I mean as in the motherboard is rotated 180 degrees.
Im looking for a smaller midi tower.
I had my eye on a thermaltake A30 however it cant support 3x120mm fans.
Keep the suggestions coming!
Ah my bad, i actually didn't think about that...That's the ONLY way rotating 180 degrees would work, otherwise your IO ports would be at the front!
A30 has the motherboard rotated 90 degrees. I really think you need to clarify what you are looking for here, do you want the motherboard on the bottom of the case?
Lian li PC-100.
