As Alex mentions, this board isn't ideal if you want to run a second graphics card one day (if you want to do this I would go with this board) - but if you only plan to ever use a single graphics card then the board is great.
I'm not convinced of that. Early reports suggest that IB struggles with heat if you give it extra voltage. That means all these boards with tons of phases will go unused unless it's under proper water or better. IB isn't a 130W part.
Ironically we're starting to see some real high end voltage control, just as power consumption takes a big dip.
