Bitfenix Shinobi XL Review
Thanks kul1, That's fair enough regards the connections, at least I know these won't rattle or fall apart easy :D
I have ordere my other parts which should be with later this week.
Thank you CaptainRAVE :)
Quick update:
Parts arrived today and currently leak testing, need to do some cables tidying and install the Blu-Ray drive.
I will be hoping to post some updated pics tomorrow :)
Looks good RJC, btw. Is the Lamptron fan controller a good fit? My current zalman zm mfc1+ has died, so im after a new fan controller. Ive swapped out the big front fan for a few 120's and theyre a bit loud for my liking.
Sorry for the late reply setter.
Yes the controller is a good fit, you need to install the the controller with the front attached, if you want to remove the front cover you will need to remove the controller first.
I am thinking of changing the front to two 120mm fans.
I have to admit I am seriously considering getting this case for my IB system. Looks great and seems to have good functionality as well!
Thanks for that, does look very nice in the case, a lot better than my zalman with its wonky pink led's.
Ive got a mismatched pair of 120's in the front, one alpenfohn and one silverstone AP1221. Both 1500 rpm, but the silverstone pushes more air. Got two but sadly one was doa. So waiting on rma replacement.
Get one!! On special offer on TWO :p
http://www.overclockers.co.uk/showproduct.php?prodid=CA-020-BX
I had the Zalman FSC which had weird colour wonky LEDS :eek:, can't fault my current one :)
Hopefully the RMA won't to long :)
Thanks GeezerButler :)
Yeah, the led's were meant to change from red to blue as you dialled up the voltage. Mine were always a girly shade of pink, now a few of the led's have just went out.
