Solar Hot water Heater, anyone got one?
18 Oct 2002
UK
Wondering if anyone here has a solar hot water heating system? I know a few people here have PV panels, but for bang for your buck and energy saving, doesn't going for the hot water route provide a better deal?
Traditionally (and cheaply) they can look rather large when installed, so probably have a hard time sticking them just anywhere on a house (planning permission) but you can locate the tank anywhere you want (in loft/basement and pump the water around)
Wondering what people think of them? Would be great to incorporate the system combining underfloor heating too.
They don't need to be big, the tank at the top can go inside the loft.
Is that the evacuated tube ones? I can't see the other types working to well in the uk.
Surely for heating purposes, you'd need it in the winter when the sun isn't at it's warmest for heating them?
It's not purly for heating. It's a heater ie. It heats the water. You can then use it directly or further heated by conventional emerision heaters/boilers. Evacuated tube ones means they are not affected by outside temp due to the vacuum and can still produce warm water in winter, meaning less heating by the boiler.
Did mention that in the post ;)
I know there are various styles, either tubes or panels, and then again differences between those types also. I don't know much about the tech, other than it sticks to the KISS concept, is cheap(ish compared to PV) and will provide a much longer useful lifespan than PV also. The effect will be less in winter of course, but every kW/litre of gas/oil saved from the main heating unit is a bonus, even in cold cold winter it'll still give a boost to the system.
/edit, aha, get the vacuum part now, didn't think much about it before but yes, greater efficiency regardless of outside temp.
If your going floor heating. An air heat exchange unit would be better. Idea for low temp loops which is what you want for UFH, co Stanton low temp, rather than high temp short bursts which is what radiators mainly do.
Ah okays. I only knew the basic of solar panels
One type heats water the other type produces leccy! :P
You don't need planning permission for panels unless youre in a listed area.
All parts must be less than 200mm above the tiles then it's permitted development ie no planning permission reqd.
You aren't going to get any meaningful heat for the underfloor when you most need it however they can be useful for helping with the hot water in summer, might go for it myself strictly DIY though.
I already have PV panels, whoever suggested they dont last as long as the evacuated tube/panel hot water system is mis-informed. PV is guaranteed to perform at 80% of new capacity after 20 years :)
You mean RHI (renewable heat incentive)
It's been delayed more times than british rail LOL. You'd need it installed by MCS installer if and when it does come in, would make any fuel savings pointless due to the price of the certified install I suspect. Also they'd insist on meeting catD isulation standards same as FIT's for PV does now.
Ron3003, what did your PV panels cost you and how effective are they?
We've just moved house, and now have a south facing aspect that would be ideal for panels, but I've been considering the water heating system in the OP, primarily down to cost
You aren't going to get any meaningful heat for the underfloor when you most need it however they can be useful for helping with the hot water in summer.
Got any links to studys in that? I'm trying to find some reviews/websites with detail but aren't finding anything decent to ruminate.
From what I understood it'd help (and go a long way towards helping in winter too not just a little) and in summer you'd have hot water coming out of your ears! Obviously family/panel size dependant though but within reason for a small family, south facing panel.
I have a water heating panel, it heats a tank of water before it is used by the boiler for a variety of purposes. I have no idea if it is any good :confused:
I had solar water heating... it has lost all its glycol and I have not replaced it yet as I cannot work out where it went..
When it was working it was awesome. I have two tanks in the airing cupboard. In summer I always had hot water with no need to use the gas boiler.
In winter it gets the water a good portion of the way there with the boiler doing the last part.
If I could find a competent solar guy I would get it fixed. But the last guy I had come over was just going to refill the glycol with no real explanation as to where it went (it is an internally venting system and the pot was empty).
Surely it must be a sealed system so it just needs filling with a coloured liquid and then look for the leak?
