The 3820 is X79.
Read point a)
He wasn't using c) as a justification over the 3820, he was using it over the 2600k/1155 platform.
The 3820 is X79.
...and an encoder written to utilise all cores![]()
Depends on the software, VMs, rendering, encoding. Intel has targetted high end workstations and enthusiasts with SB-E, it's not all about games.
Why? You're interested in gaming and don't see the need for more cores - even if you had the money why would you buy one? You must think it's better in some way...
Your approach is sound, a balanced system is always best. I'd guess that the majority of 3930K owners also have a balanced system, though there will always be exceptions.
No, a 3960X isn't adding additional cores (which is the big difference between 3820 and 3930K) and with overclocking of both chips the benefits are less pronounced over the 3930K.
Let me turn this question on it's head, what made you decide to buy into x79 over z68? A z68 would have been marginally cheaper and offered the same level of performance - I'm guessing there must be some value or worth to you of having x79 otherwise why did you spend the extra?
I never said it was
Firstly I'm not only interested in gaming, I don't know what gave you that impression. The reason I mentioned gaming in my OP is because I suspect a lot of 3930K users are mainly gamers and such (in my opinion) have wasted £200.
I game yes, but I also do a moderate amount of video encoding (My Samsung SII films in 1080p and I use the PC for editing those videos) but not my main task. I probably use my PC most for programming via Visual Studio and as an SQL server for testing my software.
The reason I said "If I won the lottery I'd get the 6960X" is because my OP is about what affordable and important to the 99% of us who have some kind of budget, if you have no budget then there's no problem in what you spend so you might as well.
As I said, just seen a few prospective builds where people are opting for the 3960K then buying a mid-range PSU, RAM and sticking with hard drives etc because they'd blown most of their budget on the CPU.
Obviously if you REALLY are going to benefit from it, like PCZ said then fair enough but I suspect that most people don't.
As I said, a 3960X owner would probably disagree and be able to justify paying twice the price for the X model.
A) Longevity - X79 still has Ivybridge-E to come whereas z68 is about to be replaced at the end of the month. A better question would be why I didn't wait for Z77 really.
B) 1155 being cheaper is a myth, at least in my case...
3820 = £229
2700k = £265 (even the 2600 non-K is more expensive than the 3820!)
The motherboards have a higher general range of prices (although were higher before 2011 arrived) but hypothetical the P67 build (shopping list) I did before I finally splashed out on the X79 had a £200 mobo on anyway.
So I've probably spent an extra £20 on the rig I was planning before in which reason A was enough to justify it.
But you only mentioned gaming in your original post, so that was the only reference point you gave us. Now you mention your other uses, then quite possibly the extra £200 is worth it. But only you can make that judgement based on how much you do of each activity and how well it is multithreaded.
That's not what your OP came across as. Everyone will have a different budget from doing it on the cheap, right up to money no object. The relative value of the different CPUs can only then be judged by the individual, the amount of money they have available and the tasks they want to perform.
Fools (not PCZ). Like I said, you've opted for a well balanced system within your budget. Be happy.
They probably can to some degree, but the point was there is less of a differential between 3960 and 3930 than 3930 and 3820 purely due to the number of cores.
But you could have built a cheaper z68 system with an OC 2600K, that has a similar spec/capability to the one in your sig. You chose not to with very valid reasons to yourself, no doubt the people who have gone for 6 core CPUs had very valid reasons for themselves. That's what I was aiming to demonstrate to you.
When I mentioned gaming I wasn't referring to me though, just the concept of it and how the 3960K probably wouldn't be an advantage (not considering the extra GPU power you can use the £200 saved on).
I don't think my OP implies I was mentioning gaming for personal reasons, I was doing it because it probably is the main reason for new builds if you take the whole of the this forum into account.
Yes but £200 isn't worth the same as it is to a millionaire as it is to the rest of us so losing it doesn't have the same effect. Also the millionaire, won't then downgrade the other parts which is more probable for the 99%.
I am, I guess I'm hoping this thread may make some people who are building new systems think a little I guess rather than have a pop at current 3930K owners.
Hence the title being "is the 3930K really worth £200 more than the 3820" and not "ZOMG peeps who bought the 3930K wasted 200 hundred squid SUCKERS!!!!![]()
But what about the differential between the clock speeds, downgraded to 3.2 to accomodate those cores and what about the software you're using?
The 50% better thing is only true under specific circumstances and you have to OC the 3960K to 3.6GHz as well to compare to a stock 3820.
It's simply a myth to imply that your PC will generally be 50% faster using the 3930K. I'm not saying that is what you're claiming but there are a lot of caveats to the 50% more power figure that aren't being mentioned here.
Of course, there are people who obviously use specialist software and use their PCs for non-mainstream reasons who can justify it. I'm not claiming that under no conditions can you justify buying a 3930K, I am asking do most people need it.
Notice 'most people' not the small number of people who do 3D modelling or the tiny number of people who encode videos constantly despite not having a job that requires it (as they'd use industry based equipment and not a home PC anyway).
Simon
You might wan't to investigate why the X79 platform has higher performance with multi GPU configs than 1155.
I am seeing a fairly significant improvement in GPU performance on the X79 over my older P67 machine.
This isn't down to CPU performance differences as the 3820 and 2500/2600
have near identical IPC.
It may be PCIe latency is lower on the X79 or that the latest cards. 680's and 7970's are now being held back a bit by the 8x PCIe on P67/Z68.
Maybe the quad chan memory is helping ?
I think even 3960X owners would admit they've payed a massive premium for mainly just the overclocking potential.
3930K v 3820
Fully unlocked
2 additional cores
50% more performance
100% extra cost
3960X v 3930K
3MB extra L3 cache
1-5% more performance (?)
Supposedly the best silicon
100% extra cost
3930K is clearly a great value product compared to 3960X but there is still a slight premium (£100?) on it compared to 3820 because it's 6 core and like 3960X has unrivalled performance.
3930K v 3820
Fully unlocked
2 additional cores
100% extra cost
3960X v 3930K
3MB extra L3 cache
100% extra cost
3930K is clearly a great value product compared to 3960X but there is still a slight premium (£100?) on it compared to 3820 because it's 6 core and is unrivalled.
Yup. I'm full up with the cold that is going around at the moment...In theory it would take two thirds the time.
Wouldn't that be 50% faster?
Not according to: http://www.anandtech.com/bench/Product/434?vs=287In that case you shouldn't buy the £150 8 core bulldozer 8150?
Arggghhh, can people stop making this claim. It's not 50% more performance at all.
Firstly, it has 12% slower clock speed (3.2 vs the 3.6 on the 3820) so overall it's 33% faster on paper (so actually Buchanan0204 was right in the first place).
3.2 x 6 = 19.2 GHz overall CPU Power
3.6 x 4 = 14.4 GHz
Difference = 33%
http://www.anandtech.com/bench/Product/552?vs=523
look at the cinebench 11.5 benchmark 3930k shows a 41.5% increase over the 3820
3.6 x 4 = 14.4 GHz
Difference = 33%
The more cores you add to a CPU, the slower the stable clock speeds become (at concept and build stage) and you can't just ignore that fact and claim the 2 cores equals 50% more power. Each of the cores on the 3820 is faster than each of the cores on the 3960K even if there are two less.
Even then you still need certain software (the vast majority of software that most people use isn't) to see that benefit and even then there's another factor...how much the software's performance is tied to the CPU.
Only if you had something that was 100% CPU intensive (so it would not use the RAM, GPU, Hard drives etcs at all) would the 33% figure be accurate..but no sofware ONLY uses the CPU for performance.
So for example if a piece of sofware's performance was afftected by 50% based on the 'power' of your CPU, then the 3960K would only out-perform the 3820 by 16.5%
So the reality is, the 3960K can be around 30% faster for CPU intensive pieces of software that were coded specifically for muiti-cored PCs; but for most people/applications it will provide you will a couple of percent extra power...in fact in a lot of applications it would be slower due the lower clock speed.
If anyone can find me a benchmarking test that shows the 3960K outperforming the 3820 by 50% in any field I'd love to see it. In fact, here's some benchmarks comparing the two.
Photoshop = 0.8% increase
H264 encoding = 7% faster
Music encoding = 38% faster
Gaming = 4% faster
The only area the 3960K really exceeds is music encoding and even then it still a way off being 50% better.
The 3930K is 204% of the cost of the 3820 (£299.99 vs £469.99).
