- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) - OEM @ £41.99 inc VAT
AMD Athlon II Dual-Core processors put the power of dual-core technology on the desktop. Dual-core processors contain two processing cores, residing on one chip, that perform calculations on two streams of data to increase efficiency and speed while running multiple programs and the new generation of multi-threaded software. AMD Athlon II Dual-Core processors deliver TRUE multi-tasking, allowing users to switch from one program to another without always pausing for the computer to catch up and reducing annoying processing pauses.
- Dual-core Technology
- 3.00Ghz clock speed (AM3 Socket)
- Multiplier unlocked
- 2.0MB L2 Cache
- Cool & Quiet Technology for Energy Efficiency
- Enhanced Virus Protection
- 64-bit Technology
- Hyper Transport Technology
- Virtualization technology
- 1yr Warranty
Was £49.99 Inc. VAT
Only £41.99 inc VAT.
ORDER NOW
AMD Bulldozer FX-8 Eight Core 8150 Black Edition 3.60Ghz (Socket AM3+) Processor - Retail with FREE Deus Ex PC Game @ £185.99 inc VAT
We call it the new AMD FX 8-Core Processor Black Edition and it's unlocked for your overclocking pleasure.1 Experience unmatched multitasking and pure core performance with the industry's first 32nm 8-core desktop processor featuring the all-new "Bulldozer" architecture. Get the speed you crave with AMD Turbo CORE Technology to push your core frequencies to the limit when you need it most. Go beyond the limits of maximum speed with easy-to-use AMD OverDrive™ and AMD Catalyst Control Center™ software suites. But the best part of all? You'll get all this impressive performance at an unbelievable price. You'll be asking yourself "what competition?" in no time.
- Multiplier Unlocked
- Eight Core Technology
- 3.60GHz Clock Speed
- 4.20GHz Turbo Clock Speed
- 5.2 GT/s System Bus
- AM3+ Socket
- 8MB L2 Cache
- 8MB L3 Cache
- 64-Bit Technology
- TDP: 125W
- Voltage: 0.9375v - 1.4125v
- 32nm technology
- Integrated memory controller upto 29.8GB/sec
- Support upto 1866MHz DDR3
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
- Supplied with FREE Deus-Ex PC Game (Subject to availability)
Was £199.99 Inc. VAT
Only £185.99 inc VAT.
ORDER NOW
Corsair Dominator 16GB (4x4GB) PC3-14900C9 1866MHz Dual/Quad Channel Kit (CMP16GX3M4X1866C9) **SPECIAL** @ £119.99 inc VAT
Dominator memory supports the Intel XMP (Extreme Memory Profile) standard, and each module is individually factory-programmed with an XMP profile indicating supported timing, frequency and voltages. Just enable XMP on your compatible motherboard and you’ll automatically get optimized memory overclocking without having to deal with multiple BIOS settings. Of course, if you’re an experienced overclocker, you can always adjust the settings on your own to push for even higher overclocking performance.
State-of-the-art cooling efficiency is essential for high-performance memory. Our DHX+ technology uses specially designed, high-quality heatsinks and a custom-designed PCB that cools the front and rear of the DRAM chips as well as the printed circuit board itself.
Your performance investment is protected. All of our memory products are backed by a limited lifetime warranty.
Features:-
- Ultra-high performance 16GB (4x 4GB) Domintaor® quad kit with Intel XMP 1.3 profile
- 16GB total capacity provides ample headroom for the most demanding user
- Outrageously fast 1866MHz performance.
- Ultra-low 9-10-9-27 latency
- Intel XMP (Extreme Memory Profile) support
- Limited Lifetime Warranty
- Compatible with Intel X79, Z68 and P67 platforms
- Speed: 1866MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
- Pin Voltage: 1.50-1.60V
Was £139.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Team Xtreem 16GB (4x4GB) DDR3 PC3-17000C9 2133MHz Dual/Quad Channel Kit (TXD316G2133HC9NQC-L) @ £119.99 inc VAT
Beyond than the shock of overclocking, Xtreem LV is joined by a new and powerful member, Xtreem DDR3 2133. Supported by IMC memory profile, Xtreem DDR3 2133 boasts outstanding efficiency and satisfies the 1.50V regulation to prevent high voltage from causing CPU damage. For the best quality, we only use original granules and with the exclusive granule screening technology, we insure the quality and stability of the materials. At the same time, we keep the strictest standards in quality control right from the compatibility test to pre-delivery test. Our quality is highly trusted by users. In addition, the memory module carries the unique X-shape heat radiation chipset and the high-coefficient conductive gel grabs the granules tightly to maximize the overall heat radiation efficiency and brings the Xtreem series the unique cool touch under extreme speed.
- Fully compatible with Intel P67, Z68, X58, x79-based DDR3 motherboards
- XMP Ready
- High frequency and Low latency
- RoHS Compliant
- Larger capacity:4 GB Kit (2GBx2), 8 GB Kit (4GBx2), 16 GB Kit (4GBx4)
- Equipped super thermal conduction heat spreader
- 100% Tested and Verified
- Lifetime Warranty
- Data transfer bandwidth: 17,000 MB/Sec (PC3 17,000)
- CL-value: 9-11-11-28
- Working voltage: 1.50-1.60V
Was £131.99 Inc. VAT
ORDER NOW
Kingston HyperX Genesis 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel (KHX1600C9D3K3/6GX) @ £29.99 inc VAT
HyperX DDR3 memory; the latest generation of DDR memory technology. Like all Kingston HyperX products, DDR3 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. DDR3 memory offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR2. HyperX DDR3 modules are available in single, dual and triple-channel memory kits.
Features:-
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL X58
CAS Latency: 9-9-9-27 2N
Capacity: 6GB (2GBx3)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.60-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Warranty: Lifetime
Was £35.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (CMZ8GX3M2A1866C9) @ £52.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1866MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1866MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1866MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-10-9-27 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Was £55.99 Inc. VAT
Only £52.99 inc VAT.
ORDER NOW
OcUK Value 8GB (2x4GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel Kit @ £23.99 inc VAT
OcUk Value Series Memory is designed to optimized the high performance DIMMs for reliability in order to ensure your system does not fail you resulting in great performance, compatibility and reliability.
Features:-
- Cas latency: 9-9-9-24-2N
- Capacity: 8GB (4GBx2)
- Speed: DDR3-1333 (PC3 10666)
- Test voltage: 1.5 Volts
- Type: 240-pin DIMM
- Warranty: Lifetime
Was £29.99 Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
OcUK Value 8GB (1x8GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Single Channel Module @ £35.99 inc VAT
Features:-
- Capacity: 4GB (4GBx1)
Was £37.99 Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
Sapphire HD 7970 OC 3072MB GDDR5 PCI-Express Graphics Card @ £419.99 inc VAT
The SAPPHIRE HD 7970 OC Edition features SAPPHIRE’s new dual-extractor technology - Dual-X - a highly efficient multi-heatpipe cooler with dual fans providing quiet and very cool operation during normal operating conditions, and superb cooling performance even under extreme load. The HD 7970 from AMD is the most powerful single chip GPU ever built - it has a new internal structure with 32 compute units and a total of 2048 Stream processors. The SAPPHIRE HD 7970 OC Edition ships with a raised core clock speed of 950MHz, and 1425MHz for the memory. Its Dual BIOS switch allows users to select the higher performance settings of 1GHz core and 1450MHz memory, making the fastest card in its class. This setting also uses a more aggressive fan profile and raises the limits for maximum overclocking.
Features:-
- Fastest single GPU graphics card on the planet
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 1000MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5800MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 6-pin
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- 3yr Warranty
Was £429.95 Inc. VAT
Only £419.99 inc VAT.
ORDER NOW
HIS HD 7950 3072MB GDDR5 PCI-Express Graphics Card @ £323.99 inc VAT
The World's first 28nm GPU. The revolutionary new GCN Architecture. Ready for DirectX 11.1. PCI Express 3.0. The AMD Radeon™ HD 7950 is your personal checklist for ground-breaking technology. The next generation of AMD Eyefinity technology is here, featuring all-new support for stereo 3D, universal bezel compensation and brand new display configurations. Face it: the best just got better. Armed with the new PCI Express 3.0 standard, multi-GPU configurations with AMD CrossFire™ technology are just another way to obliterate the competition with the revolutionary AMD Radeon™ HD 7950. Leave no performance behind. Get higher clocks and faster gaming with AMD PowerTune technology on AMD Radeon™ HD 7950 Graphics. Fold and mine faster than ever with AMD App Acceleration powered by the unprecedented 28nm GCN Architecture. The market isn't ready for 4K video, but Radeon™ is. With full support for 3GHz HDMI 1.4a and DisplayPort 1.2 HBR2, the AMD Radeon™ HD 7950 is set for Quad HD.
- Core Clock: 800MHz
- Memory: 3072MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 1792
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 2 Years
Was £329.99 Inc. VAT
Only £323.99 inc VAT.
ORDER NOW
VTX3D HD 7850 2048MB GDDR5 PCI-Express Graphics Card with FREE Dirt3 PC Game @ £182.39 inc VAT
With continued demand for increased graphics horsepower to support more visually intensive games, the AMD Radeon HD 7800 Series is set to power the next generation of games and applications. And for those looking to upgrade to a next-generation graphics card, the AMD Radeon HD 7800 Series is the ideal choice.
- Core Clock: 860MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1024
- HDCP Capable
- DirectX 11.1 Support
- OpenGL 4.2 Support
- ATI Avivo HD
- Warranty: 2 Years
- Supplied with FREE Dirt3 PC Game download voucher
Was £194.99 Inc. VAT
Only £182.39 inc VAT.
ORDER NOW
Sapphire HD 7870 2048MB GDDR5 PCI-Express Graphics Card @ £257.99 inc VAT
The new SAPPHIRE HD 7800 series of graphics cards is based on the third family of GPU’s from AMD built in its new 28nm process and featuring the highly acclaimed GCN graphics processing architecture.
The Sapphire HD 7870 GHz Edition is equipped with 2GB of the latest GDDR5 memory clocked at 1200MHz (4.8Gb/s effective) with the new dual-extractor technology - Dual-X - a highly efficient multi-heatpipe cooler with dual fans providing quiet and very cool operation during normal operating conditions, and superb cooling performance even under extreme load.
Features:-
- Core Clock: 1000MHz
- Processing Cores: 1280
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI Avivo HD
- Warranty: 2 Years
Was £274.99 Inc. VAT
Only £257.99 inc VAT.
ORDER NOW
Asus GeForce GTX 580 DirectCU II 1536MB GDDR5 PCI-Express Graphics Card @ £323.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX580 DCII to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 782MHz (reference 772MHz), allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX580 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX580 DCII/2DIS/1536MD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Voltage Tweak Technology
- Super Alloy Power: Provides 15% performance increase, 2.5 times longer product lifespan and 350C cooler operation.
- Gamer OSD: Real-time overclocking, benchmarking and video capturing in any PC game!
- Splendid: Watching movies on PC is as good as on Top-of-the-line consumer television
- Core Clock: 782MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Processing Cores: 512
- Shader Clock: 1544MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
- The card size is 10.24" x 4.84" x 1.58" inch
Was £339.95 Inc. VAT
ORDER NOW
Gainward GeForce GTX 580 "Phantom" 3072MB GDDR5 PCI-Express Graphics Card @ £341.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Instead of fans on its obverse side blowing air onto the PCB, there are three fans on its reverse side, drawing air from the aluminum fin array, and onto the PCB. The PCB also seems to be a non-reference design.
Features:-
- Core Clock: 783MHz (Fermi GF110)
- Memory Clock: 4020MHz (Effective)
- Shader Clock: 1566MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was £349.99 Inc. VAT
Only £341.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 570 Phantom 1280MB GDDR5 PCI-Express Graphics Card @ £227.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
Features:-
- Core Clock: 750MHz
- Memory: 1280MB GDDR5
- Memory Clock: 3900MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1500MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 years
Was £239.99 Inc. VAT
Only £227.99 inc VAT.
ORDER NOW
Asus GeForce GTX 560Ti DirectCU II TOP 1024MB GDDR5 PCI-Express Graphics Card @ £173.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX560 Ti DCII TOP to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 900MHz, allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX560 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX560 Ti DCII TOP/2DI/1GD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Core Clock: 900MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4200MHz (Effective)
- Processing Cores: 384
- Shader Clock: 1800MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £179.99 Inc. VAT
Only £173.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 560Ti "Phantom" 1024MB GDDR5 PCI-Express Graphics Card @ £167.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560Ti - arm yourself for battle.
Features:-
- Core Clock: 835MHz
- Memory Clock: 4050MHz (Effective)
- Shader Clock: 1670MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £169.99 Inc. VAT
Only £167.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 560Ti "Phantom" 2048MB GDDR5 PCI-Express Graphics Card @ £215.99 inc VAT
Features:-
- Core Clock: 822MHz
- Shader Clock: 1644MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £219.95 Inc. VAT
Only £215.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 560 2048MB GDDR5 PCI-Express Graphics Card @ £161.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560 - arm yourself for battle.
Features:-
- Microsoft DirectX 11 support
- DirectCompute 5.0 and OpenCL support
- One dual-link DVI-I?Display Port and one mini-HDMI 1.4a connectors
- Dual-link HDCP Capable
- Core Clock: 810MHz
- Processing Cores: 336
- Shader Clock: 1620MHz
- SLI Ready
- HDCP Capable
- OpenGL 4.1 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 years
Was £167.99 Inc. VAT
Only £161.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 480 1536MB GDDR5 PCI-Express Graphics Card (015-P3-1480-KR) @ £179.99 inc VAT
Next generation gaming has arrived. Nvidia GeForce GTX 480 gives your games an adrenaline shot with the world's fastest performance and futuristic, visually stunning graphics. Experience heartpounding, cinematic visuals on your favorite games with the combined power of DirectX 11, CUDA and Nvidia PhysX technologies. And expand your visual real estate across three HD displays in jawdropping stereoscopic 3D for the ultimate in immersive gaming. Nvidia GeForce GTX 480: pure adrenaline meets visual bliss.
- EVGA Precision Tuning Utility
- Core Clock: 700MHz
- Memory Clock: 3696MHz (Effective)
- Shader Clock: 1401MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.3a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- OpenGL 3.1 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 years standard warranty
Was £184.99 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 460 Superclocked FTW 1024MB GDDR5 PCI-Express Graphics Card (01G-P3-1363-KR) @ £115.19 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Core Clock: 867MHz
- Memory Interface: 192-Bit
- Shader Clock: 1734MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years (If registered within 30 days of purchase)
Was £119.99 Inc. VAT
Only £115.19 inc VAT.
ORDER NOW
Asus VE228H 22" Widescreen LED Multimedia Monitor - Black @ £119.99 inc VAT
Full HD 1080p Visual Enjoyment Together with HDMI Interface. Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 5 preset video modes (Scenery, Theater, Game, Night View, and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 21.5"(54.6cm) Wide Screen
- True Resolution : 1920x1080
- Pixel Pitch : 0.248mm
- Brightness(Max) : 250 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 10000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 5ms
- Display Colors : 16.7M
- Video Feature SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 5 Modes
- Skin-Tone Selection : 3 Modes
- Color Temperature Selection : 5 Modes
- HDCP support
- Audio Features Stereo Speakers : 1W x 2 Stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI ,D-Sub,DVI-D
- PC Audio Input : 3.5mm Mini-Jack
- AV Audio Input : HDMI 1.3
- Earphone jack : 3.5mm Mini-Jack
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Power Consumption Power Consumption < 30 W
- Power Saving Mode < 1 W
- Mechanical Design Chassis Colors : Black
- Tilt : +20°~-5°
- VESA Wall Mounting : 100x100mm
- Security Kensington lock
- Dimensions Phys.Dimension(WxHxD): 512.84x385.96x201mm
- Box Dimension(WxHxD): 576x468x148mm
- Weight Net Weight (Esti.): 4.1 kg
- Gross Weight (Esti.): 6.1 kg
- Accessories DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Regulation Approval Energy Star 5.0, CEL, UL/cUL, CB, CE, EuP, FCC, CCC, BSMI, Gost-R, C-Tick, VCCI, PSB, J-MOSS, WEEE, Windows Vista & Windows 7 WHQL
Was £124.99 Inc. VAT
ORDER NOW
BenQ G2222HDL 21.5" Widescreen LED Monitor - Black @ £99.98 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2222HDL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 504.6mm x 392.9mm x 175.0mm
- Weight: 3.8kg
- Warranty: 2 Years On-Site
Was £109.99 Inc. VAT
Only £99.98 inc VAT.
ORDER NOW
BenQ RL2240H 22" Widescreen LED Monitor - White @ £107.99 inc VAT
The RL2240H is a professional gaming monitor suited for RTS game play. Co-designed with the renowned StarCraft II team, StarTale, this 21.5” LED backlight monitor is packed with the latest features: the Black eQualizer, RTS mode, Display mode, Smart Scaling, 2ms GTG, HDMI and 12M:1 dynamic contrast ratio.
Built to set the benchmark for RTS gaming monitors, the RL2240H is a true testament to the belief that 'gaming is in the details'. Each and every feature has been meticulously thought out and created together with the renowned StarCraft II team, StarTale, to provide RTS gamers with vital visibility and command to take their performance to new heights.
The collaboration successfully brought together prominent players from StarTale and tapped into their wealth of knowledge and insights to create the ultimate gaming monitor that can handle real-time strategy games. Professional gamers like Rainbow, July, Ace, Bomber, Squirtle and Virus provided BenQ with insider perspectives on details that were essential to winning a game. The recent achievements from individual StarTale gamers include winning Clash of the Houses, IEM World Championship, Intel Extreme Masters Season 5 and GSTL league play.
The Black eQualizer is an exclusive feature that meets the demands of gamers when it comes to unprecedented level of control and visibility. Via finely designed color engine technology, dark scenes are brightened without over-exposing white levels, allowing gamers to acquire critical combat details and information and react quickly. Don’t let poor visibility and judgment cost you the game.
During product development and testing stages, BenQ's product team and the StarTale players exchanged several visits to fine-tune the display performance of the RL2240H for better accessibility and comfort. What they came up with is the preset RTS mode that automatically adjusts your monitor calibrations accordingly for optimum RTS gaming. This out-of-the-box setting allows you to see your enemies more visibly among the distractions and darkened areas. See what the professional gamers see and get the competitive edge you need with optimized color and contrast exposures. The exclusive preset RTS Mode will be your ultimate secret weapon.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your liking and to simulate any in-game experience. Interchange instantly between four different screen sizes from 17", 19" and 19"W to 21.5" using the Display Mode. Or take advantage of the Smart Scaling feature and enjoy the flexibility to freely scale the screen content to any custom size. You can certainly use the two features together to get the best possible view for any application or game.
Fast response time of 2ms GTG means speed without the smear. Fast-moving action and dramatic transitions will be rendered smoothly - without smearing or ghosting. Control your gaming destiny and don’t leave it in the hands of sluggish display.
The RL2240H comes in a sleek white housing that was favored by StarTale_July. Be the envy of all the other gamers as you sport the RL2240H with fluid lines and distinct curves.
Features:-
- Screen Size: 21.5”W
- Aspect Ratio: 16:9
- Resolution (max.): 1920x1080
- Brightness ( typ.): 250 cd/m2
- Contrast ( typ. ): 1000:1
- DCR (Dynamic Contrast Ratio) (typ.): 12M:1
- Viewing Angle (L/R;U/D) (CR>=10): 170/160
- Response Time(Tr+Tf) typ: 2ms GTG
- D-sub/DVI/HDMI/Headphone Jack
- 2yr Warranty
Was £113.99 Inc. VAT
Only £107.99 inc VAT.
ORDER NOW
IIyama Prolite E2273HDS 22" Widescreen LED Monitor - Black @ £119.99 inc VAT
The ProLite E2273HDS is a LED-backlit monitor. It is a full 1920x1080 high definition 22” display that features all the benefits this technology affords. Extremely slim and stylish in design, it has a narrow bezel and is finished in the latest glossy-black. The high specifications of the monitor include 5,000,000:1 ACR, fast 2ms response for excellent sharpness in high definition video and triple input connectivity (including HDMI). Power consumption is only 21W typical usage and 0,5W in standby.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
With true 1920 x 1080p resolution your LCD is ready to display any high definition images. It also offers you much more viewable area than a standard LCD with 1280 x 1024 resolution.
Contrast Ratio is a measurement of this difference between the blackest black and the whitest white your LCD can display. Advanced Contrast Ratio is a feature that automatically adjusts the contrast and brightness based on the darkness of the image. The higher the ratio, the better your screen will look when you have the lights off in a room.
This LED monitor is equipped with two high quality stereo speakers. HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
Features:-
- LED Backlit
- Brightness: 300cd/m²
- Response Time: 2ms
- Inputs: 1 x Analogue, 1 x DVD-D, & 1 x HDMI
- Dimensions: 268.1 x 476.6 mm; 10.6" x 18.8"
- Weight: 2.9kg
- Warranty: 3 Years On-Site
Was £129.95 Inc. VAT
ORDER NOW
BenQ G2420HDBL 24" Widescreen LED Monitor - Black @ £143.99 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2420HDBL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 24" Widescreen
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
- Weight: 4.4kg
Was £149.99 Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
Asus VG278H 27" TRUE 120Hz 3D Widescreen LED Monitor with NVIDIA 3D Vision 2.0 Glasses - Black @ £479.99 inc VAT
Enter an immersive 3D full HD 1080p world of games and movies with the VG278H. Through the use of the world's first NVIDIA® 3D Vision™ 2 glasses technology, it instantly takes you into another dimension - transforming all your gaming experiences and movies to 3D. With its new technology, it delivers twice sharper 3D images than conventional 3D technology. There are more than five hundreds popular PC game titles* currently compatible with the NVIDIA® 3D Vision™ Kit.
With the latest NVIDIA® 3D LightBoost™ Technology, enjoy twice the brightness of conventional 3D technology in 3D mode with zero increase in total energy consumption. It's perfect for dark-color games such as Metro 2033 and Batman: Arkham City. Additionally, the redesigned glasses bundled with NVIDIA® 3D LightBoost™ Technology features a 20-percent larger viewing lens, a light blocking visor for comfortable viewing and more comfortable - gamer-inspired design.
Supported by Trace Free II Technology, the VG278H is able to double the refresh rate to 120 frames per second, which is twice faster than generic LCD monitors, delivering ultra-smooth 3D visuals. Moreover, the response time is now reduced to 2ms to eliminate tracing and ensure crisp and clear video playback.
The VG278H reduces LCD charging time to further prevent mura, ghosting, and bright-line effects, and delivers clear motion scenes during 3D gaming and movie watching. Splendid™ Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters accordingly to ensure the color accuracy and image fidelity. Six preset video modes (Scenery, Theater, Game, Night View, sRGB, and Standard) can be selected via a hotkey. he VG278H is specially designed with swivel, tilt and height adjustment to suit your preferred viewing angles in 3D gaming and movie watching. The angle-adjustable 3D emitter optimizes 3D for every scenario; simply switch between three IR signal coverage areas via OSD menu and aim the angle-adjustable 3D emitter at shutter glasses for maximum 3D reception. Display stereoscopic 3D via Blu-ray Disc players or game consoles through HDMI 1.4 output. The VG278H offers high compatibility with any media devices with HDMI 1.4, dual-link DVI-D, and D-sub.
Features:-
- Uncompromised 27” 3D immersion with NVIDIA® 3D Vision™ 2 glasses and 3D LightBoost™
- Ultra smooth action with 120Hz refresh rate and 2ms tracer-free
- Vivid color performance with Splendid™ Video Intelligence Technology
- Ergonomic design for swivel, tilt angle, and height adjustment
- Extensive connectivity with HDMI 1.4, dual-link DVI-D, and D-sub
- Panel Size: Wide Screen 27.0"(68.6cm) 16:9
- Full HD 1080P : Yes
- Pixel Pitch : 0.311mm
- Brightness(Max) : 300 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 50000000:1
- Response Time : 2ms (Gray to Gray)
- Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 6 Modes (sRGB Mode/Scenery Mode/Theater Mode/Standard - Mode/Night View Mode/Game Mode)
- Color Temperature Selection : 4 Modes
- HDCP support
- Stereo Speakers : 3W x 2 Stereo RMS
- Signal Input : HDMI , D-Sub, Dual-link DVI-D (support NVIDIA 3D Vision)
- AV Audio Input : HDMI 1.4
- Audio Output : HDMI 1.4
- Chassis Colors : Black
- Tilt : +15°~-5°
- Swivel : Yes
- Height Adjustment : Yes
- Kensington lock
- Phys.Dimension(WxHxD): 643x460x220mm
- Net Weight (Esti.): 8 kg
- Dual-link DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Nvidia 3D Vision Kit
- 3yr Warranty
Was £499.99 Inc. VAT
Only £479.99 inc VAT.
ORDER NOW
BenQ G2750 27" Widescreen LED Monitor - Black @ £179.99 inc VAT
An enjoyable addition to your everyday home or work life, the G2750 gives you crisp and accurate viewing at all times. The G2750 comes with a dynamic contrast ratio of 50000:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games. The G2750 supports the Full HD 1080p with 16:9 aspect ratio - allowing the subtlest details to stand out with richer, more realistic colors, making your viewing experience even more absorbing. Experience the truest colors of the world with the BenQ Senseye® Human Vision Technology. With the help of its six proprietary calibration techniques, Senseye® 3 delivers only the best viewing quality in each of its six pre-set viewing modes –Standard, Movie, Game, Photo, sRGB, and Eco – with the Eco Mode especially designed to save power and money. The G2750 has passed Windows® 7 certification and are fully compatible with Windows® 7 color systems. Plug in the G2750 to your computer, and Windows 7 will recognize it instantly, making setup and connection effortless.
- Screen Size 27"W
- Resolution (max.) 1920 x 1080
- Pixel Pitch 0.276 mm
- Brightness 300 cd/m2
- Contrast Ratio 1200:1
- DCR:50,000:1
- Response Time (tr/tf) 5 ms
- Display Area 597.6 x 336.15 mm
- Display Color 16.7 million
- Viewing Angle (L/R;U/D) (CR>=10) 170 / 160
- Terminals D-sub / DVI-D
- Horizontal Frequency (Max) KHz 30 ~ 83
- Vertical Frequency (Max)Hz 50 ~ 76
- Video Bandwidth (MHz) 205
- Colour Temperature Reddish / Normal / Bluish / User mode
- Power Consumption 52W (max)
- Auto Switching Power Supply Built-in
- Features Senseye® Human Vision Technology (plus Senseye 3)
- HDCP Support
- OSD Language: 17 languages
- Windows 7® compatible
- K locker: yes
- Adjustments Tilt (down / up) -5 / 15
- Dimensions (HxWxD) 488.5 x 654.4 x 191.2 mm
- Weight Net weight: 6.4 kg.
- Gross weight: 8.12 kg.
- Accessories (Standard) VGA
- Product Colour Glossy Black
- Vista Certification Premium
- VESA Wall Mounting 100 x 100 mm
- 2yr Warranty
ORDER NOW
MSI CR640-066UK 15.6" HD, Intel Core i3-2310M, 2GB DDR3, HDMI Laptop, Windows 7 Home Premium Edition Laptop - Silver @ £395.99 inc VAT
nonl2br
<b>Processor</b> Intel® Core™ i3-2310M Dual Core (2.1GHz, Intel Sandy Bridge Architecture, 3MB Cache) <br>
<b>Screen</b> 15.6" (1366 x 768 HD Resolution) <br>
<b>Operating System</b> Windows 7 Home Premium Edition 64-bit <br>
<b>RAM</b> 2GB (DDR3 1333MHz) <br>
<b>Hard Drive</b> 320GB <br>
<b>Optical Drive</b> DVD Rewriter (Records DVDs 8x & CDs 24x & Dual Layer Super Multi) <br>
<b>Graphics</b> Integrated (Intel® HD 3000 Graphics with up to 1274MB Shared Memory) <br>
<b>Wireless LAN</b> Wireless (802.11b/g/n Wireless) <br>
<b>Network Card</b> 10/100/1000 Gigabit Fast Ethernet <br>
<b>Integrated Webcam</b> Integrated Webcam with Microphone <br>
<b>Card Reader</b> 5-in-1 card reader (SD//MS/MS-Pro/MMC/xD-Picture card™) <br>
<b>USB Ports</b> 2x USB 2.0 ports <br>
<b>Speakers</b> Integrated Sound System <br>
<b>VGA Port</b> 1 External VGA Port <br>
<b>Charge Time</b> 2.5 Hours <br>
<b>HDMI</b> 1x HDMI Port <br>
<b>Warranty</b> MSI 1 Year Collect & Return Warranty <br>
<b>Battery Life</b> 5-6 Hours (up to 6 hours with power management) <br>
Was £407.99 Inc. VAT
Only £395.99 inc VAT.
ORDER NOW
OcUK Tech Lab - V8 Watercooling Kit 240 @ £190.18 inc VAT
Until now, watercooling has been off-putting.
The costs involved and the myriad of choices available can be confusing to newcomers who crave the high performance, silence and gorgeous aesthetics that a watercooled system provides.
In the past, Watercooling Kits have nearly always had cheap, low quality parts in the box that are prone to failure or were generally low quality.
OcUK have stepped in and solved this problem. With each OcUK Kit you get everything you need to watercool your PC along with full installation instructions. this means you cant go wrong. You don't run the risk of ordering the wrong parts, and you are assured out of the box compatibility.
Pair this with the Ultra High End performance of EK products and you have the quick and easy solution you need to gain those extra MHz
Ideal for first time watercooling enthusiasts and seasoned veterans alike.
Component List:
1X XSPC EX240 120mm Radiator
Ultra high air flow and innovative built in shroud design offers uncompromised performance that is second to none.
1X EK DCP 4.0 Pump
A superb all round pump with a small footprint inside the case
1X EK Reservoir Combo DCP 4.0
A powerful aftermarket top and reservoir combo to ensure maximum performance from your Pump
1X EK Supreme HF CPU Waterblock - Copper Plexi
The most popular waterblock on the planet, and for good reason. A mixture of market leading performance and superb build quality. It's called the 'Supreme' for a reason!
2X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fans
The most recognised performance fans for watercooling radiators.
1X Mayhems Coolant
Pick your own coolant that suits your taste and style
1X XSPC 7/16" ID [16/11mm] Clear
High quality watercooling tubing with a superb bend radius
6X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Shining Silver Finish
Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.
IMPORTANT:
Kit is easy to install, use and maintain (thorough installation manual is available on our forums).
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3
***NOTE***
Our Custom Watercooling Kits and Cases are configured in house by our technicians. We endeavour to keep stock of all items at all times.
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.
Custom Units can take 24 to 48 hours if assembly of a component is required.
Whilst we endeavour to keep watercooling stock levels high for our watercooling systems, there may be some occasions where stock shortages mean that there will be a delay in completing your order. If this is the case, then our sales team are able to suggest alternative components to allow your order to be completed.
Was £194.98 Inc. VAT
Only £190.18 inc VAT.
ORDER NOW
OcUK Tech Lab - V12 Watercooled Case - BitFenix Shinobi XL Full Tower - Black @ £423.58 inc VAT
nonl2brAssembled by Expert OcUK Technical Staff, the V12 range of Pre-Watercooled cases brings you exceptional performance paired with incredible value for money! </br></br>
The OcUK Watercooled Case range comes pre-assembled for your convenience. All of the difficulty of watercooling has been removed and allows you to enjoy the best performance without the hassle.</br></br>
All of our pre-watercooled cases are built to order and come pre filled ready for you to build your dream system.</br></br>
The system is shipped with Clear Mayhems Ultra Pure Fluid. If you prefer us to use a coloured fluid or specialist liquid, you can choose from a wide range</br></br>
All you need to do is build your PC and install the waterblock which is just as easy to do as mounting any CPU cooler.</br></br>
All leak testing and filling is carried out by our technical staff which means that the watercooling system is ready to use by you when it arrives. All that is required is for you to plug the pump and fans into your power supply.</br></br>
<strong>PLEASE CHOOSE THE CORRECT MOUNTING BRACKET FOR YOUR CPU</strong></br></br>
We've taken our battle-proven Shinobi design and expanded it, creating a roomy, feature-packed full tower enclosure that will not only turn heads, but take them clean off. The larger size enables you to outfit your Shinobi XL with the latest fear-inducing hardware, including XL-ATX motherboards and the longest graphics cards. Shinobi XL can accommodate up to two 360mm radiators, making it ideal for water cooling enthusiasts. Four SuperSpeed USB 3.0 ports and the all-new BitFenix SuperCharge™ port keep your peripherals and mobile devices ready for battle, while the BitFenix FlexCage™ hard disk rack adds to the Shinobi XL's nimbleness. With three included Spectre™ fans, tool-free drive locking, filtered intakes and signature BitFenix SofTouch™ Surface Treatment, Shinobi XL is the chassis you need when vengeance is not enough.</br></br>
- Dimensions (HxWxD): 570 x 245 x 557mm (ATX Full Tower)</br>
- Motherboard Sizes: Mini-ITX, mATX, ATX, XL-ATX</br>
- 5.25” Drive Bays: x 5</br>
- 3.5” Drive Bays: x 7</br>
- 2.5” Drive Bays: x 8 (using 3.5" drive bays and 5.25" adapter)</br>
- Cooling Front: 1 x 230mm (included), or 3 x 120mm (optional)</br>
- Cooling Rear: 1 x 120mm (included), or 1 x 140mm (optional)</br>
- Cooling Top: 2 x 230mm (x 1 included), or 3 x 120mm (optional)</br>
- Cooling Bottom: 2 x 120mm (optional)</br>
- PCI Slots: 9</br>
- I/O: 1 x SuperChargeTM, 4 x USB 3.0, HD Audio</br>
- Power Supply: PS2 ATX (bottom, multi direction)</br>
- Extras: Superior watercooling support, FlexCage™, SofTouch™ Surface Treatment, filtered intakes, tool-free drive locking</br>
- Maximum CPU Cooler Height: 193mm</br>
- Maximum Expansion Card Length: 377mm (with HDD cage) / 492mm (with HDD cage removed)</br>
- Maximum MB Tray Clearance (rear): 34.5mm</br></br>
<strong>Component List:</strong></br></br>
1X BitFenix Shinobi XL Full Tower Gaming Case - Black</br>
The brand new king of watercooling cases offering excetional hardware layout options and space for expansion, this case is futureproof to the next level!</br></br>
1X Hardware Labs Black ICE SR-1 360 Radiator</br>
Ultra high air flow and innovative built in shroud design offers uncompromised performance that is second to none.</br></br>
1X EK Supreme HF CPU Waterblock - Copper Plexi</br>
The most popular waterblock on the planet, and for good reason. A mixture of market leading performance and superb build quality. It's called the 'Supreme' for a reason!</br></br>
1X Alphacool Laing D5 Vario Pump 655</br>
The Best watercooling pump on the market. Needs little introduction.</br></br>
1X Alphacool HF D5 TOP - Black Acetal G1/4</br>
The ultimate top for your pump offers even better performance as well as more mounting and connective possibilities</br></br>
1X Phobya Single 5.25” Bay Reservoir</br>
Single bay reservoir for installation into the 5.25" optical drive bay.</br></br>
8X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Shining Silver Finish</br>
Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.</br></br>
1X XSPC 7/16" ID [16/11mm] High Flex Hose - Clear</br>
High quality watercooling tubing with a superb bend radius</br></br>
3X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fans</br>
The most recognised performance fans for watercooling radiators.</br></br>
Supported sockets:</br>
- Intel Socket 775</br>
- Intel Socket 771</br>
- Intel 1366 Socket</br>
- Intel 1156 Socket</br>
- Intel 1155 Socket</br>
- Intel 2011 Socket</br>
- AMD Sockets: 939, 754, 940</br>
- AMD Sockets: AM2, AM2+, AM3</br></br>
<a href="http://www.techpowerup.com/reviews/Bitfenix/Shinobi_XL/" target="_blank"><img src="http://www.overclockers.co.uk/LP/productimages/reviewlogo/tech_powerup_recommeded.jpg"></a>
</br></br>
***NOTE***</br>
Our Custom Watercooling Kits and Cases are configured in house by our technicians. We endeavour to keep stock of all items at all times.</br>
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.</br>
Custom Units can take 24 to 48 hours if assembly of a component is required.</br></br>
Whilst we endeavour to keep watercooling stock levels high for our watercooling systems, there may be some occasions where stock shortages mean that there will be a delay in completing your order. If this is the case, then our sales team are able to suggest alternative components to allow your order to be completed.</br>
Was £425.98 Inc. VAT
Only £423.58 inc VAT.
ORDER NOW
Plantronics GameCom 780 7.1 Surround Sound USB Gaming Headset @ £38.78 inc VAT
The Plantronics GameCom 780 USB headset with Dolby technologies transforms standard audio into a stunning 7.1 surround sound experience.
The noise-cancelling microphone kills background noise so your commands are loud and clear. When you need to take a break, built-in spin joints let the earpods lay flat for easy storage.
Need to adjust volume? No problem. The controls are right on the earpods so you'll always have eyes on.
The GameCom 780 is built to last with superhero-strength cords and joints; ultra-comfortable ear cushions and headband let you stay in the game for as long as it takes.
• Dolby Headphone and Pro Logic IIx technologies transform standard audio into a stunning 7.1 surround sound experience
• 40mm speakers pound out deep bass and immersive stereo sound
• Built-in spin-joints let the earpods lay flat for easy storage when you need to take a break
• Noise-cancelling microphone kills background noise so your team or opponents can clearly hear your commands
• Easy-to-reach on-ear volume and mute buttons let you adjust the sound and still keep a hand on the controls
• Superhero-strength cords and joints mean this USB headset will be around for all your battles
• Ultra-comfortable ear cushions and headband make the GameCom 780 perfect for gaming, and great for watching videos, listening to music, and making PC voice calls.
Was £39.98 Inc. VAT
Only £38.78 inc VAT.
ORDER NOW
Logitech G35 Gaming USB Headset PC 7.1Ch Surround Sound @ £89.76 inc VAT
The Logitech G35 headset. Game-changing immersion with 7.1 surround sound powered by Dolby technology for a detailed soundfield - hear your enemies before they see you. Featuring three swappable headband pads so you can choose the best fit, for long-lasting comfort; three customizable G keys for one-touch command over music, voice morphing, and more; on-ear audio controls for quick access to volume, microphone mute, and surround sound adjustments; and an adjustable, noise-canceling microphone that focuses on your voice and reduces background noise.
- 7.1 surround sound powered by Dolby technology delivers a detailed soundfield - hear your enemies before they see you.
- Three swappable headband pads let you choose the best fit, for long-lasting comfort.
- Three customizable G keys give you one-touch command over music, voice morphing, and more.
- On-ear audio controls provide quick access to volume, microphone mute, and surround sound adjustments.
- Adjustable, noise-canceling microphone focuses on your voice and reduces background noise.
- 2-years limited warranty
Was £90.98 Inc. VAT
Only £89.76 inc VAT.
ORDER NOW
Plantronics GameCom 777 USB 7.1 Surround Sound Headset @ £40.79 inc VAT
This open-eared headset with 7.1 Dolby Headphone technology gives you an unparalleled audio advantage that lets you hear your opponents before you see them. Connect with the Dolby USB sound card for a true 7.1 experience. But if needed, an analogue connection is also provided. Stay comfortable with a lightweight frame and specially designed ear pods that redistribute pressure. When you’re ready to fire off orders, unveil the hidden, noise-cancelling mic boom to strategize clearly with team members. Responses coming in? Adjust audio levels using in-line volume and mic-mute controls.
- Dolby Headphone technology delivers a 5-channel audio experience.
- Dolby USB sound card is the only way to get the 7.1 experience. If needed, an analog connection is also provided.
- Open-ear design keeps you connected to the game and your surroundings.
- Concealed mic boom stays hidden until you’re ready to use it.
- Specially designed ear pods redistribute pressure for maximum comfort.
- In-line volume and mic-mute controls allow for easy audio adjustment.
- Noise-cancelling microphone lets you communicate clearly.
- Rugged, military-grade design and extra-strength cables make your hardware hardcore.
Was £49.99 Inc. VAT
Only £40.79 inc VAT.
ORDER NOW
Steelseries Siberia v2 Gaming Headset - Green (51120) @ £67.58 inc VAT
Based on the award-winning SteelSeries Siberia Full-size Headset, the v2 features major enhancements in sound quality, comfort and its microphone. Every element of the v2 has been optimized for pro gaming, making the headset a preferred piece of equipment for the worlds' best competitive PC gamers - the most demanding headset users in the world.
Sporting 25% larger 50mm driver units, the SteelSeries Siberia Full-size Headset dramatically boosts overall acoustic performance. Experience a rich and detailed soundscape from immersive atmospheric background music to precise 3D positional sounds of footsteps, gunfire and more.
The close type ear cups feature thick leather padded cushions built from sound dampening foam, designed to offer passive noise reduction from loud surroundings and improve comfort over prolonged use. A virtually invisible uni-directional microphone can be retracted from the left ear cup, optimized for essential voice communications.
The v2 remains lightweight and its trademark headband suspension construction makes it extremely comfortable for use over long periods of time.
- Closed type headphones.
- Pull-out microphone.
- Crystal clear high, low and mid-tones.
- 50mm driver units.
- Lightweight suspension construction.
- Integrated volume control located on the cord.
- 2 years warranty
Was £69.98 Inc. VAT
Only £67.58 inc VAT.
ORDER NOW
TT Esports Shock One 5.1 Headset @ £53.98 inc VAT
The Shock One is designed with performance and comfort in mind, featuring DTS 5.1 channel virtual surround sound, dynamic 40mm speaker drivers, a leather headband pad and multiple ear-pad cushions for enhanced comfort. The new headset has a black and red color scheme, complete with an illuminated Thermaltake logo. The Shock One also includes ten headband settings for the perfect fit, along with a noise-canceling microphone, a 3m cable and a gold-plated USB connector. An in-line control box allows easy changing of volume and microphone settings.
• Driver unit: 40mm
• Frequency Response: 20Hz~20 KHz
• Impedance: 32 ohm
• Sensitivity: 114+/-3dB
• Max. input: 100mW
• Cable length: 3m
• Connector: USB
Was £59.98 Inc. VAT
Only £53.98 inc VAT.
ORDER NOW
Energy Sistem Energy DJ 600 Professional DJ Headphones, Black @ £38.99 inc VAT
Cutting-edge design in anodized alloy with breakneck bass response and crystal clear sound, these headphones provide an exceptional listening experience. Hours of listening pleasure thanks to extra large injected foam pads and its wide flat headband. Compatible with iPod and iPhone.
• Extra Large Foam Pads
• Maximum Comfort And Lightweight
• Gold Plated 3.5mm Jack
• Crystal Clear Sound
• Deep Bass Response
• Enclosed Dynamic Circumaural Headphones
• Guarantee: 36 Months
Was £44.99 Inc. VAT
Only £38.99 inc VAT.
ORDER NOW
Logitech C210 1.3 Megapixel USB Webcam @ £13.44 inc VAT
Anyone can make a video call with a video-calling application built right into your webcam setup.
Free, fast calling
Logitech Vid™ HD is free, fast and easy for you and anyone you call. It sets up when you set up the webcam.
The real you
Your loved ones will see you in lifelike color when you talk to them, or you can take photos to share later.
It fits
The universal clip lets you attach your webcam to your notebook or LCD monitor—or sit it on a shelf or desk.
Includes Logitech Vid™ HD
Now video calling is free, fast and easy for you and anyone you want to talk to. It’s built into your webcam setup, so you can call right away.
Clear video calls
With your webcam’s VGA sensor, the people you care about will see you in lifelike color.
1.3-megapixel photos
It’s easy to take snapshots at up to 1.3 megapixels (software enhanced)
Universal clip
It’s easy to take snapshots at up to 1.3 megapixels (software enhanced). You can attach your webcam securely to a notebook or LCD monitor, or sit it on a shelf or desk.
Free video editing software
Logitech has teamed up with MAGIX to offer MAGIX™ Photo Manager 9 and MAGIX™ Video Easy with your new Logitech webcam. And they’re free.
Built-in mic with RightSound™
It gives you clear conversations without annoying background noise.
RightLight™ technology
It automatically adjusts the image during your call, so you look your best even in dim light.
IM compatibility
Works with Skype™, Windows Live™ Messenger, Yahoo!® Messenger, AOL® Instant Messenger (AIM®) and other popular instant messaging applications.
Was £13.98 Inc. VAT
Only £13.44 inc VAT.
ORDER NOW
Creative Live! Cam Socialize 1.3 Megapixel Webcam With Built In Microphone @ £17.98 inc VAT
Make instant messaging come alive with the Live! Cam Socialize webcam and Live! Central 2 software!
The software lets you add a little spice to your conversations with dramatic voice effects and funny visual effects. Communicating and connecting with friends and family have also been made easier with a host of different features. The Live! Contacts button brings up your online contact list instantly so that you can start chatting right away while the Media Show and Desktop Share features let you share your pictures, presentation slides and videos through popular instant messaging services.
Equipped with a built-in noise-canceling microphone, engage in clearer voice chats with reduced background noise, while basking in better face-to-face interactions with the new low-profile design.
- Sensor: VGA (640 x 480) CMOS image sensor
- Video Resolution: Up to 800 x 600 pixels
- Picture Resolution: Up to 1280 x 960 pixels
- Frame Rate: Up to 30fps at 800 x 600 pixels
- Integrated microphone with noise-cancellation
- Works with native Windows ® drivers for instant Plug & Chat
- Snapshot / Live! Contacts button
- Fixed focus
- Multi-attach base
- Cable length: 1.7 meters / 5.5 feet
- Hi-Speed USB 2.0
- 1-year limited hardware warranty
System Requirements
Intel Pentium 4 2.4GHz or equivalent processor
Windows XP with SP2 / Windows Vista / Windows 7
Apple Macintosh OS X 10.5
Linux 2.6
512MB RAM
USB 2.0 Port
Was £19.99 Inc. VAT
Only £17.98 inc VAT.
ORDER NOW
Saitek PZ52P VGA Webcam - Pink @ £1.32 inc VAT
This great value webcam which is fully compatible with laptops, netbooks and desktop PCs is perfect for video messaging applications. Keep in contact with your friends, family and loved ones.
- Easy Capture, click and send
- 640 X 480 resolutions
- Broadcast live video over the web
- Great for video chat, video mail & video conferencing
- Works with MSN, Yahoo, Windows Messenger & more
Was £2.99 Inc. VAT
Only £1.32 inc VAT.
ORDER NOW
Swann Monitoring Kit With PNP-51 day/night Camera and 7 Inch LCD Screen @ £132.00 inc VAT
The Home and Business Monitoring Kit is a new generation of the SecuraView, one of Swannn's best selling products. It allows you to view and hear security video on a crystal clear 7 inch color LCD monitor. The monitor connects to the color camera via a 60 foot / 18 meter cable. You can operate using the remote control in the pack. Both the monitor and camera must be connected to mains power. The pack also includes 4 theft deterrent stickers and everything you need to get started. The Home and Business Monitoring Kit is perfect for anyone wanting an affordable starting point for their security needs. It's ideal for small businesses, retail stores, restaurants or home use. The unit has a discreet, small footprint with a modern and stylish finish. It's a cost effective way to see AND hear what's really happening. You will love the color video. Unlike black and white systems, you will be able to identify what color clothing people are wearing, what color hair they have, and get a truer picture of what is going on. It's easy to do-it-yourself. Mount the camera to a wall or ceiling is simple with screws included in the pack. The LCD monitor can be mounted upside down or side-ways and the video will realign itself to be the right way up using the image flip option. For discretion and to save power you can also use the auto turn-off function when the unit is not needed. The Home and Business Monitoring Kit includes a PNP-51 camera with short range night vision and a built-in microphone to allow you to hear conversations and other sounds. The Kit is also upgradeable in that you can add a second camera and then switch camera views.
- Mount camera & LCD to walls or ceilings
- LCD image flip option. Mount lcd monitor upside down or side ways & flip the image around the right way
- Auto turn on/off LCD monitor - Set time to automatically turn the montior on & off
- Add a second camera - Automatically switch camera views at 4 to 8 second intervals
Was £134.99 Inc. VAT
Only £132.00 inc VAT.
ORDER NOW
CyberPower DX600E UPS @ £59.99 inc VAT
The DX Series UPS is a cutting-edged UPS system which is ideally designed for home and small office. It can perfectly protect users’ equipment from damaging lightening and surges that cause serious data loss. This DX Series UPS includes an advanced Energy-Saving Technology that significantly improves UPS operating efficiency and reduces energy cost for users. The LED status and battery capacity indicators allow users to monitor power status and battery backup condition to manage data saving more efficiently. Its compact design also assists users to make the best advantage of interior space.
Features & Benefits:
• GreenPower UPS™ Technology : Energy-Saving UPS
• EMI, RFI, Surge and lightning spike protection
• LED status & Battery Capacity Indicators
• Auto-Shutdown software
• USB connectivity port
• 3 power outlets
• Compact design with highest power output
• Equipment Protection Policy up to 50,000 Euros
Was £65.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
CyberPower GreenPower 600VA UPS with AVR @ £58.79 inc VAT
The GreenPower Series UPS with Automatic Voltage Regulator (AVR) is the best solution for SOHO to supply a clean and stable power. The GP series UPS is compatible with many different operating systems, including Microsoft Windows 98/Me/2000/NT/XP/Vista. PowerPanel® Personal Edition management software included for USB Port shows versatility of a UPS, like power voltage, scheduled shutdown, and remaining battery capacity?remaining battery runtime?battery status ...etc. Value GP Series UPS can save upto 75% of electricity and save your electricity bill.
- Energy-Saving UPS
- Automatic Voltage Regulator (AVR)
- Auto scheduled software
- USB & Serial connectivity ports
- 3 Output Connectors
- Compact design with highest power output
- Power Management software included
- Green Power Technology
- Auto restart / Auto charge
- Save upto 75% of electicity
- Equipment Protection Policy up to 25,000 Euros
- 600VA / 360W
- Cables Included: 1 x power cable - integrated
Was £61.26 Inc. VAT
Only £58.79 inc VAT.
ORDER NOW
Energenie 30 Minute Rundown Timer @ £5.04 inc VAT
This rundown timer will switch off the mains power to your appliance after 30 minutes.
Suitable for:
• hair strighteners
• irons
• curling tongs
• electric blankets
• bedroom lamps
• bedroom TVs etc
Voltage: 220 - 250v ac 50Hz
Maximum load: 13A, 3kW
Manual reset button & indicator lamp
Timeout period: 30 minutes
Was £7.88 Inc. VAT
Only £5.04 inc VAT.
ORDER NOW
Swiftech Apogee GTZ Waterblock - 1366 & 2011 Compatible @ £58.79 inc VAT
The Apogee™ GTZ is Swiftech's new flagship water-block. While it shares the same name with its predecessors, it also leaps beyond the GT and GTX performance charts thanks to an entirely new design that pushes and refines both thermal and mechanical specifications to the limits of today's technology. Thermal design of the cooling engine combines the benefits of direct coolant impingement over the CPU area with an entirely new copper base plate design which is primarily characterized by a pin matrix composed of 225 µm (0.009") micro structures. This results in a 20% improvement in thermal resistance compared to the Apogee™ GTX. Mechanical design of the copper base plate is optimized for Intel socket 775, 2011 and 1366 and features a topographically mapped CPU contact area which results in a 75% and up to 300% improvement in TIM joint thermal resistance compared to the Apogee™ GT/GTX series. It should be noted that other types of sockets (AMD socket F, AM2, 940) may also benefit from the enhanced contact area to a lesser extent.
Was £59.99 Inc. VAT
ORDER NOW
EK Supreme HF CPU Waterblock - Full Nickel @ £68.52 inc VAT
The Ultimate CPU Waterblock
After 2 successful years of EK-Supreme CPU water block, EK has released its successor. The EK-Supreme HF - Full Nickel Block is based on same concept as EK-Supreme.The base plate is made of nickel plated electrolytic copper lapped and polished to +/- 0,0007 mm flatness. The top is made of nickel plated electrolytic copper material. Mounting plate is made of powder coated stainless steel. The EK-Supreme HF - Full Nickel cooling engine uses fin design. The water accelerates through thin jet plate channels through 49 very thin channels, which gives extreme cooling surface. The copper base is also very thin, which gives very short distance for temperature to transfer from CPU to water.
Blocks main improvements are:
- better flow up to 50% higher flow compared or EK-Supreme
- better cooling performance
Enclosed in the box:
- EK-Supreme HF - Full Nickel water block
- 4 different jet plates + 1 blank
- Universal supported mounting plates:
o Intel: 775, 1366, 1156, xeon
o AMD: AM2, AM2+, AM3, 939, 754, opteron
- Universal CPU retention backplate
- Thermal grease Arctic Cooling MX-2 (2g)
Supported sockets:
Processor compatibility:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
Was £69.98 Inc. VAT
Only £68.52 inc VAT.
ORDER NOW
XSPC RayStorm CPU WaterBlock (Intel) @ £47.99 inc VAT
Our best ever performing water block, with a unique new look.
- Designed for Multi Core CPU’s
- High Performance Copper Base 56x56x3mm
- CNC Cut Acetal Top
- G1/4? Threads
- 4x 3mm LED Holes
- Compatible with Most Compression Fittings
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
Supplied with mounting hardware, 775, 1156/1155, and 1366/2011 backplates,
twin blue LED, allen key, and K2 thermal paste.
Was £49.98 Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
EK-FC7950 Backplate - Black @ £19.19 inc VAT
EK-FC7950 Backplate is a retention backplate made of black painted aluminum for EK-FC7950 series water block.
Backplate cover the whole lenght of graphics cards PCB, serves as an aesthetic add-on and also provides passive cooling for the backside of voltage regulation module (VRM).
This backplate is guaranteed to be compatible only with AMD reference design Radeon HD 7950 graphics card in combination with any EK-FC7950 series water block. No other water blocks are officially supported! Please check our Cooling Configurator for detailed compatibility list!
Enclosed:
- EK-FC7950 Backplate - Black
- mounting mechanism
- thermal pads
Made in Slovenia - Europe!
Was £19.99 Inc. VAT
Only £19.19 inc VAT.
ORDER NOW
EK-FC7950 Full Cover Waterblock - Nickel Plexi **EN Nickel Plating** @ £73.79 inc VAT
Please note, This item is a PLEXI + Nickel Waterblock. The item has not been produced yet and no stock photo is available.
EK-FC7970 is a high performance full-cover water block for AMD reference design Radeon HD 7950 graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC7950 water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps.
Base is made of electroless nickel (EN) plated electrolytic copper while the top is made of quality cast acrylic material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
G1/4" threaded fittings can be used on both side of the water block (on copper and plastic) and 2 plugs (EK-Plug G1/4) are enclosed!
Enclosed:
- EK-FC7950 series water block
- mounting mechanism with screw-in brass standoffs
- thermal pads
Please note: Thermal paste is not included and needs to be purchased separately. EKWB recommends Gelid GC-Extreme for best performance.
PLEASE NOTE:
- Due to superior nickel plating method and corrosion resistance, the waterblock may loose brightness over time and become of a bit duller tone.
- Due to immense variety of fittings/barbs available on market and no prescribed standards, we guarantee compatibility only for connectors bought from our web site.
Was £74.99 Inc. VAT
Only £73.79 inc VAT.
ORDER NOW
EK-FC7970 Full Cover Waterblock - Nickel Acetal **EN Nickel Plating** @ £73.99 inc VAT
EK-FC7970 is a high performance full-cover water block for AMD reference design Radeon HD 7970 and -7950 graphics card. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC7970 water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps.
Base is made of electroless nickel (EN) plated electrolytic copper while the top is made of quality POM Acetal material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
EKWB also offers a single-slot I/O bracket which frees adjacent PCI/PCIe expansion slot. The bracket is available as an optional add-on and can be purchased through EKWB webshop.
Enclosed:
- EK-FC7970 series water block
- thermal pads
Was £79.99 Inc. VAT
Only £73.99 inc VAT.
ORDER NOW
XSPC Razor 7970 GPU Waterblock @ £77.99 inc VAT
Full Cover VGA Water-Block
- CNC machined copper base
- CNC machined aluminium VRM cooler
- 1mm fins for high performance
- CNC cut stainless steel top
- Dimensions 220 x 142 x 9mm (18mm at ports)
- Prepared for crossfire with 4 G1/4? ports
- Supports ATI 7970 cards
(ATI reference design only)
Supplied with mounting kit, G1/4" plugs, thermal pads and thermal paste
Was £82.99 Inc. VAT
Only £77.99 inc VAT.
ORDER NOW
Alphacool HF D5 TOP - Black Acetal G1/4 @ £20.78 inc VAT
The ultimate top for your Alphacool power pump offers even better performance as well as more mounting and connective possibilities for your favorite pump!
The base performance of the Alphacool TPP & VPP is already truly exceptional, but what if there is a possibility to improve even on that? This idea was also what has driven the developers which have created a product that does not only increase performance but also offers other additional advantages over the base model pump.
One of the greatest advantages are the G1/4” connection threads both at the sides and top of the pump cover. Both can be used separately or even in a combination. For the unused connection threads two knurled copper plated screw plugs are included.
The design is also a factor which was not taken lightly! The elegant black Acetal material with integrated Alphacool logo gives a clue of the potential of the German Know-how in these tops!
Mounting is done quickly and easily. With a simple twisting motion the motor is separated from the mount. After that you will find 4 separated basic components. First pull the O-ring over the polished silver front piece of the pump and then push on the largest of the 4 components. At the back, where the cable is coming out of the case, the counterpiece is pushed on. With the included mounting screws the elements can be tightly connected and you are done!
And what purpose has the last plate? It can be used for mounting of the pump in the case! Simply screw the plate to the pump’s top and the opposite side to the case or decoupling module and you are set to go!
And you will notice: This is yet another great piece of engineering from the Alphacool team!
Technical specifications:
Material: Acetal
Color: Black
Connection thread size: 4x ¼”
Dimensions mounted (L x W x H): 80 x 45 x 80mm
The installation manual of Alphacool HF D5 TOP you can find here as Download.
Extent of delivery:
1x Alphacool HF D5 TOP - Black Acetal G1/4 - (VPP655/TPP644/MCP655)
2x Copper plated screw plugs
Black mounting screws
Please note:
Delivery without pump!
Was £21.98 Inc. VAT
Only £20.78 inc VAT.
ORDER NOW
Hardware Labs Black Ice GT Stealth 120 Radiator @ £26.38 inc VAT
The GTS120 boasts of a radically redesigned Black Ice® core technology that maximizes heat transfer efficiency and maintains effectively the same compact profile of the Black Ice® Pro.
Features:
- Two-pass U-flow tank configuration.
- Custom MaxFin™ 25 micron Copper Splitter Fin Configuration utilizing 45% thinner fin material yielding up to 50% less pressure drop even with twice the fin density.
- Unique fin configuration eliminates intra-louver accumulation of dust particles for trouble free operation.
- Unprecedented Ultra-high 30 FPI (Fins Per Inch) fin density providing dramatically increased heat transfer surface area.
- Custom low-profile 19.0 x 1.2mm MaxFlow™ tubes with 15% more waterside surface area and 60% frontal area reduction for superior low air-resistance aerodynamics and lower internal flow requirements.
- Yields up to 20% more heat exchange capacity than the Black Ice® Pro in both Stealth or Performance modes.
- Achieves Black Ice® Xtreme level performance in stealth mode (low-noise/low-airflow conditions).
- M4 Threaded Screw Holes for easier mounting and greater adaptability.
- Now standard G 1/4" female threaded fittings.
- Full high-temper brass structural construction for weight reduction and superior corrosion resistance.
- High performance compact radiator compatible as an upgrade to the Black Ice® Pro and most 120mm form factor radiators.
- Uses 100% Non-corrosive water-solluble fluxing process.
- Fully RoHS compliant.
- Full electrostatic polyurethane painting finish for uniform coating with high temperature curing for increased finish durability.
- Renowned Black Ice® quality.
- Patent Pending Design
Was £30.98 Inc. VAT
Only £26.38 inc VAT.
ORDER NOW
Hardware Labs Black ICE SR-1 240 Radiator @ £59.99 inc VAT
The Black Ice® SR1-240 bridges the gap between ultra-stealth and extreme high performance allowing it to effectively utilize sub-1000 rpm fans and scale performance up to 2000rpm. Ultra-stealth operation with increased thermal capacity, and from the industry's standard bearer for quality and craftsmanship.
Features:
- Two-pass u-flow configuration utilizing high-flow tubes for up to 40% increase in internal flow rates.
- Custom compressed core width to maximize airflow and enhance heat exchange.
- Optimized custom 9 FPI (Fins Per Inch) 45 micron copper maximized conductivity.
- Yields up to 30% more heat exchange capacity than the Black Ice® GTX in ultra-stealth operation mode up to 2000rpm.
- Built-in 15mm deep plenum for equalized core air pressure distribution.
- Standard G 1/4" female threaded fittings.
- High performance compact radiator compatible as an upgrade to the Black Ice® Xtreme III, Black Ice® GTX240 and most 3x120mm fan form factor radiators.
- Uses 100% Non-corrosive water-soluble fluxing process.
- Carbon Black Finish.
- Patent Pending Design.
Was £69.98 Inc. VAT
ORDER NOW
Hardware Labs Black ICE SR-1 360 Radiator @ £74.39 inc VAT
The Black Ice® SR1-360 bridges the gap between ultra-stealth and extreme high performance allowing it to effectively utilize sub-1000 rpm fans and scale performance up to 2000rpm. Ultra-stealth operation with increased thermal capacity, and from the industry's standard bearer for quality and craftsmanship.
Features:
- High performance compact radiator compatible as an upgrade to the Black Ice® Xtreme III, Black Ice® GTX360 and most 3x120mm fan form factor radiators.
Was £83.98 Inc. VAT
Only £74.39 inc VAT.
ORDER NOW
Phobya 5,25" Single Bay Reservoir Black @ £23.99 inc VAT
Phobya's first Slot-in reservoir with many technical innovations and great details: A true optical highlight! This is more than just a Plexi reservoir!
The main function of a reservoir in a water cooling loop is to offer space for expansion of the coolant, deaerate the loop and also help with initial filling. This is where the innovations from the developers at Phobya comes into play: An internal channel system helps with deaeration to ensure all air bubbles being removed from the coolant.
Even with very powerful pumps this reservoir is able to remove the air bubbles from the system. The filling of the reservoir can be done easily and quickly by removing the 3/8" screw plug after pulling the reservoir out of the drive bay. We recommend using a funnel for filling.
An even easier solution is connecting a Fillport which will allow filling without pulling the reservoir from the case.
The small details are what makes this reservoir great: Four G1/4" threads give many connection possibilities for maximum versatility.
The optical aspect of a watercooling is also very important! Especially in large enclosures there are usually too many 5.25" drive bays. With this handy reservoir they can now be used and will look even better to make the front of your system even more beautiful. A second thin Plexi plate on the actual reservoir front protects the black middle plate with the words "PHOBYA". Besides the Phobya inscription a fill level indicator is integrated to allow checking of the fill level at the front of the case. Especially with coloured coolant the fill level indicator provides a beautiful effect and sets a unique accent.
This effect can be improved even further when using the four 5mm LED holes at the rear for unique lighting effects inside of the reservoir.
The reservoir is shipped with all parts required for mounting. For mounting the reservoir can simply be pushed into the front of the tower and mounted with the black hexagonal socket screws. As usually only two of the four connection threads are used, two black nickel plated screw plugs are included.
Technical details:
Material: Acryl/Plexi (PMMMA)
Color: Transparent, black front
Dimensions (L x W x H): 175 x 149 x 44mm
Led holes: 4x 5mm
Filling opening: 1x 3/8Zoll
Connection threads: 4x 1/4Zoll
Complies with Rohs directives!
Extent of delivery:
1x Reservoir
2x Screw plugs
4x 5mm mounting screws
4x Washers
Was £24.98 Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
1 Pack - Verbatim BD-R 6x 25GB Blu-ray Print J/C (43712) @ £3.59 inc VAT
BD-R SL 25GB 6x Printable Single Jewel Case The advent of Blu-ray technology has led to the introduction of high capacity storage discs to meet the demand cause by the rapid growth of high definition television (HDTV).
Key Features
• Hard Coat protective layer
• Extremely long archival life
• Excellent playback performance
• BD-R is for use in BD drives and recorders
• Laser Wavelength: 205nm
Blu-ray discs get their name from blue laser technology. The shorter wavelength of the laser is the reason it is blue in colour. The blue laser has a wavelength of 405nm compared with the wavelength of 650nm for DVD which utilises red laser technology. The benefit of having a blue laser with a shorter wavelength means it is possible to write smaller data pits and therefore vastly increase the amount of data on the disc.
Blu-ray discs offere 3 to 5 times the storage capacity of a standard recordable DVD disc, enabling the recording, rewriting and playback of high definition video (HD).
Was £3.74 Inc. VAT
Only £3.59 inc VAT.
ORDER NOW
50 Pack - Kodak DVD-R 16x Shrink Pack @ £8.40 inc VAT
DVD-R - 4.7GB - 16x Write Speed - Shrink Pack - 50 Pack
Was £8.99 Inc. VAT
Only £8.40 inc VAT.
ORDER NOW
25 Pack - TDK CDR-80 52x 25pc Cakebox (T18767) @ £4.79 inc VAT
Developed for ultimate performance, and manufactured to the most exacting standards, TDK CD-R media is the ideal digital storage solution. CD-R disks are write once, meaning a CD-R can be fully recorded one time, but can't be erased or rerecorded.
Key Features
• Write-Once CDR
• Native Capacity 700MB
• Write Speed 52x
• Package Type Spindle
• Disc Surface Silver
Was £4.99 Inc. VAT
Only £4.79 inc VAT.
ORDER NOW
Netgear WNDR3400 Wireless-N N600 Wireless Dual Band Cable Router @ £84.19 inc VAT
Netgear WNDR3400 Rangemax Dual Band Wireless-N Router
The NETGEAR N600 Wireless Dual Band Router offers the high-performance wireless Internet access needed for demanding applications, such as streaming multimedia and multiplayer gaming. Dual band technology avoids interference, ensuring top speeds and the greatest range.
Features
Dual band - Offers twice the bandwidth with better connection and less interference
Faster multimedia streaming - Provides Wireless-N speed and dual band performance for streaming video, multiplayer online gaming and simultaneous downloads
Shared storage - ReadySHARE™ provides fast and easy shared access to an external USB storage device Jitter-free video and gaming - Video Quality of Service (QoS) for reliable Internet connections
Live Parental Controls - keeps your Internet experience safe
Blocks unsafe Internet content and applications and can be managed from anywhere
Protects connected devices through the router such as PCs, gaming consoles, and iPod touch®
To learn more visit www.netgear.com/lpc
Guest network access - Provides separate security and access restrictions for guests using the network
Broadband usage meter - ensures daily, weekly and monthly measurement of Internet traffic with customized alerts
Easy setup - Smart Wizard® CD with graphical installation guide
Secured connection - Push ‘N’ Connect with Wi-Fi Protected Setup® (WPS)1 ensure a quick and secure network connection
NETGEAR Green features - Power and Wi-Fi on/off buttons, Energy Star-compliant power adapter and 80% recycled packaging
System Requirements
Broadband (cable, DSL) Internet service and modem with Ethernet connection
2.4 or 5.0 GHz 802.11a/b/g/n specification wireless adapter or an Ethernet adapter and cable for each computer
Microsoft® Windows® 7, Vista®, XP, 2000, Mac OS®, UNIX®, or Linux®
Microsoft® Internet Explorer® 5.0, Firefox® 2.0 or Safari 1.4 or higher
Standards
IEEE® 802.11 b/g/n 2.4 GHz
IEEE 802.11 a/n 5.0 GHz
Five (5) 10/100 (1 WAN and 4 LAN) Ethernet ports with auto-sensing technology
Performance
480 MHz powerful MIPS 32-bit processor
Memory: 8 MB flash and 64 MB RAM
Five (5) (1 WAN, 4 LAN) Fast Ethernet ports
Advanced Quality of Service (QoS)
Supports Wireless Multimedia (WMM) based QoS
Was £94.99 Inc. VAT
Only £84.19 inc VAT.
ORDER NOW
Netgear WNDR4000 Wireless-N N750 Wireless Dual Band Cable Router @ £118.79 inc VAT
The NETGEAR N750 Wireless Dual Band Gigabit Router offers high performance wireless speeds of up to 450Mbps (5GHz only) needed for demanding applications, such as large file transfers, streaming HD video and multiplayer gaming. Dual band technology avoids interference, ensuring top speeds and the highest range, while Gigabit offers ultra-fast wired connections.
WAN Gigabit Ethernet port for cable/fiber combined with a wireless router create the Ultimate Integrated Home solution
Concurrent Dual band - Eusuring top speeds and the greatest range while minimizing interference
Faster multimedia streaming - Provides Wireless-N speed for streaming HD videos, simultaneous downloads, and online gaming in addition to basic Internet applications
Shared storage - Two ports for ReadySHARE® USB Storage Access provides fast and easy shared access to an external USB storage device
Live Parental Controls - Keeps your Internet experience safe
Secured connection - Push ‘N’ Connect ensures a quick and secure network connection
Broadband usage meter - Monitors Internet traffic and sends customized reports to help keep costs under control
Easy installation - Connect to PC and open your browser to install
Compatibility - Compatible with all major ADSL Internet service providers (ISPs)
Was £139.98 Inc. VAT
Only £118.79 inc VAT.
ORDER NOW
AMD Athlon II Dual-Core processors put the power of dual-core technology on the desktop. Dual-core processors contain two processing cores, residing on one chip, that perform calculations on two streams of data to increase efficiency and speed while running multiple programs and the new generation of multi-threaded software. AMD Athlon II Dual-Core processors deliver TRUE multi-tasking, allowing users to switch from one program to another without always pausing for the computer to catch up and reducing annoying processing pauses.
- Dual-core Technology
- 3.00Ghz clock speed (AM3 Socket)
- Multiplier unlocked
- 2.0MB L2 Cache
- Cool & Quiet Technology for Energy Efficiency
- Enhanced Virus Protection
- 64-bit Technology
- Hyper Transport Technology
- Virtualization technology
- 1yr Warranty
Was £49.99 Inc. VAT
Only £41.99 inc VAT.
ORDER NOW
AMD Bulldozer FX-8 Eight Core 8150 Black Edition 3.60Ghz (Socket AM3+) Processor - Retail with FREE Deus Ex PC Game @ £185.99 inc VAT
We call it the new AMD FX 8-Core Processor Black Edition and it's unlocked for your overclocking pleasure.1 Experience unmatched multitasking and pure core performance with the industry's first 32nm 8-core desktop processor featuring the all-new "Bulldozer" architecture. Get the speed you crave with AMD Turbo CORE Technology to push your core frequencies to the limit when you need it most. Go beyond the limits of maximum speed with easy-to-use AMD OverDrive™ and AMD Catalyst Control Center™ software suites. But the best part of all? You'll get all this impressive performance at an unbelievable price. You'll be asking yourself "what competition?" in no time.
- Multiplier Unlocked
- Eight Core Technology
- 3.60GHz Clock Speed
- 4.20GHz Turbo Clock Speed
- 5.2 GT/s System Bus
- AM3+ Socket
- 8MB L2 Cache
- 8MB L3 Cache
- 64-Bit Technology
- TDP: 125W
- Voltage: 0.9375v - 1.4125v
- 32nm technology
- Integrated memory controller upto 29.8GB/sec
- Support upto 1866MHz DDR3
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
- Supplied with FREE Deus-Ex PC Game (Subject to availability)
Was £199.99 Inc. VAT
Only £185.99 inc VAT.
ORDER NOW
Corsair Dominator 16GB (4x4GB) PC3-14900C9 1866MHz Dual/Quad Channel Kit (CMP16GX3M4X1866C9) **SPECIAL** @ £119.99 inc VAT
Dominator memory supports the Intel XMP (Extreme Memory Profile) standard, and each module is individually factory-programmed with an XMP profile indicating supported timing, frequency and voltages. Just enable XMP on your compatible motherboard and you’ll automatically get optimized memory overclocking without having to deal with multiple BIOS settings. Of course, if you’re an experienced overclocker, you can always adjust the settings on your own to push for even higher overclocking performance.
State-of-the-art cooling efficiency is essential for high-performance memory. Our DHX+ technology uses specially designed, high-quality heatsinks and a custom-designed PCB that cools the front and rear of the DRAM chips as well as the printed circuit board itself.
Your performance investment is protected. All of our memory products are backed by a limited lifetime warranty.
Features:-
- Ultra-high performance 16GB (4x 4GB) Domintaor® quad kit with Intel XMP 1.3 profile
- 16GB total capacity provides ample headroom for the most demanding user
- Outrageously fast 1866MHz performance.
- Ultra-low 9-10-9-27 latency
- Intel XMP (Extreme Memory Profile) support
- Limited Lifetime Warranty
- Compatible with Intel X79, Z68 and P67 platforms
- Speed: 1866MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
- Pin Voltage: 1.50-1.60V
Was £139.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Team Xtreem 16GB (4x4GB) DDR3 PC3-17000C9 2133MHz Dual/Quad Channel Kit (TXD316G2133HC9NQC-L) @ £119.99 inc VAT
Beyond than the shock of overclocking, Xtreem LV is joined by a new and powerful member, Xtreem DDR3 2133. Supported by IMC memory profile, Xtreem DDR3 2133 boasts outstanding efficiency and satisfies the 1.50V regulation to prevent high voltage from causing CPU damage. For the best quality, we only use original granules and with the exclusive granule screening technology, we insure the quality and stability of the materials. At the same time, we keep the strictest standards in quality control right from the compatibility test to pre-delivery test. Our quality is highly trusted by users. In addition, the memory module carries the unique X-shape heat radiation chipset and the high-coefficient conductive gel grabs the granules tightly to maximize the overall heat radiation efficiency and brings the Xtreem series the unique cool touch under extreme speed.
- Fully compatible with Intel P67, Z68, X58, x79-based DDR3 motherboards
- XMP Ready
- High frequency and Low latency
- RoHS Compliant
- Larger capacity:4 GB Kit (2GBx2), 8 GB Kit (4GBx2), 16 GB Kit (4GBx4)
- Equipped super thermal conduction heat spreader
- 100% Tested and Verified
- Lifetime Warranty
- Data transfer bandwidth: 17,000 MB/Sec (PC3 17,000)
- CL-value: 9-11-11-28
- Working voltage: 1.50-1.60V
Was £131.99 Inc. VAT
ORDER NOW
Kingston HyperX Genesis 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel (KHX1600C9D3K3/6GX) @ £29.99 inc VAT
HyperX DDR3 memory; the latest generation of DDR memory technology. Like all Kingston HyperX products, DDR3 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. DDR3 memory offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR2. HyperX DDR3 modules are available in single, dual and triple-channel memory kits.
Features:-
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL X58
CAS Latency: 9-9-9-27 2N
Capacity: 6GB (2GBx3)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.60-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Warranty: Lifetime
Was £35.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (CMZ8GX3M2A1866C9) @ £52.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1866MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1866MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1866MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-10-9-27 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Was £55.99 Inc. VAT
Only £52.99 inc VAT.
ORDER NOW
OcUK Value 8GB (2x4GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel Kit @ £23.99 inc VAT
OcUk Value Series Memory is designed to optimized the high performance DIMMs for reliability in order to ensure your system does not fail you resulting in great performance, compatibility and reliability.
Features:-
- Cas latency: 9-9-9-24-2N
- Capacity: 8GB (4GBx2)
- Speed: DDR3-1333 (PC3 10666)
- Test voltage: 1.5 Volts
- Type: 240-pin DIMM
- Warranty: Lifetime
Was £29.99 Inc. VAT
ORDER NOW
OcUK Value 8GB (1x8GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Single Channel Module @ £35.99 inc VAT
Features:-
- Capacity: 4GB (4GBx1)
Was £37.99 Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
Sapphire HD 7970 OC 3072MB GDDR5 PCI-Express Graphics Card @ £419.99 inc VAT
The SAPPHIRE HD 7970 OC Edition features SAPPHIRE’s new dual-extractor technology - Dual-X - a highly efficient multi-heatpipe cooler with dual fans providing quiet and very cool operation during normal operating conditions, and superb cooling performance even under extreme load. The HD 7970 from AMD is the most powerful single chip GPU ever built - it has a new internal structure with 32 compute units and a total of 2048 Stream processors. The SAPPHIRE HD 7970 OC Edition ships with a raised core clock speed of 950MHz, and 1425MHz for the memory. Its Dual BIOS switch allows users to select the higher performance settings of 1GHz core and 1450MHz memory, making the fastest card in its class. This setting also uses a more aggressive fan profile and raises the limits for maximum overclocking.
Features:-
- Fastest single GPU graphics card on the planet
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 1000MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5800MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 6-pin
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- 3yr Warranty
Was £429.95 Inc. VAT
Only £419.99 inc VAT.
ORDER NOW
HIS HD 7950 3072MB GDDR5 PCI-Express Graphics Card @ £323.99 inc VAT
The World's first 28nm GPU. The revolutionary new GCN Architecture. Ready for DirectX 11.1. PCI Express 3.0. The AMD Radeon™ HD 7950 is your personal checklist for ground-breaking technology. The next generation of AMD Eyefinity technology is here, featuring all-new support for stereo 3D, universal bezel compensation and brand new display configurations. Face it: the best just got better. Armed with the new PCI Express 3.0 standard, multi-GPU configurations with AMD CrossFire™ technology are just another way to obliterate the competition with the revolutionary AMD Radeon™ HD 7950. Leave no performance behind. Get higher clocks and faster gaming with AMD PowerTune technology on AMD Radeon™ HD 7950 Graphics. Fold and mine faster than ever with AMD App Acceleration powered by the unprecedented 28nm GCN Architecture. The market isn't ready for 4K video, but Radeon™ is. With full support for 3GHz HDMI 1.4a and DisplayPort 1.2 HBR2, the AMD Radeon™ HD 7950 is set for Quad HD.
- Core Clock: 800MHz
- Memory: 3072MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 1792
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 2 Years
Was £329.99 Inc. VAT
Only £323.99 inc VAT.
ORDER NOW
VTX3D HD 7850 2048MB GDDR5 PCI-Express Graphics Card with FREE Dirt3 PC Game @ £182.39 inc VAT
With continued demand for increased graphics horsepower to support more visually intensive games, the AMD Radeon HD 7800 Series is set to power the next generation of games and applications. And for those looking to upgrade to a next-generation graphics card, the AMD Radeon HD 7800 Series is the ideal choice.
- Core Clock: 860MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1024
- HDCP Capable
- DirectX 11.1 Support
- OpenGL 4.2 Support
- ATI Avivo HD
- Warranty: 2 Years
- Supplied with FREE Dirt3 PC Game download voucher
Was £194.99 Inc. VAT
Only £182.39 inc VAT.
ORDER NOW
Sapphire HD 7870 2048MB GDDR5 PCI-Express Graphics Card @ £257.99 inc VAT
The new SAPPHIRE HD 7800 series of graphics cards is based on the third family of GPU’s from AMD built in its new 28nm process and featuring the highly acclaimed GCN graphics processing architecture.
The Sapphire HD 7870 GHz Edition is equipped with 2GB of the latest GDDR5 memory clocked at 1200MHz (4.8Gb/s effective) with the new dual-extractor technology - Dual-X - a highly efficient multi-heatpipe cooler with dual fans providing quiet and very cool operation during normal operating conditions, and superb cooling performance even under extreme load.
Features:-
- Core Clock: 1000MHz
- Processing Cores: 1280
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI Avivo HD
- Warranty: 2 Years
Was £274.99 Inc. VAT
Only £257.99 inc VAT.
ORDER NOW
Asus GeForce GTX 580 DirectCU II 1536MB GDDR5 PCI-Express Graphics Card @ £323.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX580 DCII to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 782MHz (reference 772MHz), allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX580 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX580 DCII/2DIS/1536MD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Voltage Tweak Technology
- Super Alloy Power: Provides 15% performance increase, 2.5 times longer product lifespan and 350C cooler operation.
- Gamer OSD: Real-time overclocking, benchmarking and video capturing in any PC game!
- Splendid: Watching movies on PC is as good as on Top-of-the-line consumer television
- Core Clock: 782MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Processing Cores: 512
- Shader Clock: 1544MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
- The card size is 10.24" x 4.84" x 1.58" inch
Was £339.95 Inc. VAT
ORDER NOW
Gainward GeForce GTX 580 "Phantom" 3072MB GDDR5 PCI-Express Graphics Card @ £341.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Instead of fans on its obverse side blowing air onto the PCB, there are three fans on its reverse side, drawing air from the aluminum fin array, and onto the PCB. The PCB also seems to be a non-reference design.
Features:-
- Core Clock: 783MHz (Fermi GF110)
- Memory Clock: 4020MHz (Effective)
- Shader Clock: 1566MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was £349.99 Inc. VAT
Only £341.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 570 Phantom 1280MB GDDR5 PCI-Express Graphics Card @ £227.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
Features:-
- Core Clock: 750MHz
- Memory: 1280MB GDDR5
- Memory Clock: 3900MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1500MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 years
Was £239.99 Inc. VAT
Only £227.99 inc VAT.
ORDER NOW
Asus GeForce GTX 560Ti DirectCU II TOP 1024MB GDDR5 PCI-Express Graphics Card @ £173.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX560 Ti DCII TOP to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 900MHz, allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX560 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX560 Ti DCII TOP/2DI/1GD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Core Clock: 900MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4200MHz (Effective)
- Processing Cores: 384
- Shader Clock: 1800MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £179.99 Inc. VAT
Only £173.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 560Ti "Phantom" 1024MB GDDR5 PCI-Express Graphics Card @ £167.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560Ti - arm yourself for battle.
Features:-
- Core Clock: 835MHz
- Memory Clock: 4050MHz (Effective)
- Shader Clock: 1670MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £169.99 Inc. VAT
Only £167.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 560Ti "Phantom" 2048MB GDDR5 PCI-Express Graphics Card @ £215.99 inc VAT
Features:-
- Core Clock: 822MHz
- Shader Clock: 1644MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £219.95 Inc. VAT
Only £215.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 560 2048MB GDDR5 PCI-Express Graphics Card @ £161.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560 - arm yourself for battle.
Features:-
- Microsoft DirectX 11 support
- DirectCompute 5.0 and OpenCL support
- One dual-link DVI-I?Display Port and one mini-HDMI 1.4a connectors
- Dual-link HDCP Capable
- Core Clock: 810MHz
- Processing Cores: 336
- Shader Clock: 1620MHz
- SLI Ready
- HDCP Capable
- OpenGL 4.1 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 years
Was £167.99 Inc. VAT
Only £161.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 480 1536MB GDDR5 PCI-Express Graphics Card (015-P3-1480-KR) @ £179.99 inc VAT
Next generation gaming has arrived. Nvidia GeForce GTX 480 gives your games an adrenaline shot with the world's fastest performance and futuristic, visually stunning graphics. Experience heartpounding, cinematic visuals on your favorite games with the combined power of DirectX 11, CUDA and Nvidia PhysX technologies. And expand your visual real estate across three HD displays in jawdropping stereoscopic 3D for the ultimate in immersive gaming. Nvidia GeForce GTX 480: pure adrenaline meets visual bliss.
- EVGA Precision Tuning Utility
- Core Clock: 700MHz
- Memory Clock: 3696MHz (Effective)
- Shader Clock: 1401MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.3a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- OpenGL 3.1 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 years standard warranty
Was £184.99 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 460 Superclocked FTW 1024MB GDDR5 PCI-Express Graphics Card (01G-P3-1363-KR) @ £115.19 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Core Clock: 867MHz
- Memory Interface: 192-Bit
- Shader Clock: 1734MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years (If registered within 30 days of purchase)
Was £119.99 Inc. VAT
Only £115.19 inc VAT.
ORDER NOW
Asus VE228H 22" Widescreen LED Multimedia Monitor - Black @ £119.99 inc VAT
Full HD 1080p Visual Enjoyment Together with HDMI Interface. Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 5 preset video modes (Scenery, Theater, Game, Night View, and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 21.5"(54.6cm) Wide Screen
- True Resolution : 1920x1080
- Pixel Pitch : 0.248mm
- Brightness(Max) : 250 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 10000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 5ms
- Display Colors : 16.7M
- Video Feature SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 5 Modes
- Skin-Tone Selection : 3 Modes
- Color Temperature Selection : 5 Modes
- HDCP support
- Audio Features Stereo Speakers : 1W x 2 Stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI ,D-Sub,DVI-D
- PC Audio Input : 3.5mm Mini-Jack
- AV Audio Input : HDMI 1.3
- Earphone jack : 3.5mm Mini-Jack
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Power Consumption Power Consumption < 30 W
- Power Saving Mode < 1 W
- Mechanical Design Chassis Colors : Black
- Tilt : +20°~-5°
- VESA Wall Mounting : 100x100mm
- Security Kensington lock
- Dimensions Phys.Dimension(WxHxD): 512.84x385.96x201mm
- Box Dimension(WxHxD): 576x468x148mm
- Weight Net Weight (Esti.): 4.1 kg
- Gross Weight (Esti.): 6.1 kg
- Accessories DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Regulation Approval Energy Star 5.0, CEL, UL/cUL, CB, CE, EuP, FCC, CCC, BSMI, Gost-R, C-Tick, VCCI, PSB, J-MOSS, WEEE, Windows Vista & Windows 7 WHQL
Was £124.99 Inc. VAT
ORDER NOW
BenQ G2222HDL 21.5" Widescreen LED Monitor - Black @ £99.98 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2222HDL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 504.6mm x 392.9mm x 175.0mm
- Weight: 3.8kg
- Warranty: 2 Years On-Site
Was £109.99 Inc. VAT
Only £99.98 inc VAT.
ORDER NOW
BenQ RL2240H 22" Widescreen LED Monitor - White @ £107.99 inc VAT
The RL2240H is a professional gaming monitor suited for RTS game play. Co-designed with the renowned StarCraft II team, StarTale, this 21.5” LED backlight monitor is packed with the latest features: the Black eQualizer, RTS mode, Display mode, Smart Scaling, 2ms GTG, HDMI and 12M:1 dynamic contrast ratio.
Built to set the benchmark for RTS gaming monitors, the RL2240H is a true testament to the belief that 'gaming is in the details'. Each and every feature has been meticulously thought out and created together with the renowned StarCraft II team, StarTale, to provide RTS gamers with vital visibility and command to take their performance to new heights.
The collaboration successfully brought together prominent players from StarTale and tapped into their wealth of knowledge and insights to create the ultimate gaming monitor that can handle real-time strategy games. Professional gamers like Rainbow, July, Ace, Bomber, Squirtle and Virus provided BenQ with insider perspectives on details that were essential to winning a game. The recent achievements from individual StarTale gamers include winning Clash of the Houses, IEM World Championship, Intel Extreme Masters Season 5 and GSTL league play.
The Black eQualizer is an exclusive feature that meets the demands of gamers when it comes to unprecedented level of control and visibility. Via finely designed color engine technology, dark scenes are brightened without over-exposing white levels, allowing gamers to acquire critical combat details and information and react quickly. Don’t let poor visibility and judgment cost you the game.
During product development and testing stages, BenQ's product team and the StarTale players exchanged several visits to fine-tune the display performance of the RL2240H for better accessibility and comfort. What they came up with is the preset RTS mode that automatically adjusts your monitor calibrations accordingly for optimum RTS gaming. This out-of-the-box setting allows you to see your enemies more visibly among the distractions and darkened areas. See what the professional gamers see and get the competitive edge you need with optimized color and contrast exposures. The exclusive preset RTS Mode will be your ultimate secret weapon.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your liking and to simulate any in-game experience. Interchange instantly between four different screen sizes from 17", 19" and 19"W to 21.5" using the Display Mode. Or take advantage of the Smart Scaling feature and enjoy the flexibility to freely scale the screen content to any custom size. You can certainly use the two features together to get the best possible view for any application or game.
Fast response time of 2ms GTG means speed without the smear. Fast-moving action and dramatic transitions will be rendered smoothly - without smearing or ghosting. Control your gaming destiny and don’t leave it in the hands of sluggish display.
The RL2240H comes in a sleek white housing that was favored by StarTale_July. Be the envy of all the other gamers as you sport the RL2240H with fluid lines and distinct curves.
Features:-
- Screen Size: 21.5”W
- Aspect Ratio: 16:9
- Resolution (max.): 1920x1080
- Brightness ( typ.): 250 cd/m2
- Contrast ( typ. ): 1000:1
- DCR (Dynamic Contrast Ratio) (typ.): 12M:1
- Viewing Angle (L/R;U/D) (CR>=10): 170/160
- Response Time(Tr+Tf) typ: 2ms GTG
- D-sub/DVI/HDMI/Headphone Jack
- 2yr Warranty
Was £113.99 Inc. VAT
Only £107.99 inc VAT.
ORDER NOW
IIyama Prolite E2273HDS 22" Widescreen LED Monitor - Black @ £119.99 inc VAT
The ProLite E2273HDS is a LED-backlit monitor. It is a full 1920x1080 high definition 22” display that features all the benefits this technology affords. Extremely slim and stylish in design, it has a narrow bezel and is finished in the latest glossy-black. The high specifications of the monitor include 5,000,000:1 ACR, fast 2ms response for excellent sharpness in high definition video and triple input connectivity (including HDMI). Power consumption is only 21W typical usage and 0,5W in standby.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
With true 1920 x 1080p resolution your LCD is ready to display any high definition images. It also offers you much more viewable area than a standard LCD with 1280 x 1024 resolution.
Contrast Ratio is a measurement of this difference between the blackest black and the whitest white your LCD can display. Advanced Contrast Ratio is a feature that automatically adjusts the contrast and brightness based on the darkness of the image. The higher the ratio, the better your screen will look when you have the lights off in a room.
This LED monitor is equipped with two high quality stereo speakers. HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
Features:-
- LED Backlit
- Brightness: 300cd/m²
- Response Time: 2ms
- Inputs: 1 x Analogue, 1 x DVD-D, & 1 x HDMI
- Dimensions: 268.1 x 476.6 mm; 10.6" x 18.8"
- Weight: 2.9kg
- Warranty: 3 Years On-Site
Was £129.95 Inc. VAT
ORDER NOW
BenQ G2420HDBL 24" Widescreen LED Monitor - Black @ £143.99 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2420HDBL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 24" Widescreen
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
- Weight: 4.4kg
Was £149.99 Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
Asus VG278H 27" TRUE 120Hz 3D Widescreen LED Monitor with NVIDIA 3D Vision 2.0 Glasses - Black @ £479.99 inc VAT
Enter an immersive 3D full HD 1080p world of games and movies with the VG278H. Through the use of the world's first NVIDIA® 3D Vision™ 2 glasses technology, it instantly takes you into another dimension - transforming all your gaming experiences and movies to 3D. With its new technology, it delivers twice sharper 3D images than conventional 3D technology. There are more than five hundreds popular PC game titles* currently compatible with the NVIDIA® 3D Vision™ Kit.
With the latest NVIDIA® 3D LightBoost™ Technology, enjoy twice the brightness of conventional 3D technology in 3D mode with zero increase in total energy consumption. It's perfect for dark-color games such as Metro 2033 and Batman: Arkham City. Additionally, the redesigned glasses bundled with NVIDIA® 3D LightBoost™ Technology features a 20-percent larger viewing lens, a light blocking visor for comfortable viewing and more comfortable - gamer-inspired design.
Supported by Trace Free II Technology, the VG278H is able to double the refresh rate to 120 frames per second, which is twice faster than generic LCD monitors, delivering ultra-smooth 3D visuals. Moreover, the response time is now reduced to 2ms to eliminate tracing and ensure crisp and clear video playback.
The VG278H reduces LCD charging time to further prevent mura, ghosting, and bright-line effects, and delivers clear motion scenes during 3D gaming and movie watching. Splendid™ Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters accordingly to ensure the color accuracy and image fidelity. Six preset video modes (Scenery, Theater, Game, Night View, sRGB, and Standard) can be selected via a hotkey. he VG278H is specially designed with swivel, tilt and height adjustment to suit your preferred viewing angles in 3D gaming and movie watching. The angle-adjustable 3D emitter optimizes 3D for every scenario; simply switch between three IR signal coverage areas via OSD menu and aim the angle-adjustable 3D emitter at shutter glasses for maximum 3D reception. Display stereoscopic 3D via Blu-ray Disc players or game consoles through HDMI 1.4 output. The VG278H offers high compatibility with any media devices with HDMI 1.4, dual-link DVI-D, and D-sub.
Features:-
- Uncompromised 27” 3D immersion with NVIDIA® 3D Vision™ 2 glasses and 3D LightBoost™
- Ultra smooth action with 120Hz refresh rate and 2ms tracer-free
- Vivid color performance with Splendid™ Video Intelligence Technology
- Ergonomic design for swivel, tilt angle, and height adjustment
- Extensive connectivity with HDMI 1.4, dual-link DVI-D, and D-sub
- Panel Size: Wide Screen 27.0"(68.6cm) 16:9
- Full HD 1080P : Yes
- Pixel Pitch : 0.311mm
- Brightness(Max) : 300 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 50000000:1
- Response Time : 2ms (Gray to Gray)
- Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 6 Modes (sRGB Mode/Scenery Mode/Theater Mode/Standard - Mode/Night View Mode/Game Mode)
- Color Temperature Selection : 4 Modes
- HDCP support
- Stereo Speakers : 3W x 2 Stereo RMS
- Signal Input : HDMI , D-Sub, Dual-link DVI-D (support NVIDIA 3D Vision)
- AV Audio Input : HDMI 1.4
- Audio Output : HDMI 1.4
- Chassis Colors : Black
- Tilt : +15°~-5°
- Swivel : Yes
- Height Adjustment : Yes
- Kensington lock
- Phys.Dimension(WxHxD): 643x460x220mm
- Net Weight (Esti.): 8 kg
- Dual-link DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Nvidia 3D Vision Kit
- 3yr Warranty
Was £499.99 Inc. VAT
Only £479.99 inc VAT.
ORDER NOW
BenQ G2750 27" Widescreen LED Monitor - Black @ £179.99 inc VAT
An enjoyable addition to your everyday home or work life, the G2750 gives you crisp and accurate viewing at all times. The G2750 comes with a dynamic contrast ratio of 50000:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games. The G2750 supports the Full HD 1080p with 16:9 aspect ratio - allowing the subtlest details to stand out with richer, more realistic colors, making your viewing experience even more absorbing. Experience the truest colors of the world with the BenQ Senseye® Human Vision Technology. With the help of its six proprietary calibration techniques, Senseye® 3 delivers only the best viewing quality in each of its six pre-set viewing modes –Standard, Movie, Game, Photo, sRGB, and Eco – with the Eco Mode especially designed to save power and money. The G2750 has passed Windows® 7 certification and are fully compatible with Windows® 7 color systems. Plug in the G2750 to your computer, and Windows 7 will recognize it instantly, making setup and connection effortless.
- Screen Size 27"W
- Resolution (max.) 1920 x 1080
- Pixel Pitch 0.276 mm
- Brightness 300 cd/m2
- Contrast Ratio 1200:1
- DCR:50,000:1
- Response Time (tr/tf) 5 ms
- Display Area 597.6 x 336.15 mm
- Display Color 16.7 million
- Viewing Angle (L/R;U/D) (CR>=10) 170 / 160
- Terminals D-sub / DVI-D
- Horizontal Frequency (Max) KHz 30 ~ 83
- Vertical Frequency (Max)Hz 50 ~ 76
- Video Bandwidth (MHz) 205
- Colour Temperature Reddish / Normal / Bluish / User mode
- Power Consumption 52W (max)
- Auto Switching Power Supply Built-in
- Features Senseye® Human Vision Technology (plus Senseye 3)
- HDCP Support
- OSD Language: 17 languages
- Windows 7® compatible
- K locker: yes
- Adjustments Tilt (down / up) -5 / 15
- Dimensions (HxWxD) 488.5 x 654.4 x 191.2 mm
- Weight Net weight: 6.4 kg.
- Gross weight: 8.12 kg.
- Accessories (Standard) VGA
- Product Colour Glossy Black
- Vista Certification Premium
- VESA Wall Mounting 100 x 100 mm
- 2yr Warranty
ORDER NOW
MSI CR640-066UK 15.6" HD, Intel Core i3-2310M, 2GB DDR3, HDMI Laptop, Windows 7 Home Premium Edition Laptop - Silver @ £395.99 inc VAT
nonl2br
<b>Processor</b> Intel® Core™ i3-2310M Dual Core (2.1GHz, Intel Sandy Bridge Architecture, 3MB Cache) <br>
<b>Screen</b> 15.6" (1366 x 768 HD Resolution) <br>
<b>Operating System</b> Windows 7 Home Premium Edition 64-bit <br>
<b>RAM</b> 2GB (DDR3 1333MHz) <br>
<b>Hard Drive</b> 320GB <br>
<b>Optical Drive</b> DVD Rewriter (Records DVDs 8x & CDs 24x & Dual Layer Super Multi) <br>
<b>Graphics</b> Integrated (Intel® HD 3000 Graphics with up to 1274MB Shared Memory) <br>
<b>Wireless LAN</b> Wireless (802.11b/g/n Wireless) <br>
<b>Network Card</b> 10/100/1000 Gigabit Fast Ethernet <br>
<b>Integrated Webcam</b> Integrated Webcam with Microphone <br>
<b>Card Reader</b> 5-in-1 card reader (SD//MS/MS-Pro/MMC/xD-Picture card™) <br>
<b>USB Ports</b> 2x USB 2.0 ports <br>
<b>Speakers</b> Integrated Sound System <br>
<b>VGA Port</b> 1 External VGA Port <br>
<b>Charge Time</b> 2.5 Hours <br>
<b>HDMI</b> 1x HDMI Port <br>
<b>Warranty</b> MSI 1 Year Collect & Return Warranty <br>
<b>Battery Life</b> 5-6 Hours (up to 6 hours with power management) <br>
Was £407.99 Inc. VAT
Only £395.99 inc VAT.
ORDER NOW
OcUK Tech Lab - V8 Watercooling Kit 240 @ £190.18 inc VAT
Until now, watercooling has been off-putting.
The costs involved and the myriad of choices available can be confusing to newcomers who crave the high performance, silence and gorgeous aesthetics that a watercooled system provides.
In the past, Watercooling Kits have nearly always had cheap, low quality parts in the box that are prone to failure or were generally low quality.
OcUK have stepped in and solved this problem. With each OcUK Kit you get everything you need to watercool your PC along with full installation instructions. this means you cant go wrong. You don't run the risk of ordering the wrong parts, and you are assured out of the box compatibility.
Pair this with the Ultra High End performance of EK products and you have the quick and easy solution you need to gain those extra MHz
Ideal for first time watercooling enthusiasts and seasoned veterans alike.
Component List:
1X XSPC EX240 120mm Radiator
Ultra high air flow and innovative built in shroud design offers uncompromised performance that is second to none.
1X EK DCP 4.0 Pump
A superb all round pump with a small footprint inside the case
1X EK Reservoir Combo DCP 4.0
A powerful aftermarket top and reservoir combo to ensure maximum performance from your Pump
1X EK Supreme HF CPU Waterblock - Copper Plexi
The most popular waterblock on the planet, and for good reason. A mixture of market leading performance and superb build quality. It's called the 'Supreme' for a reason!
2X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fans
The most recognised performance fans for watercooling radiators.
1X Mayhems Coolant
Pick your own coolant that suits your taste and style
1X XSPC 7/16" ID [16/11mm] Clear
High quality watercooling tubing with a superb bend radius
6X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Shining Silver Finish
Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.
IMPORTANT:
Kit is easy to install, use and maintain (thorough installation manual is available on our forums).
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3
***NOTE***
Our Custom Watercooling Kits and Cases are configured in house by our technicians. We endeavour to keep stock of all items at all times.
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.
Custom Units can take 24 to 48 hours if assembly of a component is required.
Whilst we endeavour to keep watercooling stock levels high for our watercooling systems, there may be some occasions where stock shortages mean that there will be a delay in completing your order. If this is the case, then our sales team are able to suggest alternative components to allow your order to be completed.
Was £194.98 Inc. VAT
Only £190.18 inc VAT.
ORDER NOW
OcUK Tech Lab - V12 Watercooled Case - BitFenix Shinobi XL Full Tower - Black @ £423.58 inc VAT
nonl2brAssembled by Expert OcUK Technical Staff, the V12 range of Pre-Watercooled cases brings you exceptional performance paired with incredible value for money! </br></br>
The OcUK Watercooled Case range comes pre-assembled for your convenience. All of the difficulty of watercooling has been removed and allows you to enjoy the best performance without the hassle.</br></br>
All of our pre-watercooled cases are built to order and come pre filled ready for you to build your dream system.</br></br>
The system is shipped with Clear Mayhems Ultra Pure Fluid. If you prefer us to use a coloured fluid or specialist liquid, you can choose from a wide range</br></br>
All you need to do is build your PC and install the waterblock which is just as easy to do as mounting any CPU cooler.</br></br>
All leak testing and filling is carried out by our technical staff which means that the watercooling system is ready to use by you when it arrives. All that is required is for you to plug the pump and fans into your power supply.</br></br>
<strong>PLEASE CHOOSE THE CORRECT MOUNTING BRACKET FOR YOUR CPU</strong></br></br>
We've taken our battle-proven Shinobi design and expanded it, creating a roomy, feature-packed full tower enclosure that will not only turn heads, but take them clean off. The larger size enables you to outfit your Shinobi XL with the latest fear-inducing hardware, including XL-ATX motherboards and the longest graphics cards. Shinobi XL can accommodate up to two 360mm radiators, making it ideal for water cooling enthusiasts. Four SuperSpeed USB 3.0 ports and the all-new BitFenix SuperCharge™ port keep your peripherals and mobile devices ready for battle, while the BitFenix FlexCage™ hard disk rack adds to the Shinobi XL's nimbleness. With three included Spectre™ fans, tool-free drive locking, filtered intakes and signature BitFenix SofTouch™ Surface Treatment, Shinobi XL is the chassis you need when vengeance is not enough.</br></br>
- Dimensions (HxWxD): 570 x 245 x 557mm (ATX Full Tower)</br>
- Motherboard Sizes: Mini-ITX, mATX, ATX, XL-ATX</br>
- 5.25” Drive Bays: x 5</br>
- 3.5” Drive Bays: x 7</br>
- 2.5” Drive Bays: x 8 (using 3.5" drive bays and 5.25" adapter)</br>
- Cooling Front: 1 x 230mm (included), or 3 x 120mm (optional)</br>
- Cooling Rear: 1 x 120mm (included), or 1 x 140mm (optional)</br>
- Cooling Top: 2 x 230mm (x 1 included), or 3 x 120mm (optional)</br>
- Cooling Bottom: 2 x 120mm (optional)</br>
- PCI Slots: 9</br>
- I/O: 1 x SuperChargeTM, 4 x USB 3.0, HD Audio</br>
- Power Supply: PS2 ATX (bottom, multi direction)</br>
- Extras: Superior watercooling support, FlexCage™, SofTouch™ Surface Treatment, filtered intakes, tool-free drive locking</br>
- Maximum CPU Cooler Height: 193mm</br>
- Maximum Expansion Card Length: 377mm (with HDD cage) / 492mm (with HDD cage removed)</br>
- Maximum MB Tray Clearance (rear): 34.5mm</br></br>
<strong>Component List:</strong></br></br>
1X BitFenix Shinobi XL Full Tower Gaming Case - Black</br>
The brand new king of watercooling cases offering excetional hardware layout options and space for expansion, this case is futureproof to the next level!</br></br>
1X Hardware Labs Black ICE SR-1 360 Radiator</br>
Ultra high air flow and innovative built in shroud design offers uncompromised performance that is second to none.</br></br>
1X EK Supreme HF CPU Waterblock - Copper Plexi</br>
The most popular waterblock on the planet, and for good reason. A mixture of market leading performance and superb build quality. It's called the 'Supreme' for a reason!</br></br>
1X Alphacool Laing D5 Vario Pump 655</br>
The Best watercooling pump on the market. Needs little introduction.</br></br>
1X Alphacool HF D5 TOP - Black Acetal G1/4</br>
The ultimate top for your pump offers even better performance as well as more mounting and connective possibilities</br></br>
1X Phobya Single 5.25” Bay Reservoir</br>
Single bay reservoir for installation into the 5.25" optical drive bay.</br></br>
8X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Shining Silver Finish</br>
Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.</br></br>
1X XSPC 7/16" ID [16/11mm] High Flex Hose - Clear</br>
High quality watercooling tubing with a superb bend radius</br></br>
3X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fans</br>
The most recognised performance fans for watercooling radiators.</br></br>
Supported sockets:</br>
- Intel Socket 775</br>
- Intel Socket 771</br>
- Intel 1366 Socket</br>
- Intel 1156 Socket</br>
- Intel 1155 Socket</br>
- Intel 2011 Socket</br>
- AMD Sockets: 939, 754, 940</br>
- AMD Sockets: AM2, AM2+, AM3</br></br>
<a href="http://www.techpowerup.com/reviews/Bitfenix/Shinobi_XL/" target="_blank"><img src="http://www.overclockers.co.uk/LP/productimages/reviewlogo/tech_powerup_recommeded.jpg"></a>
</br></br>
***NOTE***</br>
Our Custom Watercooling Kits and Cases are configured in house by our technicians. We endeavour to keep stock of all items at all times.</br>
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.</br>
Custom Units can take 24 to 48 hours if assembly of a component is required.</br></br>
Whilst we endeavour to keep watercooling stock levels high for our watercooling systems, there may be some occasions where stock shortages mean that there will be a delay in completing your order. If this is the case, then our sales team are able to suggest alternative components to allow your order to be completed.</br>
Was £425.98 Inc. VAT
Only £423.58 inc VAT.
ORDER NOW
Plantronics GameCom 780 7.1 Surround Sound USB Gaming Headset @ £38.78 inc VAT
The Plantronics GameCom 780 USB headset with Dolby technologies transforms standard audio into a stunning 7.1 surround sound experience.
The noise-cancelling microphone kills background noise so your commands are loud and clear. When you need to take a break, built-in spin joints let the earpods lay flat for easy storage.
Need to adjust volume? No problem. The controls are right on the earpods so you'll always have eyes on.
The GameCom 780 is built to last with superhero-strength cords and joints; ultra-comfortable ear cushions and headband let you stay in the game for as long as it takes.
• Dolby Headphone and Pro Logic IIx technologies transform standard audio into a stunning 7.1 surround sound experience
• 40mm speakers pound out deep bass and immersive stereo sound
• Built-in spin-joints let the earpods lay flat for easy storage when you need to take a break
• Noise-cancelling microphone kills background noise so your team or opponents can clearly hear your commands
• Easy-to-reach on-ear volume and mute buttons let you adjust the sound and still keep a hand on the controls
• Superhero-strength cords and joints mean this USB headset will be around for all your battles
• Ultra-comfortable ear cushions and headband make the GameCom 780 perfect for gaming, and great for watching videos, listening to music, and making PC voice calls.
Was £39.98 Inc. VAT
Only £38.78 inc VAT.
ORDER NOW
Logitech G35 Gaming USB Headset PC 7.1Ch Surround Sound @ £89.76 inc VAT
The Logitech G35 headset. Game-changing immersion with 7.1 surround sound powered by Dolby technology for a detailed soundfield - hear your enemies before they see you. Featuring three swappable headband pads so you can choose the best fit, for long-lasting comfort; three customizable G keys for one-touch command over music, voice morphing, and more; on-ear audio controls for quick access to volume, microphone mute, and surround sound adjustments; and an adjustable, noise-canceling microphone that focuses on your voice and reduces background noise.
- 7.1 surround sound powered by Dolby technology delivers a detailed soundfield - hear your enemies before they see you.
- Three swappable headband pads let you choose the best fit, for long-lasting comfort.
- Three customizable G keys give you one-touch command over music, voice morphing, and more.
- On-ear audio controls provide quick access to volume, microphone mute, and surround sound adjustments.
- Adjustable, noise-canceling microphone focuses on your voice and reduces background noise.
- 2-years limited warranty
Was £90.98 Inc. VAT
Only £89.76 inc VAT.
ORDER NOW
Plantronics GameCom 777 USB 7.1 Surround Sound Headset @ £40.79 inc VAT
This open-eared headset with 7.1 Dolby Headphone technology gives you an unparalleled audio advantage that lets you hear your opponents before you see them. Connect with the Dolby USB sound card for a true 7.1 experience. But if needed, an analogue connection is also provided. Stay comfortable with a lightweight frame and specially designed ear pods that redistribute pressure. When you’re ready to fire off orders, unveil the hidden, noise-cancelling mic boom to strategize clearly with team members. Responses coming in? Adjust audio levels using in-line volume and mic-mute controls.
- Dolby Headphone technology delivers a 5-channel audio experience.
- Dolby USB sound card is the only way to get the 7.1 experience. If needed, an analog connection is also provided.
- Open-ear design keeps you connected to the game and your surroundings.
- Concealed mic boom stays hidden until you’re ready to use it.
- Specially designed ear pods redistribute pressure for maximum comfort.
- In-line volume and mic-mute controls allow for easy audio adjustment.
- Noise-cancelling microphone lets you communicate clearly.
- Rugged, military-grade design and extra-strength cables make your hardware hardcore.
Was £49.99 Inc. VAT
Only £40.79 inc VAT.
ORDER NOW
Steelseries Siberia v2 Gaming Headset - Green (51120) @ £67.58 inc VAT
Based on the award-winning SteelSeries Siberia Full-size Headset, the v2 features major enhancements in sound quality, comfort and its microphone. Every element of the v2 has been optimized for pro gaming, making the headset a preferred piece of equipment for the worlds' best competitive PC gamers - the most demanding headset users in the world.
Sporting 25% larger 50mm driver units, the SteelSeries Siberia Full-size Headset dramatically boosts overall acoustic performance. Experience a rich and detailed soundscape from immersive atmospheric background music to precise 3D positional sounds of footsteps, gunfire and more.
The close type ear cups feature thick leather padded cushions built from sound dampening foam, designed to offer passive noise reduction from loud surroundings and improve comfort over prolonged use. A virtually invisible uni-directional microphone can be retracted from the left ear cup, optimized for essential voice communications.
The v2 remains lightweight and its trademark headband suspension construction makes it extremely comfortable for use over long periods of time.
- Closed type headphones.
- Pull-out microphone.
- Crystal clear high, low and mid-tones.
- 50mm driver units.
- Lightweight suspension construction.
- Integrated volume control located on the cord.
- 2 years warranty
Was £69.98 Inc. VAT
Only £67.58 inc VAT.
ORDER NOW
TT Esports Shock One 5.1 Headset @ £53.98 inc VAT
The Shock One is designed with performance and comfort in mind, featuring DTS 5.1 channel virtual surround sound, dynamic 40mm speaker drivers, a leather headband pad and multiple ear-pad cushions for enhanced comfort. The new headset has a black and red color scheme, complete with an illuminated Thermaltake logo. The Shock One also includes ten headband settings for the perfect fit, along with a noise-canceling microphone, a 3m cable and a gold-plated USB connector. An in-line control box allows easy changing of volume and microphone settings.
• Driver unit: 40mm
• Frequency Response: 20Hz~20 KHz
• Impedance: 32 ohm
• Sensitivity: 114+/-3dB
• Max. input: 100mW
• Cable length: 3m
• Connector: USB
Was £59.98 Inc. VAT
Only £53.98 inc VAT.
ORDER NOW
Energy Sistem Energy DJ 600 Professional DJ Headphones, Black @ £38.99 inc VAT
Cutting-edge design in anodized alloy with breakneck bass response and crystal clear sound, these headphones provide an exceptional listening experience. Hours of listening pleasure thanks to extra large injected foam pads and its wide flat headband. Compatible with iPod and iPhone.
• Extra Large Foam Pads
• Maximum Comfort And Lightweight
• Gold Plated 3.5mm Jack
• Crystal Clear Sound
• Deep Bass Response
• Enclosed Dynamic Circumaural Headphones
• Guarantee: 36 Months
Was £44.99 Inc. VAT
Only £38.99 inc VAT.
ORDER NOW
Logitech C210 1.3 Megapixel USB Webcam @ £13.44 inc VAT
Anyone can make a video call with a video-calling application built right into your webcam setup.
Free, fast calling
Logitech Vid™ HD is free, fast and easy for you and anyone you call. It sets up when you set up the webcam.
The real you
Your loved ones will see you in lifelike color when you talk to them, or you can take photos to share later.
It fits
The universal clip lets you attach your webcam to your notebook or LCD monitor—or sit it on a shelf or desk.
Includes Logitech Vid™ HD
Now video calling is free, fast and easy for you and anyone you want to talk to. It’s built into your webcam setup, so you can call right away.
Clear video calls
With your webcam’s VGA sensor, the people you care about will see you in lifelike color.
1.3-megapixel photos
It’s easy to take snapshots at up to 1.3 megapixels (software enhanced)
Universal clip
It’s easy to take snapshots at up to 1.3 megapixels (software enhanced). You can attach your webcam securely to a notebook or LCD monitor, or sit it on a shelf or desk.
Free video editing software
Logitech has teamed up with MAGIX to offer MAGIX™ Photo Manager 9 and MAGIX™ Video Easy with your new Logitech webcam. And they’re free.
Built-in mic with RightSound™
It gives you clear conversations without annoying background noise.
RightLight™ technology
It automatically adjusts the image during your call, so you look your best even in dim light.
IM compatibility
Works with Skype™, Windows Live™ Messenger, Yahoo!® Messenger, AOL® Instant Messenger (AIM®) and other popular instant messaging applications.
Was £13.98 Inc. VAT
Only £13.44 inc VAT.
ORDER NOW
Creative Live! Cam Socialize 1.3 Megapixel Webcam With Built In Microphone @ £17.98 inc VAT
Make instant messaging come alive with the Live! Cam Socialize webcam and Live! Central 2 software!
The software lets you add a little spice to your conversations with dramatic voice effects and funny visual effects. Communicating and connecting with friends and family have also been made easier with a host of different features. The Live! Contacts button brings up your online contact list instantly so that you can start chatting right away while the Media Show and Desktop Share features let you share your pictures, presentation slides and videos through popular instant messaging services.
Equipped with a built-in noise-canceling microphone, engage in clearer voice chats with reduced background noise, while basking in better face-to-face interactions with the new low-profile design.
- Sensor: VGA (640 x 480) CMOS image sensor
- Video Resolution: Up to 800 x 600 pixels
- Picture Resolution: Up to 1280 x 960 pixels
- Frame Rate: Up to 30fps at 800 x 600 pixels
- Integrated microphone with noise-cancellation
- Works with native Windows ® drivers for instant Plug & Chat
- Snapshot / Live! Contacts button
- Fixed focus
- Multi-attach base
- Cable length: 1.7 meters / 5.5 feet
- Hi-Speed USB 2.0
- 1-year limited hardware warranty
System Requirements
Intel Pentium 4 2.4GHz or equivalent processor
Windows XP with SP2 / Windows Vista / Windows 7
Apple Macintosh OS X 10.5
Linux 2.6
512MB RAM
USB 2.0 Port
Was £19.99 Inc. VAT
Only £17.98 inc VAT.
ORDER NOW
Saitek PZ52P VGA Webcam - Pink @ £1.32 inc VAT
This great value webcam which is fully compatible with laptops, netbooks and desktop PCs is perfect for video messaging applications. Keep in contact with your friends, family and loved ones.
- Easy Capture, click and send
- 640 X 480 resolutions
- Broadcast live video over the web
- Great for video chat, video mail & video conferencing
- Works with MSN, Yahoo, Windows Messenger & more
Was £2.99 Inc. VAT
Only £1.32 inc VAT.
ORDER NOW
Swann Monitoring Kit With PNP-51 day/night Camera and 7 Inch LCD Screen @ £132.00 inc VAT
The Home and Business Monitoring Kit is a new generation of the SecuraView, one of Swannn's best selling products. It allows you to view and hear security video on a crystal clear 7 inch color LCD monitor. The monitor connects to the color camera via a 60 foot / 18 meter cable. You can operate using the remote control in the pack. Both the monitor and camera must be connected to mains power. The pack also includes 4 theft deterrent stickers and everything you need to get started. The Home and Business Monitoring Kit is perfect for anyone wanting an affordable starting point for their security needs. It's ideal for small businesses, retail stores, restaurants or home use. The unit has a discreet, small footprint with a modern and stylish finish. It's a cost effective way to see AND hear what's really happening. You will love the color video. Unlike black and white systems, you will be able to identify what color clothing people are wearing, what color hair they have, and get a truer picture of what is going on. It's easy to do-it-yourself. Mount the camera to a wall or ceiling is simple with screws included in the pack. The LCD monitor can be mounted upside down or side-ways and the video will realign itself to be the right way up using the image flip option. For discretion and to save power you can also use the auto turn-off function when the unit is not needed. The Home and Business Monitoring Kit includes a PNP-51 camera with short range night vision and a built-in microphone to allow you to hear conversations and other sounds. The Kit is also upgradeable in that you can add a second camera and then switch camera views.
- Mount camera & LCD to walls or ceilings
- LCD image flip option. Mount lcd monitor upside down or side ways & flip the image around the right way
- Auto turn on/off LCD monitor - Set time to automatically turn the montior on & off
- Add a second camera - Automatically switch camera views at 4 to 8 second intervals
Was £134.99 Inc. VAT
Only £132.00 inc VAT.
ORDER NOW
CyberPower DX600E UPS @ £59.99 inc VAT
The DX Series UPS is a cutting-edged UPS system which is ideally designed for home and small office. It can perfectly protect users’ equipment from damaging lightening and surges that cause serious data loss. This DX Series UPS includes an advanced Energy-Saving Technology that significantly improves UPS operating efficiency and reduces energy cost for users. The LED status and battery capacity indicators allow users to monitor power status and battery backup condition to manage data saving more efficiently. Its compact design also assists users to make the best advantage of interior space.
Features & Benefits:
• GreenPower UPS™ Technology : Energy-Saving UPS
• EMI, RFI, Surge and lightning spike protection
• LED status & Battery Capacity Indicators
• Auto-Shutdown software
• USB connectivity port
• 3 power outlets
• Compact design with highest power output
• Equipment Protection Policy up to 50,000 Euros
Was £65.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
CyberPower GreenPower 600VA UPS with AVR @ £58.79 inc VAT
The GreenPower Series UPS with Automatic Voltage Regulator (AVR) is the best solution for SOHO to supply a clean and stable power. The GP series UPS is compatible with many different operating systems, including Microsoft Windows 98/Me/2000/NT/XP/Vista. PowerPanel® Personal Edition management software included for USB Port shows versatility of a UPS, like power voltage, scheduled shutdown, and remaining battery capacity?remaining battery runtime?battery status ...etc. Value GP Series UPS can save upto 75% of electricity and save your electricity bill.
- Energy-Saving UPS
- Automatic Voltage Regulator (AVR)
- Auto scheduled software
- USB & Serial connectivity ports
- 3 Output Connectors
- Compact design with highest power output
- Power Management software included
- Green Power Technology
- Auto restart / Auto charge
- Save upto 75% of electicity
- Equipment Protection Policy up to 25,000 Euros
- 600VA / 360W
- Cables Included: 1 x power cable - integrated
Was £61.26 Inc. VAT
Only £58.79 inc VAT.
ORDER NOW
Energenie 30 Minute Rundown Timer @ £5.04 inc VAT
This rundown timer will switch off the mains power to your appliance after 30 minutes.
Suitable for:
• hair strighteners
• irons
• curling tongs
• electric blankets
• bedroom lamps
• bedroom TVs etc
Voltage: 220 - 250v ac 50Hz
Maximum load: 13A, 3kW
Manual reset button & indicator lamp
Timeout period: 30 minutes
Was £7.88 Inc. VAT
Only £5.04 inc VAT.
ORDER NOW
Swiftech Apogee GTZ Waterblock - 1366 & 2011 Compatible @ £58.79 inc VAT
The Apogee™ GTZ is Swiftech's new flagship water-block. While it shares the same name with its predecessors, it also leaps beyond the GT and GTX performance charts thanks to an entirely new design that pushes and refines both thermal and mechanical specifications to the limits of today's technology. Thermal design of the cooling engine combines the benefits of direct coolant impingement over the CPU area with an entirely new copper base plate design which is primarily characterized by a pin matrix composed of 225 µm (0.009") micro structures. This results in a 20% improvement in thermal resistance compared to the Apogee™ GTX. Mechanical design of the copper base plate is optimized for Intel socket 775, 2011 and 1366 and features a topographically mapped CPU contact area which results in a 75% and up to 300% improvement in TIM joint thermal resistance compared to the Apogee™ GT/GTX series. It should be noted that other types of sockets (AMD socket F, AM2, 940) may also benefit from the enhanced contact area to a lesser extent.
Was £59.99 Inc. VAT
ORDER NOW
EK Supreme HF CPU Waterblock - Full Nickel @ £68.52 inc VAT
The Ultimate CPU Waterblock
After 2 successful years of EK-Supreme CPU water block, EK has released its successor. The EK-Supreme HF - Full Nickel Block is based on same concept as EK-Supreme.The base plate is made of nickel plated electrolytic copper lapped and polished to +/- 0,0007 mm flatness. The top is made of nickel plated electrolytic copper material. Mounting plate is made of powder coated stainless steel. The EK-Supreme HF - Full Nickel cooling engine uses fin design. The water accelerates through thin jet plate channels through 49 very thin channels, which gives extreme cooling surface. The copper base is also very thin, which gives very short distance for temperature to transfer from CPU to water.
Blocks main improvements are:
- better flow up to 50% higher flow compared or EK-Supreme
- better cooling performance
Enclosed in the box:
- EK-Supreme HF - Full Nickel water block
- 4 different jet plates + 1 blank
- Universal supported mounting plates:
o Intel: 775, 1366, 1156, xeon
o AMD: AM2, AM2+, AM3, 939, 754, opteron
- Universal CPU retention backplate
- Thermal grease Arctic Cooling MX-2 (2g)
Supported sockets:
Processor compatibility:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
Was £69.98 Inc. VAT
Only £68.52 inc VAT.
ORDER NOW
XSPC RayStorm CPU WaterBlock (Intel) @ £47.99 inc VAT
Our best ever performing water block, with a unique new look.
- Designed for Multi Core CPU’s
- High Performance Copper Base 56x56x3mm
- CNC Cut Acetal Top
- G1/4? Threads
- 4x 3mm LED Holes
- Compatible with Most Compression Fittings
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
Supplied with mounting hardware, 775, 1156/1155, and 1366/2011 backplates,
twin blue LED, allen key, and K2 thermal paste.
Was £49.98 Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
EK-FC7950 Backplate - Black @ £19.19 inc VAT
EK-FC7950 Backplate is a retention backplate made of black painted aluminum for EK-FC7950 series water block.
Backplate cover the whole lenght of graphics cards PCB, serves as an aesthetic add-on and also provides passive cooling for the backside of voltage regulation module (VRM).
This backplate is guaranteed to be compatible only with AMD reference design Radeon HD 7950 graphics card in combination with any EK-FC7950 series water block. No other water blocks are officially supported! Please check our Cooling Configurator for detailed compatibility list!
Enclosed:
- EK-FC7950 Backplate - Black
- mounting mechanism
- thermal pads
Made in Slovenia - Europe!
Was £19.99 Inc. VAT
Only £19.19 inc VAT.
ORDER NOW
EK-FC7950 Full Cover Waterblock - Nickel Plexi **EN Nickel Plating** @ £73.79 inc VAT
Please note, This item is a PLEXI + Nickel Waterblock. The item has not been produced yet and no stock photo is available.
EK-FC7970 is a high performance full-cover water block for AMD reference design Radeon HD 7950 graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC7950 water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps.
Base is made of electroless nickel (EN) plated electrolytic copper while the top is made of quality cast acrylic material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
G1/4" threaded fittings can be used on both side of the water block (on copper and plastic) and 2 plugs (EK-Plug G1/4) are enclosed!
Enclosed:
- EK-FC7950 series water block
- mounting mechanism with screw-in brass standoffs
- thermal pads
Please note: Thermal paste is not included and needs to be purchased separately. EKWB recommends Gelid GC-Extreme for best performance.
PLEASE NOTE:
- Due to superior nickel plating method and corrosion resistance, the waterblock may loose brightness over time and become of a bit duller tone.
- Due to immense variety of fittings/barbs available on market and no prescribed standards, we guarantee compatibility only for connectors bought from our web site.
Was £74.99 Inc. VAT
Only £73.79 inc VAT.
ORDER NOW
EK-FC7970 Full Cover Waterblock - Nickel Acetal **EN Nickel Plating** @ £73.99 inc VAT
EK-FC7970 is a high performance full-cover water block for AMD reference design Radeon HD 7970 and -7950 graphics card. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC7970 water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps.
Base is made of electroless nickel (EN) plated electrolytic copper while the top is made of quality POM Acetal material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
EKWB also offers a single-slot I/O bracket which frees adjacent PCI/PCIe expansion slot. The bracket is available as an optional add-on and can be purchased through EKWB webshop.
Enclosed:
- EK-FC7970 series water block
- thermal pads
Was £79.99 Inc. VAT
Only £73.99 inc VAT.
ORDER NOW
XSPC Razor 7970 GPU Waterblock @ £77.99 inc VAT
Full Cover VGA Water-Block
- CNC machined copper base
- CNC machined aluminium VRM cooler
- 1mm fins for high performance
- CNC cut stainless steel top
- Dimensions 220 x 142 x 9mm (18mm at ports)
- Prepared for crossfire with 4 G1/4? ports
- Supports ATI 7970 cards
(ATI reference design only)
Supplied with mounting kit, G1/4" plugs, thermal pads and thermal paste
Was £82.99 Inc. VAT
Only £77.99 inc VAT.
ORDER NOW
Alphacool HF D5 TOP - Black Acetal G1/4 @ £20.78 inc VAT
The ultimate top for your Alphacool power pump offers even better performance as well as more mounting and connective possibilities for your favorite pump!
The base performance of the Alphacool TPP & VPP is already truly exceptional, but what if there is a possibility to improve even on that? This idea was also what has driven the developers which have created a product that does not only increase performance but also offers other additional advantages over the base model pump.
One of the greatest advantages are the G1/4” connection threads both at the sides and top of the pump cover. Both can be used separately or even in a combination. For the unused connection threads two knurled copper plated screw plugs are included.
The design is also a factor which was not taken lightly! The elegant black Acetal material with integrated Alphacool logo gives a clue of the potential of the German Know-how in these tops!
Mounting is done quickly and easily. With a simple twisting motion the motor is separated from the mount. After that you will find 4 separated basic components. First pull the O-ring over the polished silver front piece of the pump and then push on the largest of the 4 components. At the back, where the cable is coming out of the case, the counterpiece is pushed on. With the included mounting screws the elements can be tightly connected and you are done!
And what purpose has the last plate? It can be used for mounting of the pump in the case! Simply screw the plate to the pump’s top and the opposite side to the case or decoupling module and you are set to go!
And you will notice: This is yet another great piece of engineering from the Alphacool team!
Technical specifications:
Material: Acetal
Color: Black
Connection thread size: 4x ¼”
Dimensions mounted (L x W x H): 80 x 45 x 80mm
The installation manual of Alphacool HF D5 TOP you can find here as Download.
Extent of delivery:
1x Alphacool HF D5 TOP - Black Acetal G1/4 - (VPP655/TPP644/MCP655)
2x Copper plated screw plugs
Black mounting screws
Please note:
Delivery without pump!
Was £21.98 Inc. VAT
Only £20.78 inc VAT.
ORDER NOW
Hardware Labs Black Ice GT Stealth 120 Radiator @ £26.38 inc VAT
The GTS120 boasts of a radically redesigned Black Ice® core technology that maximizes heat transfer efficiency and maintains effectively the same compact profile of the Black Ice® Pro.
Features:
- Two-pass U-flow tank configuration.
- Custom MaxFin™ 25 micron Copper Splitter Fin Configuration utilizing 45% thinner fin material yielding up to 50% less pressure drop even with twice the fin density.
- Unique fin configuration eliminates intra-louver accumulation of dust particles for trouble free operation.
- Unprecedented Ultra-high 30 FPI (Fins Per Inch) fin density providing dramatically increased heat transfer surface area.
- Custom low-profile 19.0 x 1.2mm MaxFlow™ tubes with 15% more waterside surface area and 60% frontal area reduction for superior low air-resistance aerodynamics and lower internal flow requirements.
- Yields up to 20% more heat exchange capacity than the Black Ice® Pro in both Stealth or Performance modes.
- Achieves Black Ice® Xtreme level performance in stealth mode (low-noise/low-airflow conditions).
- M4 Threaded Screw Holes for easier mounting and greater adaptability.
- Now standard G 1/4" female threaded fittings.
- Full high-temper brass structural construction for weight reduction and superior corrosion resistance.
- High performance compact radiator compatible as an upgrade to the Black Ice® Pro and most 120mm form factor radiators.
- Uses 100% Non-corrosive water-solluble fluxing process.
- Fully RoHS compliant.
- Full electrostatic polyurethane painting finish for uniform coating with high temperature curing for increased finish durability.
- Renowned Black Ice® quality.
- Patent Pending Design
Was £30.98 Inc. VAT
Only £26.38 inc VAT.
ORDER NOW
Hardware Labs Black ICE SR-1 240 Radiator @ £59.99 inc VAT
The Black Ice® SR1-240 bridges the gap between ultra-stealth and extreme high performance allowing it to effectively utilize sub-1000 rpm fans and scale performance up to 2000rpm. Ultra-stealth operation with increased thermal capacity, and from the industry's standard bearer for quality and craftsmanship.
Features:
- Two-pass u-flow configuration utilizing high-flow tubes for up to 40% increase in internal flow rates.
- Custom compressed core width to maximize airflow and enhance heat exchange.
- Optimized custom 9 FPI (Fins Per Inch) 45 micron copper maximized conductivity.
- Yields up to 30% more heat exchange capacity than the Black Ice® GTX in ultra-stealth operation mode up to 2000rpm.
- Built-in 15mm deep plenum for equalized core air pressure distribution.
- Standard G 1/4" female threaded fittings.
- High performance compact radiator compatible as an upgrade to the Black Ice® Xtreme III, Black Ice® GTX240 and most 3x120mm fan form factor radiators.
- Uses 100% Non-corrosive water-soluble fluxing process.
- Carbon Black Finish.
- Patent Pending Design.
Was £69.98 Inc. VAT
ORDER NOW
Hardware Labs Black ICE SR-1 360 Radiator @ £74.39 inc VAT
The Black Ice® SR1-360 bridges the gap between ultra-stealth and extreme high performance allowing it to effectively utilize sub-1000 rpm fans and scale performance up to 2000rpm. Ultra-stealth operation with increased thermal capacity, and from the industry's standard bearer for quality and craftsmanship.
Features:
- High performance compact radiator compatible as an upgrade to the Black Ice® Xtreme III, Black Ice® GTX360 and most 3x120mm fan form factor radiators.
Was £83.98 Inc. VAT
Only £74.39 inc VAT.
ORDER NOW
Phobya 5,25" Single Bay Reservoir Black @ £23.99 inc VAT
Phobya's first Slot-in reservoir with many technical innovations and great details: A true optical highlight! This is more than just a Plexi reservoir!
The main function of a reservoir in a water cooling loop is to offer space for expansion of the coolant, deaerate the loop and also help with initial filling. This is where the innovations from the developers at Phobya comes into play: An internal channel system helps with deaeration to ensure all air bubbles being removed from the coolant.
Even with very powerful pumps this reservoir is able to remove the air bubbles from the system. The filling of the reservoir can be done easily and quickly by removing the 3/8" screw plug after pulling the reservoir out of the drive bay. We recommend using a funnel for filling.
An even easier solution is connecting a Fillport which will allow filling without pulling the reservoir from the case.
The small details are what makes this reservoir great: Four G1/4" threads give many connection possibilities for maximum versatility.
The optical aspect of a watercooling is also very important! Especially in large enclosures there are usually too many 5.25" drive bays. With this handy reservoir they can now be used and will look even better to make the front of your system even more beautiful. A second thin Plexi plate on the actual reservoir front protects the black middle plate with the words "PHOBYA". Besides the Phobya inscription a fill level indicator is integrated to allow checking of the fill level at the front of the case. Especially with coloured coolant the fill level indicator provides a beautiful effect and sets a unique accent.
This effect can be improved even further when using the four 5mm LED holes at the rear for unique lighting effects inside of the reservoir.
The reservoir is shipped with all parts required for mounting. For mounting the reservoir can simply be pushed into the front of the tower and mounted with the black hexagonal socket screws. As usually only two of the four connection threads are used, two black nickel plated screw plugs are included.
Technical details:
Material: Acryl/Plexi (PMMMA)
Color: Transparent, black front
Dimensions (L x W x H): 175 x 149 x 44mm
Led holes: 4x 5mm
Filling opening: 1x 3/8Zoll
Connection threads: 4x 1/4Zoll
Complies with Rohs directives!
Extent of delivery:
1x Reservoir
2x Screw plugs
4x 5mm mounting screws
4x Washers
Was £24.98 Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
1 Pack - Verbatim BD-R 6x 25GB Blu-ray Print J/C (43712) @ £3.59 inc VAT
BD-R SL 25GB 6x Printable Single Jewel Case The advent of Blu-ray technology has led to the introduction of high capacity storage discs to meet the demand cause by the rapid growth of high definition television (HDTV).
Key Features
• Hard Coat protective layer
• Extremely long archival life
• Excellent playback performance
• BD-R is for use in BD drives and recorders
• Laser Wavelength: 205nm
Blu-ray discs get their name from blue laser technology. The shorter wavelength of the laser is the reason it is blue in colour. The blue laser has a wavelength of 405nm compared with the wavelength of 650nm for DVD which utilises red laser technology. The benefit of having a blue laser with a shorter wavelength means it is possible to write smaller data pits and therefore vastly increase the amount of data on the disc.
Blu-ray discs offere 3 to 5 times the storage capacity of a standard recordable DVD disc, enabling the recording, rewriting and playback of high definition video (HD).
Was £3.74 Inc. VAT
Only £3.59 inc VAT.
ORDER NOW
50 Pack - Kodak DVD-R 16x Shrink Pack @ £8.40 inc VAT
DVD-R - 4.7GB - 16x Write Speed - Shrink Pack - 50 Pack
Was £8.99 Inc. VAT
Only £8.40 inc VAT.
ORDER NOW
25 Pack - TDK CDR-80 52x 25pc Cakebox (T18767) @ £4.79 inc VAT
Developed for ultimate performance, and manufactured to the most exacting standards, TDK CD-R media is the ideal digital storage solution. CD-R disks are write once, meaning a CD-R can be fully recorded one time, but can't be erased or rerecorded.
Key Features
• Write-Once CDR
• Native Capacity 700MB
• Write Speed 52x
• Package Type Spindle
• Disc Surface Silver
Was £4.99 Inc. VAT
Only £4.79 inc VAT.
ORDER NOW
Netgear WNDR3400 Wireless-N N600 Wireless Dual Band Cable Router @ £84.19 inc VAT
Netgear WNDR3400 Rangemax Dual Band Wireless-N Router
The NETGEAR N600 Wireless Dual Band Router offers the high-performance wireless Internet access needed for demanding applications, such as streaming multimedia and multiplayer gaming. Dual band technology avoids interference, ensuring top speeds and the greatest range.
Features
Dual band - Offers twice the bandwidth with better connection and less interference
Faster multimedia streaming - Provides Wireless-N speed and dual band performance for streaming video, multiplayer online gaming and simultaneous downloads
Shared storage - ReadySHARE™ provides fast and easy shared access to an external USB storage device Jitter-free video and gaming - Video Quality of Service (QoS) for reliable Internet connections
Live Parental Controls - keeps your Internet experience safe
Blocks unsafe Internet content and applications and can be managed from anywhere
Protects connected devices through the router such as PCs, gaming consoles, and iPod touch®
To learn more visit www.netgear.com/lpc
Guest network access - Provides separate security and access restrictions for guests using the network
Broadband usage meter - ensures daily, weekly and monthly measurement of Internet traffic with customized alerts
Easy setup - Smart Wizard® CD with graphical installation guide
Secured connection - Push ‘N’ Connect with Wi-Fi Protected Setup® (WPS)1 ensure a quick and secure network connection
NETGEAR Green features - Power and Wi-Fi on/off buttons, Energy Star-compliant power adapter and 80% recycled packaging
System Requirements
Broadband (cable, DSL) Internet service and modem with Ethernet connection
2.4 or 5.0 GHz 802.11a/b/g/n specification wireless adapter or an Ethernet adapter and cable for each computer
Microsoft® Windows® 7, Vista®, XP, 2000, Mac OS®, UNIX®, or Linux®
Microsoft® Internet Explorer® 5.0, Firefox® 2.0 or Safari 1.4 or higher
Standards
IEEE® 802.11 b/g/n 2.4 GHz
IEEE 802.11 a/n 5.0 GHz
Five (5) 10/100 (1 WAN and 4 LAN) Ethernet ports with auto-sensing technology
Performance
480 MHz powerful MIPS 32-bit processor
Memory: 8 MB flash and 64 MB RAM
Five (5) (1 WAN, 4 LAN) Fast Ethernet ports
Advanced Quality of Service (QoS)
Supports Wireless Multimedia (WMM) based QoS
Was £94.99 Inc. VAT
Only £84.19 inc VAT.
ORDER NOW
Netgear WNDR4000 Wireless-N N750 Wireless Dual Band Cable Router @ £118.79 inc VAT
The NETGEAR N750 Wireless Dual Band Gigabit Router offers high performance wireless speeds of up to 450Mbps (5GHz only) needed for demanding applications, such as large file transfers, streaming HD video and multiplayer gaming. Dual band technology avoids interference, ensuring top speeds and the highest range, while Gigabit offers ultra-fast wired connections.
WAN Gigabit Ethernet port for cable/fiber combined with a wireless router create the Ultimate Integrated Home solution
Concurrent Dual band - Eusuring top speeds and the greatest range while minimizing interference
Faster multimedia streaming - Provides Wireless-N speed for streaming HD videos, simultaneous downloads, and online gaming in addition to basic Internet applications
Shared storage - Two ports for ReadySHARE® USB Storage Access provides fast and easy shared access to an external USB storage device
Live Parental Controls - Keeps your Internet experience safe
Secured connection - Push ‘N’ Connect ensures a quick and secure network connection
Broadband usage meter - Monitors Internet traffic and sends customized reports to help keep costs under control
Easy installation - Connect to PC and open your browser to install
Compatibility - Compatible with all major ADSL Internet service providers (ISPs)
Was £139.98 Inc. VAT
Only £118.79 inc VAT.
ORDER NOW
