I have Stereoscopic 3d on the left panel inside nvidia control panel (Using latest drivers)
I have Enable stereoscopic 3d (Enabled)
Then a drop down for BenQ 120hz 3d LCD or 3D vision discover (Using Benq 120hz option)
I see box tyhat says: select when the display is in 3d mode but its greyed out :'(
Edit - after disabling my second monitor that was on extend display, when I set it to use only 1 monitor I can then select always
(you should see enemies a lot better too)
