7 Apr 2012 at 22:12 #1 413x 413x Caporegime Joined 13 Jan 2010 Posts 33,453 Location Llaneirwg Not sure what is happening, when I tell the tv to convert my 2d game into 3d it does it for a while then flicks back to 2d, anyone provide an answer? Can't track it down using Google
7 Apr 2012 at 23:07 #2 insane200 insane200 Soldato Joined 10 Aug 2006 Posts 6,791 Nothing springs to mind, does the screen resolution change at all when this happens ? like cut scenes.
8 Apr 2012 at 00:32 #3 413x 413x Caporegime OP Joined 13 Jan 2010 Posts 33,453 Location Llaneirwg insane200 said: Nothing springs to mind, does the screen resolution change at all when this happens ? like cut scenes. Click to expand... It did once, last time I used the feature it was fine from the pc using a game
8 Apr 2012 at 08:42 #4 insane200 insane200 Soldato Joined 10 Aug 2006 Posts 6,791 what source are you using when it happens, pc/ps3/xbox ?
8 Apr 2012 at 08:55 #5 413x 413x Caporegime OP Joined 13 Jan 2010 Posts 33,453 Location Llaneirwg Split screen forza 4 on xbox via hdmi Was it too much info for the tv to process?
8 Apr 2012 at 11:01 #6 insane200 insane200 Soldato Joined 10 Aug 2006 Posts 6,791 Should be fine, Have you tried another socket or hdmi lead ! could be a signal loss causing it to revert back to 2d.
8 Apr 2012 at 11:38 #7 413x 413x Caporegime OP Joined 13 Jan 2010 Posts 33,453 Location Llaneirwg dont think its the cable, worked fine with images from the pc. its also in the same socket i used with the pc, bit confused tbh
