No, but if you buy direct from the devs you should get a Steam code.quick question ladies, If I buy this on GOG do i get a code to be able to activate on Steam as well ?
but GoG have all the nice free stuff![]()
I'm finding this quite tricky. Now down to Level 5 and the mosters are seriously messing me up. I'm beginning to think that sticking with the default party was a bad move. Do I start again now that I've spent a good few hours scouring the place for secrets and not bothered to document a single thing.
The point is, with 12 points in their primary stat, rogues can use any weapon from the back row. Swords, axes, you name it.
That doesnt really answer the question though does it... The point I was making was why would anyone use a bow using rogue on the front row over a warrior with a shield
