c sharp text file application
10 Apr 2012
hi everyone, i have created a text file windows application which reads in 10 records, i was wondering how to read the records one by one into a textbox when a button is pressed, and also when the edit or save button is pressed, this will take the user to a 2nd form for saving and editing the text file which has been loaded, i have already created some strings. any help would be much appreciated
class Program
private struct person //creates new person structure//
public int list;
public string lastName; record
public string firstName;
public string middlename;
public DateTime dob; //datetime class is used for date of birth
public string gender;
public string toString()
26 Apr 2009
class Program
public int list;
PHP:
        try
            // Create an instance of StreamReader to read from a file.
            // The using statement also closes the StreamReader.
            using (StreamReader sr = new StreamReader("TestFile.txt"))
                String line;
                // Read and display lines from the file until the end of
                // the file is reached.
                while ((line = sr.ReadLine()) != null)
                       textBox1.Text = textBox1.Text + "\n" + line;
        catch (Exception e)
            // Let the user know what went wrong.
            Console.WriteLine("The file could not be read:");
            Console.WriteLine(e.Message);
You want to put that code into the button you want the event to be actioned from
