Little Discoveries
The middle mouse button opens links in a new tab, I really don't know how I missed that
MW
And the middle mouse button closes tabs in FireFox, annoyingly after trying it on this page! :mad:
Alt and Print Screen highlights the live window rather than the entire screen. Oldy but amazing how many people don't know about it.
That you can get away with buying large screen TV's for £20 by putting them through on self service checkouts as button mushrooms. ;)
That 'F2' will put whatever is highlighted, editable. I.e. a file name/field in excel
Genius!
Mega genius!
Mmmmmmmonster genius!
How did I miss all these?
Now, do I have anything to add? Hmmm, F4 repeating whatever your last command was in MS programmes. Can there be a human being alive who doesn't already know that one?
Learning that I had been tying my shoelaces the wrong way round all my life and correcting it has literally changed my life as they never come undone anymore.
Same. Thirty years of doing it wrong and all I needed to change was right-over-left instead of left-over-right at the start, so it was a reef knot rather than a granny knot. No more infuriating double knots required.
That you can pinch apart the touch keyboard on ios 5 to split it rather than having to press and hold the split button... Also found five finger close apps the other day, and remembered the four finger swipe.
The keyboard one is most used, but still all were nice..
kd
kd
Didn't know that you could split the kb. Thanks.
I'll share another recent discovery... the unix join command. Saves a lot of hassle merging files that have a common key! Despite my example, it's best to ensure that both files are sorted by the common key first to avoid any unpredictable behaviour.
EG:
$ cat file1
John,3841
Dave,3692
Harry,3102
$ cat file2
John,Accounts
Dave,Support
Harry,Sales
$ join -t "," -j1 1 -j2 1 -o 1.1 1.2 2.2 file1 file2
(so join with comma as delimiter, join on field 1 of file 1 and field 1 of file 2, then output file1.field1, file1.field2, file2.field2 - and the input files are file1 and file2)
Dave,3692,Support
Harry,3102,Sales
John,3841,Accounts
It's very fast and I use it in some scripts to merge some rather large output tables. The method I was using before I discovered this was a fair bit slower.
This is really useful. Thanks.
kd
if you split the keyboard by touch it sits lower on the screen rather randomly, but its a much nicer position.
Shoe laces wise if the loops point up and down rather that side to side your doing it wrong - when your tieing the bows together you need to change the side that goes under around...
:eek: You, sir, are a god among men. How have I been using Windows since 1993 and not discovered this? :p
I found that middle mouse button trick for opening something in a new tab a while back - I just can't get myself to use it for some reason. Just always right click the link and do it there....can't stop myself.
'Git bisect' blew my mind when it was shown to me last week.
If you have some units tests in your code base that can output success or failure then you can write a short script that runs these tests checking for success and git bisect will do a binary search through all previous revisions to find the revision which broke your code (i.e where the bug was introduced).
EG:
$ cat file1
John,3841
Dave,3692
Harry,3102
$ cat file2
John,Accounts
Dave,Support
Harry,Sales
Dave,3692,Support
Harry,3102,Sales
John,3841,Accounts
thats handy.
