Corsair Vengeance LP 1.35v
8 Feb 2012
Iv been looking at the above ram for my asrock h67 itx/Ht build due to its low voltage but my board only supports 1333 is this a problem with the Vengeance being 1600? and does anyone know of any other low voltage ram or is this the best?
No it isnt a problem. It will resort to a 1333 setting by default. My mITX PC currently has the same issue with my dual vengeance high profile memory but it works fine.
Is that ram suitable for the mobo ? Might just be the picture but it looks too big
It'll fit in any motherboard which takes DDR3.
The RAM is very low profile:
Edit:
It should also easily run 1333MHz at less than 1.30V, quite possibly a fair bit less.
Before i order one of these does anyone have any other options or are these two the best? they seem pretty good to me but you never know
G.Skill make some 1.35V and 1.25V 1600MHz DDR3 but it's not available from OcUK.
It's much taller as well.
They also make some 1.35V 1333MHz DDR3.
The same sort of height as Kingston HyperX or Corsair XMS3.
