**MORE CUSTOM & 4GB GTX 680's NOW AVAILABLE!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
KFA2 and Gainward have are now shipping us their super duper variations of the GTX 680. Take note all these cards use 8+6pin power connectors for better OC ability and vastly more powerful coolers yet still extremely quiet:-
KFA2 GeForce GTX 680 EX OC 4096MB GDDR5 PCI-Express Graphics Card @ £549.95 inc VAT
The GeForce® GTX 680 delivers more than just state-of-the-art features and technology. It gives you truly game-changing performance that taps into the powerful next-generation GeForce architecture to redefine smooth, seamless, lifelike gaming.
Immerse yourself in an ultra-smooth gaming experience with exciting new NVIDIA technology advancements like NVIDIA Adaptive Vertical Sync. It’s a fast, seamless way to adjust VSync to your current frame rates for maximum playability.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- KFA2 Own Design GeForce GTX 680
- Innovation Cooler Design giving powerful yet silent cooling
- Overclocking Performance
- Extreme Cool
- Extreme Quiet
- 6-Phase Core PWM,
- 2-PhaseMemory PWM
- Core Clock: 1110MHz (GK104)
- Core Boost Clock: 1176MHz
- Memory: 4096MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2220MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 195 watts at stock speed)
- 1x 8-Pin + 1x 6-Pin PCI-E Connectors required
- Card Dimensions: 270*111.15*38.75 mm
- Warranty: 2 Years
Only £549.95 inc VAT.
ORDER NOW
KFA2 GeForce GTX 680 EX OC 2048MB GDDR5 PCI-Express Graphics Card @ £469.99 inc VAT
Features:-
Specification:-
- Extreme Cool
- Extreme Quiet
- 6-Phase Core PWM,
- 2-PhaseMemory PWM
- Memory: 2048MB GDDR5
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Only £469.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 680 Phantom 4096MB GDDR5 PCI-Express Graphics Card @ £599.99 inc VAT
Gainward GTX 680 Phantom, continue the elegant design of the first generation. The new Phantom II comes with brand new fins design (patent pending) that introduces 1) better thermal performance 2) lower acoustic level 3) more solid structure than previous generation. With this new outstanding innovated thermal design and optimized product design Gainward GTX 680 Phantom delivers an extreme gaming performance for enthusiast gamers.
Gainward Grand-Prix Heat-Pipes Hybrid Cooler, was designed in 6 mm copper-water heat-pipes on a copper base conducting heats away from GPU at highest efficiency, then dissipating onto aluminum heatsinks, which are forced ventilated with Great 8 cm silent PWM fans (GR8).
Great 8 cm silent PWM Fan (GR8) achieves highest cooling performance at much lower temperatures under power saving mode.
Gainward provides 4 ports in one, fulfills universal connectivity to diverse displays in extreme high-definition resolution. Dual View is supported with ease without bothering connector conversion.
Features:-
Specification:-
- Core Clock: 1084MHz (GK104)
- Core Boost Clock: 1150MHz
- Innovative thermal design: Vapour Chamber (Quieter & Cooler than previous generation)
- Gainward 6+2-Phase PWM for improved OC headroom and power stability
- Memory Clock: 6300MHz (Effective)
- Memory Bandwidth: 201.6GB/s
- Shader Clock: 2168MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 215 watts at stock speed)
- 1x 8-Pin PCI-E Connectors & 1x 6-Pin PCI-E Connectors required
- Warranty: 2 Years
Only £599.99 inc VAT.
ORDER NOW
Really liking the look of all these new cards but I really need to get a higher paying job! To be fair to Gibbo people are buying these so make hay while the sun shines. If anyone has tips on how you get lots of disposable income be sure to tell me ;)
I don't think you need a new job, I think they need to lower prices. You know, I can afford this but it's just crazy imo.
Indeed.
"Wait for kepler" did that, now wait for kepler to drop its prices. I could buy it right now if i wanted but will never spend that much on a gfx card.
I'll be interested to see the benchmarks. The 680 tends to out perform the 7970 despite having less RAM, so it would be interesting if the VRAM really is holding it back. I'd be surprised if it performs a lot better, even at higher resolutions but I'll be impressed if it does.
Still, way too expensive.
Indeed.
Same here, pay day and these are little too high almost.
Mind you after that I decided to try and order the normal EVGA one and bam out of stock just as after I saw 1 left. :mad:
Clock speeds on these are higher and they take an 8pin and a 6pin.
Also they only have 2 year warranties...
True, I could afford these in SLI but I know it won't be value for money. On the other hand if I had £5000 a month to spare I wouldn't care. I've got other things on the list like bills, savings, pension etc. I must be getting old!
You know, no one is forcing people to buy cards at £500-£600. If you cant afford it dont buy it, if you can, buy it if you want. I've no idea why people cry about the prices.
These cards have, 2 year warranty, more RAM and higher clock speeds, so what do people really expect when a stock 680 is between £430 to £460? A card with all mentioned above and a none reference cooling system will be priced higher, it really is simple to understand when you think about it eh.
Wait for the Evga GTX 680 F.T.W. which will have 3 year warranty :P
Edit: Lol, "for the win" abreviated is blocked.
o.O
Last week I bought a brand new gigabyte mobo, 2500k and a 6970 for £450, £600 seems crazy for just one piece of kit - Especially seeing as there isn't a lot out there decent enough to push them hugely.
o.O
The main target market would presumably be enthusiasts who will probably have stupid resolutions which need the 4GB VRAM and te power of a 680 (maybe more)
