc VAT
These cards are specifically designed to handle the extreme overclocking which eager gamers and media outlets around the world have been waiting for. Industry-leading Power4 architecture and Twin Frozr III dual-fan cooling with innovative Propeller Blade technology brings together a solid power supply with advanced cooling technology. This results in huge boosts to overclocking potential and stability, enabling the air-cooled 6970 Lightning to break the 1GHz core clock barrier with ease. The Lightning series of graphic cards is designed to offer the ultimate in overclocking capabilities and is the superior choice for overclocking enthusiasts seeking to set new world records!
Inheriting the impressive Power4 architecture from previous Lightning cards along with improved components and design in four areas. The PWM module is twice as large as before and provides double the amount of current to the GPU. Memory has its own independent power supply using an 8-pin connector for minimum interference to greatly increase overclocking potential. The next-generation Proadlizer capacitor increases signal stability by leaps and bounds while CopperMOS, the industry's best MOSFET, provides the GPU with a large and stable power supply. Combined, these features provide ordinary users as well as extreme overclocking enthusiasts with a more stable operating environment and the best performance out there.
The all new Twin Frozr III cooling design utilizes the innovative Propeller Blade technology to double the amount of airflow compared to conventional fans. The airflow also covers a large surface to remove heat quickly and effectively, and when you add in twin 9cm PWM fans, SuperPipe technology, and the Form-in-one heatsink, the result is GPU operating temperatures 26°C lower than the reference board when the 6970 Lightning are operating under full loads. Fan noise is also 11dB lower in addition to having much higher overclocking potential.
The MSI 6970 Lightning graphic cards come with the latest version of MSI's exclusive Afterburner V2.1.0 overclocking utility. The utility not only adjusts GPU and memory clock but also manage the GPU/Memory/PLL(VDDCI) voltages to maximize overclocking potential. Thanks to Triple Overvoltage, the overclocking potential of 6970 Lightning is much higher than the reference board and offers enthusiasts ultimate performance.
For hardware enthusiasts, the MSI 6970 Lightning graphic cards come with exclusive extreme overclocking features. Apart from V-Check Points and V-Switch for monitoring and adjusting the GPU/Memory/PLL(VDDCI) voltages in real time, Dual Bios switches help to effectively prevent potential problems stemming from liquid nitrogen cooling. PWM Clock Tuner also helps to increase overclocking potential. All of these come together to make the 6970 Lightning the ultimate graphic cards for extreme overclocking
The MSI 6970 Lightning graphic cards use top-quality Military Class II components including All Solid Cap for overclocking and full-speed operation, SFC for 10% higher efficiency, and 30% increase in maximum current, as well as Hi-c Cap with Tantalum core which boasts 8 times the lifetime of conventional solid capacitors. These high-quality components not only increase the graphic cards' overall service life but also enhance GPU stability.
Specifications:-
- Stream Processors - 1536 Units
- Core Clock - 940 MHz
- Memory Clock - 5500 MHz
- Memory Size - 2048MB GDDR5
- Memory Bus - 256 bits
- Output - Mini DisplayPort*2 / HDMI / DVI*2
- TDP</b> - 269 W
- Card Dimension - 310x127x40mm
- Form Factor - ATX
- DirectX 11 - Yes
- OpenGL 4.0 - Yes
- CrossFireX - Yes
- Eyefinity - Yes
- AVIVO HD - Yes
- PowerPlay - Yes
- HDCP - Yes
- World’s first 18 phase PWM on HD 6970.<br>
- Independent Memory Power support. <br>
- Copper MOS with 2x high current capacity. <br>
- Proadlizer*4 to optimized power supply. <br>
- Twin Frozr III Thermal Design with 26C cooler & 11dB quieter. <br>
- Propeller Blade technology for 20% more airflow. <br>
- Dual 9cm fans with dual 8mm SuperPipes for best heat dissipation. <br>
- Form-in-one heatsink covers memory and modules to dissipate heat efficiency.<br>
- Support voltage adjustment of GPU/Memory/VDDCI<br>
- Military Class II Components for longer product lifespan. <br>
- LPL (Lightning Power Layer) for the stable power supply.<br>
- Usage of the Micro/DIP switches on rear of card voids warranty - For extreme/expert overclockers ONLY!<br>
- 3yr Warranty!!
Was [£299.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
This is crazy pricing for such a top of the range 6970 card.
