could i use a kenko 1.4x dgx pro 300 with the canon 70 - 200mm f/4 usm L or IS version will this combo work or will i just get blurry pictures.
http://www.techradar.com/reviews/cameras-and-camcorders/cameras/camera-lenses/kenko-teleplus-pro-300-af-dgx-1-4x-1030858/review
http://www.steveoakley.net/template_permalink.asp?id=263
I use a 7d with 100-400 for airshows and it's not a bad setup. I also have a 70-200 f/4 but thats not really used too much apart from static ground shots or when i'm really close to the action.
Even with the crop body though i would really prefer a 500mm prime for airshows. But, all i shoot really is aviation so eventually i will get one!
From what i have heard (have no experience myself on this) the AF speed is majorly hit when using a TC on the 70-200 as well.
I thought that Canon were bringing out a new telephoto lens with built in teleconverter? I seem to remember there were pics on the internet of the new MKIII and a lens that were being tested at a safari. Not sure if this is something that might be worth researching?
Edit... Look here http://forum.mflenses.com/viewtopic.php?t=46618
The AF will be slower with the 2x on a 70-200. Seeing as some people are using the mkII over the 300mm f4 with 1.4x and 100-400 lenses, I just had to give it a go. I'm selling my mkI IS and 150-500 to fund it. I'm going to try the Kenko or Sigma TC's first, just need to source some!
Here's why I've gone the 70-200 mkII route.
Here's why you probably shouldn't with a mkI 70-200.
Expected to be around 8k though!
http://www.the-digital-picture.com/...m-f-4-L-IS-USM-Extender-1.4x-Lens-Review.aspx
Both the new Canon and Nikon 70-200 are much improved with TCs but the Canon with a 2xTC wide open is not as sharp as the 100-400 wide open a 400mm.
So it is stll the case that if you need the 300-400mm range sufficiently often then the dedicated lens provides better sharpness.
Look at the 400mm f/5.6 vs the 70-200 IS MKII:
http://www.the-digital-picture.com/...meraComp=453&SampleComp=0&FLIComp=7&APIComp=2
I wish Nikon made a modern 400mm f/5.6 . They did release a patent so maybe one is coming.
As I said, if you need the 300-400 range frequently then a lens of that focal length without TCs would be a better purchase, but since you want to use the 70-200 without a TC most of the time then it is obviously the better option.
Buying a lens with the intention if using a TC frequently, unless we are talking exotic primes with a 1.4x TC, is not really a great investment.
http://www.lcegroup.co.uk/used/Canon-CANON-28-300mm_43445.html
It is always a double edged sword trying to get more reach by using TCs that then impact your effective resolution such that you are not really gaining anymore than simply cropping the image and potentially upscaling.
Getting sufficient reach is a real pain and there is no magic solution, except trying to get closer to the subject (which is not always possible).
I was thinking of updating my 70-200VR1 to the newer version so it handles TCs better but i am no so sure. I may bet better seed simply saving up and buying a 500mm f/4.0 VR selling and replin gthe 70-700 with a couple of primes.
Maybe the suggestion to hire something to try is a good idea, any suggestions where from, midlands bassed ?
