Gaming computer £800 budget
12 Apr 2012
Surrey
Hello there, I am looking to build a gaming pc for around £800 I will need everything so OS, gaming mouse and keyboard and the computer parts themselves. I do already have a monitor so wont need a new one. For the case I was thinking of the CM storm enforcer but any other suggestions would be greatly appreciated.
Thanks
cheers guys for the excellent advice, one last question (hopefully) would you recommend AMD cards over Nvidia? and is there an Nvidia equivalent for a similar price?
not much rly over amd and nvidia as people would have believe. amd is known to be cheaper. just go for the best u can afford. for about £200 the 7850 is a very good card
The 570s perform similar/slightly better:
http://www.anandtech.com/bench/Product/549?vs=518
But are slightly more expensive and are older so use more power - so I'd suggest the 7850 as others have for your price range :)
hmm, i think i might wait a bit then and save up a bit more money so i can afford some better parts, especially if ivybridge and the Kepler series form nvidia are coming out
as said above. u could always be saving up for better parts as something is always on the horizon which will be better, than the current options
