Hi there
Some great deals here for the Easter break on the truly superb Samsung Green memory and were now doing 16GB kits with a further discount applied representing awesome value.
Samsung Green 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual Channel Kit (MV-3V4G3D/US) **EASTER WEEKEND SPECIAL** @ £44.99 inc VAT
These Samsung Green kits are a world first using 30nm technology. This results in lower power usage, extended life and ultra low profile making them compatible with all DDR3 solutions including small form factor.
Boost performance with Samsung genuine PC memory. As the number one memory supplier in the world, Samsung DRAM modules are made with 100% Samsung components. With the 30nm-Class DDR3 1600MHz Extreme Low Voltage UDIMM module from Samsung, you can get faster speed and greater reliability from your computer while consuming less energy. Use Samsung UDIMM DDR3 memory to replace or increase the memory in your desktop or server. This Samsung DDR3 memory module employs 30-nanometer technology and, as a result, uses up to 65 percent less power and is only two-thirds the size of conventional 60-nanometer memory modules. This version of Samsung DDR3 has a 8 GB capacity (2 DRAM modules, each with 4 GB).
The other major advantage of these modules is their overclocking ability, in our own testing we achieved 2400MHz with CAS 11-11-11-28-1T timings with just 1.55v resulting in staggering levels of performance.
Features:-
- Model Name: MV-3V4G3D/US
- Main Board: INTEL/AMD
- System: DESKTOP/SFF
- System Type: DDR3
- M/B Chipset: INTEL P67, Z68, Z77, X79 & AMD Chipsets
- CAS Latency: 11-11-11-28 1N
- Capacity: 8GB (4GBx2)
- Speed: DDR3-1600 (PC3-12800)
- Test Voltage: 1.25-1.55V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 240-pin DIMM Low Profile
- Warranty: Lifetime
Overclocking Features (Not Guaranteed)
- 1600MHz (7-8-8-24 1N) @ 1.40v
- 1866MHz (9-9-9-27 1N) @ 1.40v
- 2000MHz (9-10-10-28 1N) @ 1.45v
- 2133MHz (10-10-10-28 1N) @ 1.45v
- 2400MHz (11-11-11-28 2N) @ 1.50v
- In our own in house testing we were able to achieve all the above clock speeds on an Asus X79 platform with 4x4GB modules (16GB total) SuperPI Stable too, 32M
Was [£49.99] Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
Samsung Green 16GB (4x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual/Quad Channel Kit (MV-3V4G3D/US) **EASTER WEEKEND SPECIAL** @ £83.99 inc VAT
Boost performance with Samsung genuine PC memory. As the number one memory supplier in the world, Samsung DRAM modules are made with 100% Samsung components. With the 30nm-Class DDR3 1600MHz Extreme Low Voltage UDIMM module from Samsung, you can get faster speed and greater reliability from your computer while consuming less energy. Use Samsung UDIMM DDR3 memory to replace or increase the memory in your desktop or server. This Samsung DDR3 memory module employs 30-nanometer technology and, as a result, uses up to 65 percent less power and is only two-thirds the size of conventional 60-nanometer memory modules. This version of Samsung DDR3 has a 16 GB capacity (4 DRAM modules, each with 4 GB), so ideal for al platforms including Intel X79 Quad Channel.
Features:-
- System Type: DDR3
- Capacity: 16GB (4GBx4)
Was [£99.99] Inc. VAT
Only £83.99 inc VAT.
ORDER NOW
Crucial Ballistix Tactical Tracer 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLTCP4G3D1608DT2TXRGCEU) (Red & Green Activity LEDs) **WORLD FIRST** @ £44.99 inc VAT
Crucial is all about the win—and our complete line of Crucial Ballistix performance memory is proof of that commitment. Whether you're a casual enthusiast or hardcore gamer, the expanded Ballistix line delivers a choice of performance memory that meets your need for speed.
Are you ready to shed some light on your computer?
Play with even more bling — customized by you. The Ballistix Smart Tracer features activity-indicating LEDs on the top edge and ground-effect LEDs along the bottom.
These Smart Tracer modules are available in either Blue/Orange or Red/Green LED color combinations that you can manipulate in real time, switching up the color options. In addition, select from four different LED patterns, adjust brightness, or turn the LEDs on/off. All of this can be done on-the-fly! Turn on the lights — and turn up your performance — with Ballistix Smart Tracer memory.
Add to it the downloadable MOD utility, and you get the real-time temperature monitoring — and more!
Features:-
- Black PCB
- Black high performance CAMO ALU heatspreaders
- Ultimate performance memory
- Activity LED's (RED / GREEN)
- Temperature Probe
- Crucial MOD software compatible
- Each two module set is tested at 1600MHz
- Tactical heat spreader for performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 8-8-8-24 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
- Bulldozer compatible
Was [£53.99] Inc. VAT
ORDER NOW
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) @ £35.99 inc VAT
Kingston's KHX1600C9D3X2K2/8GX is a kit of two 512M x 64-bit 4GB DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 8GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
Model Name: KHX1600C9D3X2K2/8GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
CAS Latency: 9-9-9-27 2N
Test Voltage: 1.50-1.65V
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Was [£39.95] Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
Some cracking deals there to spank the wallets with.
Features:-
- System Type: DDR3
ORDER NOW
Features:-
- System Type: DDR3
ORDER NOW
Features:-
- Black PCB
- Temperature Probe
- Lifetime Warranty
ORDER NOW
Main Board: INTEL
System: DESKTOP
System Type: DDR3
Type: 240-pin DIMM
Black PCB
Warranty: Lifetime
ORDER NOW
