 - 17 Apr 2006
 - 3rd rock...
Ive been putting this off for a while as I was finding it tough to find a card that would fit the space in my case. I have a Powercolor HD5850 I got from OcUK thats 265mm long and its still a squeeze. Been wanting to upgrade but the new cards are so long
Finally went on a mission and I found this and a quick check on Sapphires site gives it a length of 260mm...win!
Sapphire HD 7870 2048MB GDDR5 PCI-Express
£274.99 (£285.79 delivered)
So, it will fit
 But whats your take on this card OcUk? A good replacement for HD5850? I dont wanna break the £300 mark. Thanks for any thoughts on this card.
I wish all the cards dimensions were listed on OcUK
 Its shown for some cards but not for others. I think its really handy to know the dimensions.
Thanx!
Core Clock: 1000MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Processing Cores: 1280
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 2 Years
So, it will fit
 But whats your take on this card OcUk? A good replacement for HD5850? I dont wanna break the £300 mark. Thanks for any thoughts on this card.I wish all the cards dimensions were listed on OcUK
 Its shown for some cards but not for others. I think its really handy to know the dimensions. Thanx!
 Look up some settings and make small increases. With all the info out there is isn't hard to get a decent OC just time consuming especially if you don't do a lot of it like myself.
