Good non metallic rigid mouse mat?
19 May 2004
It's cold in Scotland (I know, big shock) and my metal mouse mat is actually getting so cold its making my hand cramp so I am looking for a rigid mouse mat to use that's plastic based because my metal one is acting like a heatsink.
Any suggestions?
The boogie is neither rigid nor suitable for a laptop :/ The problem is glass transmits heat really well, I have an old icemat and it gets freezing too.
It needs to be:
A) Rigid
B) Plastic based
Cheers guys.
Hmz, considering the vespular (I have the pro (basically white) exact mat atm, so its a plastic version. Or I could go with the scarab and maybe use it in the case if I need it particularly non flexible....
Please read what I said, glass suffers the same issue as metal. As much as I love the surface of both, it's actually painful to use either.
I swear some people just see 'Mousemat' in a thread name and copy/paste 'Boogiebug' into it. He asked for a RIGID mat and the Boogie is clearly not rigid. You guys using an IceMat are missing out on modern tech. I used an IceMat for 4 years before Steelseries acquired the company and began producing them under a different name. I too believed it was the best around, until I tried my friends cloth Qck. Promptly bought one and havent looked back.
If you're set on a solid plastic mat (personally I don't understand why anyone would be in 2012, with the evolution of cloth mats) then look into the Razer Scarab or Steelseries 4/9HD. Both will exceed your expectations if you're coming from an IceMat.
