thanks for that,theres so many different versions so all of you search,search and search some more so your 100% sure of all the features that you want/need
The sabertooth doesn't come with wifi either does it?
Yeah Im sort've going to try to hold out as long as possible... but buying new tech is sooo tempting D:
. I may consider shelling out for this beauty http://www.overclockers.co.uk/showproduct.php?prodid=MB-387-GI&groupid=701&catid=5&subcat=2261
probs going to end up with the ud5/asus v pro/sabertooth OR I might wait for the second batch of z77s. But Im not sure what manufacturers are releasing more models might just be Gigabyte w/ the sniper boards. But either way might be worth holding out for.
