Panasonic ST30 5.1 optical out?
26 Nov 2002
Romford
Does the ST30 pass through 5.1 from external HDMI sources (xbox/htpc) out of it's optical out, my old TV doesn't and Im just wondering if I should waist time mucking about with this new one when it arrives.
cheers
Doesnt your receiver display DTS or TrueHD etc?
DTS/TrueHD only shows when I use the optical lead
edit: Although a quick google search shows this, so you should be ok:
Does HDMI support Dolby Digital, DTS, and high-resolution audio formats?
Yes. From the start, HDMI was defined to carry 8-channels of 192kHz, 24-bit uncompressed audio, which exceeds all current consumer media formats. In addition, HDMI can carry any currently available flavor of compressed audio format such as Dolby (including Dolby Digital EX 7.1, Dolby Digital Plus 7.1, Dolby TrueHD) or DTS (including DTS-ES 6.1 and DTS-HD Master Audio). Such compressed formats are the only multi-channel or high-resolution audio formats that can be carried across the older S/PDIF or AES/EBU interfaces. HDMI 1.3 adds additional support for new lossless digital surround audio formats Dolby TrueHD and DTS-HD Master Audio. Additionally, most existing HDMI sources can output any compressed stream, and the newer sources can output uncompressed 6-channel, 96kHz audio from a DVD-Audio disk. There are A/V receivers on the market that can accept and process the 6- or 8-channel audio over HDMI.
I have a crappy AV setup, I want to go from HTPC to TV and out again into AV. Or I can just use HTPC to AV like Im doing at the moment (so no nice sounds when I just use the TV).
