No it won't fit. There is very little space. Also note that you may not be able to fit a dedicated graphics card in the case if you have a 3.5" drive at the bottom.You think I could squeeze a 2.5" under the 3.5" hdd, as there are screw holes for a 2.5" on the floor of the case?
The only way I could see it working is if you remove the SSD from its housing completely. Will you be using the top 5.25" drive bay? If that's free then you could always use an adapter in there.Ive got the 7mm version of the Crucial m4 ssd ordered aswel.. I guess I could somehow mod it so the 3.5" hdd sits slightly higher up in cage?
