Need a new PSU
You don't need anywhere near 1000W for sli 680. SLI 480, maybe.
FYI, I use 450W peak with my rig.
750W or 850W, and they wont even stress.
But could a AX850 run higher powered GTX cards, what if the GTX 780 was 250W. Then what if I SLIed and OCed two GTX 780 with high end liquid cooling with a OCed Haswell-E?
Newer cards are (majority of the time, fermi the exception) more energy efficient.
High end liquid cooling doesn't take up much power, maybe max 100w for pumps and fans and that's extremely high (talking about maybe a setup in a MM case with 12-16 fans and 2-3 pumps or something).
A decent 750W would be able to run future components.
I don't think you know how much power an actual high end system draws at idle or full load.
PS - If you're going on 'what ifs?' then what if the next generation card is 400w? and the next generation cpu is 150w? and so on. With what if might as well go for a 1.2KW PSU just to satisfy what ifs, and maybe then that's not enough :)
The AX850 can pretty much run any 2 card system that only requires 1 ATX 4+4 Pin CPU (8-Pin EPS 12V connector).
It has 2 8-Pin EPS 12V connectors, but you can't run 2 high end cards using 4 PCI-E at the same time. This won't be a problem for most people.
So you can't run two decent cards in SLI\CF, like for example two 4870s?
Yes you can. What he's saying is that some motherboards need 2 8-pin CPU power plugs. Only very few. But you can't use two of these and 4 PCIe at the same time.
So with a more normal motherboard, 1 CPU power socket and 4 PCIe connectors is not a problem :)
But 'what if' you need to use those EPS12V connectors? :D
... I don't think he will :p
If you really want fully modular, and want to spend £200 then the 1000W XFX would be my recommendation.
My current plan is to maybe get an Ivy Bridge 2700k in June, then to give\sell that CPU and motherboard to someone I know and get a Haswell-E.
Those 'what ifs' are very difficult to predict :p
Get the XFX 1000W like beejjacobs mentioned that way you can accommodate all types of future hardware.
It'll be not as efficient in power terms until you get a really loaded rig but if you're spending that much on a system then I guess the extra in the electricity bill wont matter.
