+1 Probably wouldn't have sold my ps3, such is my hate for the ps3 controller.
But the DS3 is the best controller!
Does it need an ugly adapter sticking out of the PS3?
Genuine question, why should I buy this over a 360 controller? (already have one btw)
For the rapid fire function or is the battery life and wireless capability longer?
I hate to use one of my most hated internet memes but;
Not sure if serious?
Yes. All none sony products do. I'm sure the bluetooth from Sony has a special encryption. So to combat it none Sony products need their own bluetooth receiver.
Why don't you like it?
The triggers are a bit iffy but other than that a far better d pad, pressure sensitive buttons and analogue sticks are perfectly fine
I would say that the d-pad is only thing it has going for it and really, is that something a controller should be trumpeting? It's got no heft to it, the buttons feel cheap, the triggers are awful, the sticks are in an awkward position and domed. Ergonomics aside it just feels cheap cheap cheap.
It was fine and dandy on the PSX, but even then I preferred the n64 controller. The ergonomics were never brilliant and have barely evolved at all.
Crappy d-pad included(it's only weakness) I would take the xbox controller over it every time and if I stop being such a miser I'll get the new xbox pad(with fancy d-pad) and just deal with the ps3 pad when I have to.
I wish they did the PS3 controller for PC, much nicer than xbox
Not sure if you're serious?!
It feels cheap. I don't like the analogue sticks at all, they feel too loose, not enough resistance. The triggers, as you say are rubbish.
The d pad is ok, it's quick to turn on and I liked the ability to switch music tracks anywhere because of blutooth.
The 360 pad though is the best console controller ever made in my opinion. Just a shame the console lacks the media capabilities of the ps3.
Why do you want weight on the controller?
